Old Feb 03, 2013, 04:39 PM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Got a couple Racing questions.
Gonna get a Q500 viper or Dominator 500. Will be my first. I guess I need to get a .40 ? Or what should I get ? A TTPro .40 or Jett engeneering ? Can I race with that set up
Dale 813 is offline Find More Posts by Dale 813
Old Feb 03, 2013, 08:24 PM
exf3bguy is offline
Find More Posts by exf3bguy
United States, CA, Sacramento
Joined Oct 2011
Find out what classes of Q-500 are being flown in your local area if you intend to compete and equip as per their format. If you don't care about competing and just want something fast get a Rossi .45, OS .46 or even Webra 50 with Nelson or Jett mufflers. Any of those engines would get you into the 140 mph range.
exf3bguy is offline Find More Posts by exf3bguy
Reply With Quote  (Disabled)
Old Feb 03, 2013, 10:35 PM
kbozarth is offline
Find More Posts by kbozarth
Joined Jun 2008
Get a TT .40 pro. Start in the AMA 424 class. Perfect way to start racing.
Kurt
kbozarth is offline Find More Posts by kbozarth
Old Feb 04, 2013, 07:32 AM
ScorpionRacing is offline
Find More Posts by ScorpionRacing
NMPRA 86T
ScorpionRacing's Avatar
United States, FL, Winter Haven
Hi Dale, and welcome to the racing addiction! If you are new to pylon racing, the Thunder Tiger PRO40 is the exclusive engine we race in 424 nationwide. They are very reliable and easy to set up & run. The Jett would be the next class up, and is quite a step up for a new guy to try to start with. I would suggest that you run at least a few 424 class races before you decide to move up. If you do decide to get a 426 engine (Jett), I would suggest that you just practice with it, and race the TT in 424.
The next race in our district is my event in Mulberry, Florida the third weekend of March. I would be glad to help you get started in racing, so let me know what you need. A few of us try to practice at least a couple of times a month at the field, and you can really learn a lot running in practice. Dennis O'Brien, Randy Bridge, Ray Brown and I are all members in Mulberry.
Scott Smith - 86t
NMPRA District 7 VP
SEMPRA President
ScorpionRacing is offline Find More Posts by ScorpionRacing
Old Feb 04, 2013, 06:27 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Thanks Scott. Wow. They sounds awesome. I fly at TRAC in Tampa. I think I'll get the great planes q500 viper and a TT Pro40. At this point. I guess I just wanna be able to beat the guys at my field against their ultra sticks. But competition sounds like fun. How fast will the viper & TT40 go ?
Old Feb 04, 2013, 07:43 PM
fizzwater2 is online now
Find More Posts by fizzwater2
United States, KS, Overland Park
Joined Jun 2007
There are some recommended reinforcements for the viper. I'm not sure what all of them are, someone here will surely be able to point you to a link with more info. They dont make it any faster, but do beef up a couple of weak points and make it last longer
fizzwater2 is online now Find More Posts by fizzwater2
Old Feb 04, 2013, 07:44 PM
NMPRA 86T
The viper & TT40 properly set-up to race with an APC 9x6 prop spinning 17K is around 115~125mph. If it is just speed you want, an APC 9x6.5 pylon prop would be your best bet, and a few mph faster. If you plan on running the engine at the higher rpm's, you will need to replace the rear bearing to ensure it stays together. Most guys replace the standard ones with the Boca Bearing HP bearings. If you want to set up a motor PM me, and I'll send you some information on all you need to do.
Scott Smith
NMPRA District 7 VP
SEMPRA President
Old Feb 04, 2013, 09:29 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
So would I assume right in saying that this Viper with a TT40Pro will beat a Ultra stick40 with a OS 55ax ?? In a race.
Old Feb 05, 2013, 08:07 AM
gsjames is offline
Find More Posts by gsjames
Gary James
gsjames's Avatar
Weatherford, TX
Joined Feb 2006
Dale: Here is the link to the Viper "improvement" thread. The airplane, as it comes in the box, has some areas that are structurally deficient.
http://www.rcuniverse.com/forum/m_7651229/tm.htm
gsjames is offline Find More Posts by gsjames
Old Feb 05, 2013, 08:40 AM
Joined Jun 2007
Thanks, Gary - I knew the info was out there somewhere.
Old Feb 10, 2013, 09:24 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Another question. Will be putting a new TT 40 pro on it. Aside from the manufactures break in procedures. Is there a special way you Pylon guys like to break these in ?
Old Feb 10, 2013, 10:05 PM
kbozarth is offline
Joined Jun 2008
Put a smaller prop on it, or cut a 9x6 down to 8" and run it rich but at high rpms (16,500) on the bench for a few tanks. Pinch the fuel lines every once in a while to get a feel for how far you are off from peak. Then put an APC 9x6 on in and set it with a decent smoke trail. Do some climb/dives (giant egg shaped loops) to let the motor unload numerous times during the first few flights. Don't run it slobbering rich like they used to with ringed engines.
Kurt
Old Feb 11, 2013, 04:21 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Kurt
Good stuff. Any certain type glow plugs or is stock fine ?
Old Feb 11, 2013, 10:22 AM
kbozarth is offline
Joined Jun 2008
Stock. I have tried many different ones over the years - the best ones are simply the ones that "work."
Kurt
Old Feb 11, 2013, 10:52 AM
Joined Jun 2007
I've had good luck with K&B 1L. You can get them from Mecoa still, but they're not as common in the hobby stores, etc, as they used to be.
I've heard the Merlin 2003 is pretty close, they'd be worth a try.
Reliable is best - you want a plug that lights well, always starts the engine, and finishes 10 laps reliably. That counts for a lot. You can't get points if you don't start and finish both..
Sold Aeromod Aldij wing w/conventional style fuse sailplane LPU or AMA swap shop sarmoby Aircraft - Sailplanes (FS/W) 0 Jan 10, 2013 12:47 AM
Discussion Where can I get this MiG29? Uusitalo Foamy EDFs 0 Jan 07, 2013 12:15 PM
Question Where to get a small worm gear. Yellow Baron Flight Accessories 1 Jan 05, 2013 12:30 PM
Discussion Where to get a Q500 The Toolman Pylon Racing 1 Nov 25, 2007 12:30 PM
Discussion V-Tail, T-Tail, Conventional? Where to go? flying evader Electric Sailplanes 12 Sep 16, 2006 04:05 AM
