Old Feb 07, 2013, 07:57 AM
TomCrump is online now
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Originally Posted by rcav8r2 View Post
I use seeTemp (seetemp.com)
Here's a REALLY old web page I did years ago that shows how I use it.
http://home.comcast.net/~daverc102/spookmain.htm
I'm surprised that nobody commented on your post.
See Temp is a viable option when duplicating parts, and it is probably one of the easiest to do.
I'm using it on my current build. What a time saver. At least it is for me.
TomCrump is online now Find More Posts by TomCrump
Old Feb 07, 2013, 09:24 AM
twalther is online now
Find More Posts by twalther
United States, MN, Waseca
Joined Jan 2011
I would not use 3M 77 as it is a permanent adhesive, instead use 3M spray mount. It is intended for such applications.
twalther is online now Find More Posts by twalther
Old Feb 07, 2013, 09:38 PM
conrad907 is offline
Find More Posts by conrad907
conrad907's Avatar
China, Guangdong, Shenzhen
Joined Feb 2012
I used the acetone transfer method for my current build, and thought it worked quite well. It is mentioned in the forum here this can cause distortion of the paper. I hadn't really thought about that. I do agree with this method of cutting and labeling templates as a good approach. I will do this next time I scratch build from plans.
conrad
conrad907 is offline Find More Posts by conrad907
Old Feb 07, 2013, 11:48 PM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
For me making templates is the easiest thing. These are some of the templates I did for the Cap 232 I am building. Just use any heavy card stock you have around the house. Cereal boxes work great. I am saving all my templates for multiple reasons. In case I damage a wing I will be able to quickly replace broken parts, some buddies at the field have expressed interest in having the same plane if it flys well, and hell I think I might build another one.
cbarnes0061 is offline Find More Posts by cbarnes0061
Discussion Transferring plan images to balsa Peter Davis The Builders Workshop 8 Jun 29, 2006 12:44 PM
Transferring plans from paper to balsa. New method? Chuck The Builders Workshop 19 Apr 13, 2004 10:57 PM
Transfer of plan lines to balsa...help! JonB The Builders Workshop 12 Dec 13, 2002 01:28 PM
transfering plans to Balsa Da Flying Man Electric Plane Talk 5 Nov 30, 2002 09:16 PM
