68mm F-35C Project
Hello everyone,
**I have finished building a 37", 1.25 kg F-35C from depron and 3/4 oz fiberglass. I am extremely pleased with the final product, and I am very excited for the maiden.** Finished and flying great!
[I'm in the process of designing plans for a larger scale (roughly 39" span) F-35C. I will be using 6mm depron, and I will fiberglass the depron. The plans I am using are modified from au117's F-35 overall layout. Gear I will be using: Alloy DPS Series 68mm EDF unit with 3580kv : (235g) 1.7kg (3.78 lb) thrust E-flite 60 amp ESC (66g) Turnigy 2200 mah 4s 25-50C battery (238g) Servos: Undecided, I have several 9g and 15g servos Ailerons, Elevators, and Rudders. *no longer using retracts, but steerable nose gear* AUW: Looks to be around 1100-1200 grams (~2.5 lbs) 332 Watts/lb Please give me any advice, structural..mechanical...anything! I've only dealt with smaller scratch build planes from 10" to 18" wingspans.] |
Download the free version of profili2, and you can print out any airfoil they have to see how it will look. When you choose a certain airfoil and go to print it, it will ask what size in length (mm) plug the numbers in and your all set to go. It really is very easy.
http://www.profili2.com/ Good luck and have fun!
I'm trying to sort out the intake duct...any recommendations?
I like awrightbrother's method, http://www.rcgroups.com/forums/showt...672388&page=45 However, I'm really trying to minimize weight. Do I need an intake duct with this set up? The area transitioning from the entrance to the EDF will remain almost constant (d = 68mm, A = 3,216 mm^2) with the belly of the plane and the splitter. |
| Thread Tools | |
| Idea RC lander EDF 68mm W/F-22 JET FOAM SELF MADE MAIDEN FLY | tttfck | Foamies (Scratchbuilt) | 3 | Aug 16, 2009 08:04 PM |
| Build Log F-16 scratch build foamy 68mm EDF | viper1990 | Foamies (Scratchbuilt) | 9 | Sep 28, 2008 05:40 PM |
| Sold RBC F-35C Joint Strike Fighter - Project Plane | punkindrublik | Aircraft - Electric - Jets (FS/W) | 1 | Aug 04, 2008 10:38 AM |
| Discussion phase 3 f-16 with 68mm fan | zaskarkid | Foamy EDFs | 3 | Jun 24, 2008 03:39 PM |
