Old Feb 20, 2013, 05:30 AM
I Marauderer is offline
Find More Posts by I Marauderer
I Marauderer's Avatar
Powder Springs, GA
Joined Oct 2008
What Fizz said!! and your wheels are just fine.
I Marauderer is offline Find More Posts by I Marauderer
Old Feb 20, 2013, 10:41 PM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Description: last week when I saw Randy Bridge at the field and he had the fishing line switch deal. I thought it was kinda weird. Keep in mind it was my first time seeing Pylon Racers in person. So after seeing your pics Fizz, I thought it would look nice not having a switch mounted on the fuse.
Dale 813 is offline Find More Posts by Dale 813
Old Feb 21, 2013, 08:48 AM
Powder Springs, GA
Joined Oct 2008
It is really starting to come together dale.
Old Feb 21, 2013, 10:09 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Thanks Barry. Except for the fact that I need a new wheel. I droped a little CA on it and it pretty much destroyed it.
Old Feb 21, 2013, 10:20 AM
Powder Springs, GA
Joined Oct 2008
I don't use the ball bearing wheels but, spray a little CA release into the bearing and wait a bit and see if it frees up. If it does follow it up with a bit of alcohol and then oil. Dennis has great wheels and axles for about $12/pr.
Old Feb 21, 2013, 11:24 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
I put some CA debonder on it and it started eating the material. The wheels I have are that the wheel sits over the metal hub and it spins around the hub.
Old Feb 21, 2013, 11:32 AM
Powder Springs, GA
Joined Oct 2008
Ouch. Those are the $25 wheels with the ball bearings??
Old Feb 21, 2013, 12:19 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
No. I just talked to Dennis. The wheels I have ate the no Balls wheels. They are $15 a pair. I like them. But I need to keep the CA off em.
Old Feb 21, 2013, 01:04 PM
Powder Springs, GA
Joined Oct 2008
I understand. I got some locktite on mine and they didn't want to turn so I used a bit of light oil on them and they freed right up. I usually put a couple drops of fuel on them when i am fueling up for a heat and they run nice and smooth but, because they are bushing that only lasts one or two heats and if I land in the dirt I have to make sure they are cleaned and lubed before the next heat.
Old Mar 02, 2013, 09:09 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Description:
Old Mar 02, 2013, 09:12 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Description:
Old Mar 02, 2013, 09:18 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
This is my Ready to cover version that I bought. Unfortunately my other one took a Dirt Nap a couple weeks ago. Still not sure what happened. Started my turn around #1 when it didn't want to stop the left roll. It hit the ground so hard that I had to pull the engine out of the dirt. Well that engine has been test run on the bench and is now in this Plane and will maiden some time this week.
Old Mar 03, 2013, 06:33 AM
Powder Springs, GA
Joined Oct 2008
We look forward to a full report
Old Mar 05, 2013, 10:55 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Maiden flight this morning. Very nervous. Once I got er up. Didn't take much trim. Was flying around on half throttle for a minute and then I let her loose. Crazy Fast ! I think this one is faster than the last one. Flew two times. Blew the runway both times. Damn she glides. I'm pumped and can't wait to Race !
I want to thank all the guys that gave me tips and info. I appreciate all y'all.
Old Mar 05, 2013, 11:12 AM
Powder Springs, GA
Joined Oct 2008
We will see how fast on the weekend of the 15th. Do you have any of the $500/oz wax for your plane???
Sold Aeromod Aldij wing w/conventional style fuse sailplane LPU or AMA swap shop sarmoby Aircraft - Sailplanes (FS/W) 0 Jan 10, 2013 12:47 AM
Discussion Where can I get this MiG29? Uusitalo Foamy EDFs 0 Jan 07, 2013 12:15 PM
Question Where to get a small worm gear. Yellow Baron Flight Accessories 1 Jan 05, 2013 12:30 PM
Discussion Where to get a Q500 The Toolman Pylon Racing 1 Nov 25, 2007 12:30 PM
Discussion V-Tail, T-Tail, Conventional? Where to go? flying evader Electric Sailplanes 12 Sep 16, 2006 04:05 AM
