Old Feb 11, 2013, 11:47 AM
I Marauderer is offline
Find More Posts by I Marauderer
I Marauderer's Avatar
Powder Springs, GA
Joined Oct 2008
What Fitz said. I run Merlins and have run the 2002, 2002HD, 2003, and the globee style 216. Depending on the conditions of the day and the engine one of those plugs has always allowed my planes to be competitive.
I Marauderer is offline Find More Posts by I Marauderer
Old Feb 12, 2013, 05:55 AM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Originally Posted by kbozarth View Post
Put a smaller prop on it, or cut a 9x6 down to 8" and run it rich but at high rpms (16,500) on the bench for a few tanks. Pinch the fuel lines every once in a while to get a feel for how far you are off from peak. Then put an APC 9x6 on in and set it with a decent smoke trail. Do some climb/dives (giant egg shaped loops) to let the motor unload numerous times during the first few flights. Don't run it slobbering rich like they used to with ringed engines.
Kurt
What does the smaller prop do for the break in ? Just curious. I don't own a test stand. I will construct my own.
Dale 813 is offline Find More Posts by Dale 813
Old Feb 12, 2013, 06:15 AM
Powder Springs, GA
Joined Oct 2008
Lightens the load on the engine so it keeps the temps down and piston to cylinder wall wear in will be a bit slower and less chance of scoring a piston. Some feel that running the higher rpm will assist the motor in running at a higher rpm when you install the regular 9x6 apc sport prop on it. Maybe someone can explain it better
Old Feb 12, 2013, 10:03 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
I understand. Yep. Was just going to throw the motor on the plane but I want to do it right so asking tons of questions. You guys will hate me after a while. LOL Barry. I got the pics. Thank you.
Old Feb 12, 2013, 10:19 AM
Powder Springs, GA
Joined Oct 2008
Nah, we won't hate you ever. We want you to be a competitor. When you start betting me on a regular basis and are not humble about it then you will be irritating only. We need all the competitors we can get
Old Feb 12, 2013, 10:36 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Should I keep it stock for break in or do the mods first ?
Old Feb 12, 2013, 10:47 AM
fizzwater2 is offline
Find More Posts by fizzwater2
United States, KS, Overland Park
Joined Jun 2007
Mods? What sort of mods? Engines are supposed to be stock other than a few items... gaskets, etc.
Rear bearings are a common change - at least the earlier TTpro bearings had a stamped metal cage for the balls. At the RPM we're getting on the 9/6 props, the cages would fail and pieces would wreak havoc on the rest of the engine.
fizzwater2 is offline Find More Posts by fizzwater2
Old Feb 12, 2013, 11:10 AM
Powder Springs, GA
Joined Oct 2008
I would change the rear bearing and the carburetor spring removal. Don't forget to put a small piece of fuel tubing in to replace the spring so the barrel doesn't oscillate.
Old Feb 12, 2013, 11:14 AM
Joined Jun 2007
I think the carb spring removal is pretty common, even if it isn't mentioned in the rules. Either that, or I'm not looking in the right place.
I would recommend doing anything prior to break in. After all, you wouldn't want a premature bearing failure to ruin a perfectly good engine.
I've seen what happens when that original style bearing lets go - and it ain't pretty.. one of mine, and two or three others amongst other club members.
I have also heard that the newer engines may already have a plastic bearing retainer cage - but none of my engines were that new. If so, you shouldn't need to change it.
Old Feb 12, 2013, 11:20 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Yeah. The mods I was referring to was the spring, Bearing if needed an head shim removal.
Powder Springs, GA
Joined Oct 2008
If you are not sure on which rear bearing you have change it. I use rcbearings.com and the rear bearing in steel made by SKF is $6.62 + postage. Also you would really feel bad if your engine was breaking in really well and it ate the carb spring. If you are not sure of how to do it PM or email me and I will walk you through it.
Old Feb 12, 2013, 11:21 AM
Powder Springs, GA
Joined Oct 2008
I would not shim the head initially for breakin.
Old Feb 12, 2013, 11:24 AM
Joined Jun 2007
Ditto - I'd leave the head shim that comes in it, in it, during break in.
Those stock head shims are pretty thick - I've seen engines that will darn near let the piston hit the head if you simply remove it. You may have to replace it with thinner shims to get the head clearance you want.
Old Feb 12, 2013, 11:39 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Very cool. Well that's exactly what I'll do. I do the spring and bearing
Old Feb 12, 2013, 11:41 AM
Joined Jun 2007
While it might not be 100% necessary, I'll typically add extra castor oil to the fuel I'm using for breaking.
Sold Aeromod Aldij wing w/conventional style fuse sailplane LPU or AMA swap shop sarmoby Aircraft - Sailplanes (FS/W) 0 Jan 10, 2013 12:47 AM
Discussion Where can I get this MiG29? Uusitalo Foamy EDFs 0 Jan 07, 2013 12:15 PM
Question Where to get a small worm gear. Yellow Baron Flight Accessories 1 Jan 05, 2013 12:30 PM
Discussion Where to get a Q500 The Toolman Pylon Racing 1 Nov 25, 2007 12:30 PM
Discussion V-Tail, T-Tail, Conventional? Where to go? flying evader Electric Sailplanes 12 Sep 16, 2006 04:05 AM
