Feb 13, 2013, 02:49 PM
Joined Jun 2007
Inside the fuse, mounted crosswise. I drill a 1/16" hole through the switch actuator, tie a piece of 45lb test braided catfish line to it, stick the ends out the sides (one each side).
Pull on one side and it's on, pull on the other side, and it's off. I set mine up like a few guys I fly with, pull the right side for on, left side for off - that way if they're launching an airplane for me, they don't turn it off accidentally!
I've had switches mounted with the actuator sticking out of the side of the plane actually get turned off in a mid air collision. The airplane wasn't broken after they bumped, but it sure wasn't flying... it got broken when it flew into the ground! Got there to pick up pieces, and the switch was in the off position..
