Old Feb 14, 2013, 10:20 PM
kbozarth is offline
Find More Posts by kbozarth
Joined Jun 2008
Glue your hatch on from here, don't screw it on. No modifying the muffler. No need to either, it works perfectly fine as is, same with head height.
Kurt
kbozarth is offline Find More Posts by kbozarth
Old Feb 14, 2013, 10:57 PM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
I took the motor apart to replace the bearing. The bearing that's in there has a plastic retainer on the prop side of the rear bearing. I left it in. I did not see a gasket or shim when I took the head off. I guess that's good or they are improving their design. Thanks Kbo. The hatch seems kinda dinky. I may replace it with ply as stated being done before and epoxy it down.
Dale 813 is offline Find More Posts by Dale 813
Old Feb 14, 2013, 11:11 PM
I Marauderer is offline
Find More Posts by I Marauderer
I Marauderer's Avatar
Powder Springs, GA
Joined Oct 2008
TTPro 40 Muffler. I went 4.5 yrs without having a problem with the mufflers. Last year I had one come apart during a race. I now take out the red rubber gasket and put it together with JB Weld and replace the threaded rod with a piece of 6/32 all thread and use two nuts on each end jammed and use red locktite.
I Marauderer is offline Find More Posts by I Marauderer
Old Feb 14, 2013, 11:34 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Very cool. Will JB weld mine tonight. CARB. On the Idle adjustment screw. Once loctite is on. Do I screw it in all the way and THEN back it out 2 turns or just screw it in 2 turns ?
Old Feb 15, 2013, 09:06 AM
fizzwater2 is offline
Find More Posts by fizzwater2
United States, KS, Overland Park
Joined Jun 2007
screw it in just far enough to stay in - not any further than you have to.
Landings will end up being dead stick, the engine will die when you shut the carb barrel.
fizzwater2 is offline Find More Posts by fizzwater2
Old Feb 15, 2013, 09:23 AM
Powder Springs, GA
Joined Oct 2008
Doesn't everyone land dead stick??
Old Feb 15, 2013, 10:10 AM
Joined Jun 2007
I guess landings don't always end up being deadstick, but deadsticks almost always end up being landings of some sort...
Old Feb 15, 2013, 10:27 AM
Powder Springs, GA
Joined Oct 2008
Good point!! I guess I have been doing this long enough that if I am not DS landing it just doesn't feel normal. Almost like I am cheating having the motor running to help me out.
Old Feb 15, 2013, 05:59 PM
ScorpionRacing is offline
Find More Posts by ScorpionRacing
NMPRA 86T
ScorpionRacing's Avatar
United States, FL, Winter Haven
You mean some guys put in more than enough fuel to run 11 laps?
Scott Smith - 86t
NMPRA District 7 VP
SEMPRA President
ScorpionRacing is offline Find More Posts by ScorpionRacing
Old Feb 15, 2013, 08:18 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Just got done fiberglassing the tail area. This is Fun !!
Old Feb 15, 2013, 08:31 PM
Joined Jun 2007
Just wait till your first close race....
Old Feb 16, 2013, 12:19 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Yeah. I'm pretty excited about the big race. I think I'll be a little overwhelmed. And a bit nervous. It's so soon. But I ll have fun
Old Feb 17, 2013, 12:34 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
What a sweet sounding motor. Broke in 5 tanks. With a APC 8x5. Last tank moved the needle to 16,000 rpm. Pinch went to 17,200-17,600. Now going to put it on the plane with the APC 9x6. Should I leave the needle alone ? Or give it a couple clicks lean ?
Old Feb 17, 2013, 02:35 PM
Powder Springs, GA
Joined Oct 2008
Back the needle out 1 full turn before starting the motor with the 9X6 and be ready to open it more. You want to be definitely rich when you start it and then slowly lean it out and pinch till you get it 5-600 rpm below peak. A good broken in motor is usually set to 3-500 rpm below peak before launching.
Old Feb 17, 2013, 07:33 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Will do. I ordered some plastic medical clamps (Hemostats) so I can pinch my fuel line.
Sold Aeromod Aldij wing w/conventional style fuse sailplane LPU or AMA swap shop sarmoby Aircraft - Sailplanes (FS/W) 0 Jan 10, 2013 01:47 AM
Discussion Where can I get this MiG29? Uusitalo Foamy EDFs 0 Jan 07, 2013 01:15 PM
Question Where to get a small worm gear. Yellow Baron Flight Accessories 1 Jan 05, 2013 01:30 PM
Discussion Where to get a Q500 The Toolman Pylon Racing 1 Nov 25, 2007 01:30 PM
Discussion V-Tail, T-Tail, Conventional? Where to go? flying evader Electric Sailplanes 12 Sep 16, 2006 05:05 AM
