Old Feb 03, 2013, 09:12 PM
Jeff2010 is offline
Find More Posts by Jeff2010
Joined Jan 2013
Painting a Sterling Balsa Wood model Chris Craft boat
Hi everyone,
Have some questions regarding painting my Sterling Chris Craft 50' Catalina Flying Bridge. What type of paint do I use? Do I seal it first with dope? Or is the color paint dope? I want to paint it white with the light blue on the top, does anyone know what the actual tone of white and blue are called? What type of clear varnish or lacquer do I use on the Mahogany parts? Should I clear the mahogany pieces before I glue them?
Jeff2010 is offline Find More Posts by Jeff2010
Old Feb 03, 2013, 09:47 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Hi Jeff, looks like quite a bit of construction ahead for you before many of the answers to these questions are meaningful..
Have you started the model ? ( all we see is the box ) ...
Tim B. is offline Find More Posts by Tim B.
Old Feb 03, 2013, 10:24 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Hi Jeff2010,
You will probably need to fiberglass the hull in order to give it proper strength. Here is a link to a thread that explains the whole process:
http://www.rcgroups.com/forums/showthread.php?t=329811
And this thread is a great resource for all construction techniques. It has links to differnt thread based on topic.
http://www.rcgroups.com/forums/showthread.php?t=1301317
Also, you should start a thread for your boat build, this way you can ask any questions as you go, and post pictures to help explain what you are dealing with. The members here love to see pix and follow along.
Regards,
Pete
blutoh is offline Find More Posts by blutoh
Old Feb 03, 2013, 10:48 PM
Jeff2010 is offline
Joined Jan 2013
I have punched out all the pieces. One of the templates was missing so I had to fabricate 5 pieces myself. This is my first attempt at build a model out of balsa. I plan to start assembling next weekend.
Old Feb 03, 2013, 11:17 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Welcome Jeff!
Can you even get model airplane dope anymore?
What a lot of us use now is thinned epoxy.
And, there is an excellent new tutorial just put out by the AMA on fiberglassing as well:
Fiberglassing Tutorial (17 min 5 sec)
Kmot is online now Find More Posts by Kmot
Old Feb 04, 2013, 06:38 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Oh dear, resin and cyano with everything.
Basically a hard chine hull Jeff2010, heavyweight tissue and doping should be fine for the hull. P/M your e-mail and I'll forward the words and music from this side of the pond of how to do it.
Aliphatic resin (white) glue for the wood construction.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Feb 04, 2013, 01:47 PM
defranci is offline
Find More Posts by defranci
Central Ohio
Joined Feb 2003
Originally Posted by Kmot View Post
Welcome Jeff!
Nitrate dope is used as a wood sealer and also as an adhesive for attaching materials such as silkspan.
http://www.sigmfg.com/IndexText/SIGND001.html
Check out some of Pat Tritle's builds. He uses it often.
Don
defranci is offline Find More Posts by defranci
Old Feb 04, 2013, 01:49 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Old Feb 10, 2013, 07:32 PM
Jeff2010 is offline
Joined Jan 2013
Sterling Chris Craft. Progress. Started gluing
So still waiting on a response for the painting process. I need to know best way to varnish or clear mahogany pieces and sealing the balsa wood pieces. This will be a display model. No water.
Old Feb 10, 2013, 08:03 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Man you got ALOT done fast !
Old Feb 10, 2013, 08:51 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Hi Jeff, while waiting for responses you might go to this thread, there is an Enormous amount of info on similar builds, surely there is some helpfull stuff here:
Scroll down to post # 2, there are Many links to choose from.
Old Feb 10, 2013, 09:01 PM
Mike-A is offline
Find More Posts by Mike-A
Mike-A's Avatar
Sweden
Joined Oct 2002
Jeff you should also start a build thread. You have a nice piece of kit there... keep us informed of your progress!
Mike-A is offline Find More Posts by Mike-A
Discussion Revell Chris-craft sport fishing boat plans Brutustitan Micro and Sub-Micro Boats 1 Feb 23, 2013 03:12 PM
Video Chris Craft Monterey model built in 1954 Tim B. Dock Talk 0 Jan 09, 2013 02:35 PM
Discussion Dumas 1249 Chris craft model Chipper3333 Dock Talk 4 Jan 07, 2013 01:43 PM
Wanted Wanted Sterling boat kit 42' Chris Craft Corvette madkollector Boats (FS/W) 2 Dec 29, 2008 08:25 AM
For Sale Vintage Sterling Chris Craft 63' motor yacht model kit lefidler Boats (FS/W) 0 Jun 09, 2007 11:45 AM
