Old Feb 03, 2013, 04:26 PM
BavarianCharles is offline
Find More Posts by BavarianCharles
Follow me to sink!
BavarianCharles's Avatar
85045
Joined Oct 2005
Simple Load Test for DLG Wing
I'd like to load-test DLG wings after joining the panels: Suspend the tips, add a weight to the panel joint - bag of BBs or equivalent - and wait a few seconds.
Does anyone have a simplified method or empirical data on how to calculate the required static load that would represent an inside looping at max lift, i.e. during launch rotation, disregarding loads generated by flutter, torsion, etc.?
BavarianCharles is offline Find More Posts by BavarianCharles
Old Feb 03, 2013, 04:40 PM
glidermang is offline
Find More Posts by glidermang
Charles:
Try this: 10 Gs for a 9-ounce airplane would represent roughly 90 ounces, or a bit more than 5 and a half pounds. Spread that load over the whole span, and that would probably be near the max load a wing would see. That would be my first-order estimate of the load, as a semi-retired and not-very-good aeronautical engineer.
For a "better" estimate, I would assume rotating through 90 degrees in one second, at a release velocity of 80 mph. Translate that into the acceleration towards the center of the arc, and that would be (since it is pretty near a symmetrical pull-up) pretty close to the G-load being pulled by the wing.
My two cents. I'm too tired to re-invent the math after all these years.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Feb 03, 2013, 05:47 PM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
I have some tabulated data from tests of various foam cores under bending loads. I never finished the testing because my testing apparatus broke and I had already gotten most of the information I wanted, but when I get home I can see about uploading it. The test was just to see how different core materials affected the bending strength of the wing.
As far as the maximum bending load that a DLG sees, if it comes out of the hand at 80mph (36m/s) and rotates upward with a turning radius of 7m, then the centripetal acceleration is a=v^2/r=36^2/7=182.7m/s^2. Newton's second law is F=ma, so for a 300g glider F=(.3kg)(182.7m/s^2)=54.8N. That load is distributed across the span of the wing, but we can approximate the bending load by assuming the load acts at the center of the wing panel. The maximum bending load at the root of the wing is then M=F*d=(54.8N)(.75m/2)=20.56N*m.
Now, we could analyze that much more accurately if we knew the exact lift distribution of the wing and the exact rotation radius and speed on launch, but that should be a reasonable 5-minute back-of-the-envelope type of calculation.
bwill6 is offline Find More Posts by bwill6
Old Feb 03, 2013, 05:48 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
You need to subtract the wing mass from the plane mass.
Gerald
G_T is offline Find More Posts by G_T
Old Feb 03, 2013, 07:00 PM
bwill6 is offline
Joined Jun 2011
Good point Gerald. That would reduce the bending moment to 12.3N*m. With another 3oz of ballast it would be 18.4N*m.
Old Feb 03, 2013, 07:15 PM
Follow me to sink!
85045
Joined Oct 2005
Thanks for the input - I'll assume a centripetal acceleration of app. 20g, and reduce the fueslage to a point-mass of 140 grams, for a net load of app. 28N, which approximates Greg's test load of 5 lb.
A lingering question remains: I'm not an areodynamical engineer, and realize that a wing can't generate more lift than it's capable of doing at a certain maximum angle of attack. However, if you dive the DLG, and then pull up sharply, is the path really an arc? Won't the plane retain significant downward momentum, so that the wings act as a speedbrake, with huge areodynamic loads that exceed lift by a substantial margin?
Old Feb 03, 2013, 07:39 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Charles,
If you're implying that the AoA of the airplane exceeds say ten degrees, then something has to make it increase to that level. I'm assuming that even if you violently pulled the elevator, the horizontal would likely stall trying to overcome inertia and create an AoA high enough that would damage the wing. I guess what I'm saying is that a control input has to be rapidly applied and the surface has to be able to continue creating force when it too is operating at a very high AoA.
Besides the force calculations above... we have to take into account whether or not the control inputs can cause that type of imbalance. I always roughly approximated 5lb as well and assumed it to be overkill.
tom43004 is offline Find More Posts by tom43004
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
The wings have a reasonably high L/D even when past stall AoA, so the lift is always the predominate load. That said, the resultant force is not perpendicular to the fuselage or wing bottom surface. When they load test homebuilts, they usually set the wing at stall AoA (upside down of course), and add load that approximates the lift distribution along the span. You might want the wing at 12 to 15 degrees AoA, so there is actually a load pulling the wings forward.
Stan Hall wrote some good articles for Soaring magazine in the 70's on doing load and flutter tests for homebuilt sailplanes. I might still have them somewhere.
http://esoaring.com/stan_hall_collected_works.htm
You can assume the lift distribution is elliptical, if you want to distribute the load, and be very close.
Wings can generate far higher max Cls when they are pitched up rapidly because the air doesn't separate into a stall immediately. I have some papers with max Cl increased by about 25% by rapid aircraft pitch rates or gust loads.
Kevin
Edit: Here is a good article on load testing wings:
http://lightaircraftassociation.co.u...%20Testing.pdf
kcaldwel is offline Find More Posts by kcaldwel
Old Feb 03, 2013, 09:50 PM
G_T is offline
G_T
G_T
Joined Apr 2009
Another point - we don't set up DLGs so that the elevator can pull enough to stall the wing in flight where there is otherwise sufficient airspeed. These are gliders after all... So, although the wing could produce higher lift coefficients than the normal stall lift coefficient, it wouldn't because there isn't enough elevator throw to get there.
Gerald
Old Feb 03, 2013, 10:19 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Charles,
Assuming that you are making the wing for yourself: Have you ever broken a wing? If not, then don't worry.
If you are worried about creases, that's another issue.
If you are worried about whether others might break it, let George, Charlie, Donnie, etc. throw it. If the break it, beef it up. If they don't, it's fine.
Some things can be over analyzed.
Gary
GaryO is offline Find More Posts by GaryO
Old Feb 04, 2013, 07:29 AM
Follow me to sink!
85045
Joined Oct 2005
Originally Posted by GaryO View Post
Charles,
Assuming that you are making the wing for yourself: Have you ever broken a wing? If not, then don't worry. Gary
To quote former Intel CEO Andy Grove: "Only the paranoid survive!"
As my wings get lighter, the chances increase for a failure under load, and some of us have seen a carbon stressed-skin structure fail catastrophically - kapow! Carbon don't wrinkle like Kevlar. The last set of full-carbon panels weigh 95 grams, and are stiff as planks, but are they strong? A failure, i.e. during launch, could put other pilots in jeopardy.
See you at the AZ Open!
Old Feb 04, 2013, 09:46 AM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
Gerald
With the low stability margins DLGs are usually flown with, sudden elevator commands could result in a high enough pitch rate to get to any AoA. And we have no control over the air, especially in the turbulent boundary layer next to the ground where DLGs have high speed on launch. Turbulence could increase the AoA to max Cl, especially during the pull-up when the glider is already at a positive Cl.
The energy will burn off a DLG quickly as it tried to generate high G, because the mass is so low. The time at a high G load will be very small, not the 3 seconds usually used.
The design G-load for turbulent air for airplanes with more mass is usually:
Gmax = (max air speed/stall speed)^2
So for a glider with a 20kph stall, and a throwing speed of 140 kph (38m/sec)
(140/20)^2 * 1.0 = 49g
Pick your numbers.
Fortunately, given the weight of a DLG, this probably isn't much of a design challenge.
Kevin
Old Feb 04, 2013, 10:40 AM
G_T is offline
G_T
G_T
Joined Apr 2009
Not really true, by simple geometry of a DLG.
Let's take a look at that 49g loop. a = rw^2. a is the acceleration. r is the radius. w is the angular velocity (in radians) reference to the center of the loop.
49g -> 480m/s^2 which is the acceleration.
r and w are related, by velocity. A circle has 2*pi radians. One radian along the circle is equal in distance to r (how a radian was defined IIRC). w = v / (2*pi*r).
So, a = r*(v/(2*pi*r))^2 = v^2 / ((2*pi)^2)*r). Solving for r, we get
r = v^2 / ((2*pi)^2 * a)
r = v^2 / 39.48*a ... approximately.
v is 38 m/s.
r = 1444m^2/s^2 / 39.48*480m/s^2 = 0.076m
Clearly we have a problem. Though the wing could theoretically generate the force at that velocity, it isn't going to be able to make a loop of 0.076m radius. Why? It has a horizontal tail. That tail isn't mounted roughly perpendicular to the wing, as in leading edge nearly straight down. That would be required for the horizontal tail to point its zero lift line into the appropriate direction for this radius loop.
Perhaps I made a little math or arithmatic error somewhere, but in any event this should show the point. A DLG can't pull that number of G's, primarily because it isn't fast enough for the resultant loop to be big enough to be geometrically consistent with the physical geometry of a DLG.
Gerald
Old Feb 04, 2013, 11:01 AM
belli is offline
Find More Posts by belli
United States, NY, Hastings-On-Hudson
Joined Aug 2007
Max launch height
If the Ev (J) at launch is 1/2mv^2(l) and this equals potential energy at launch height Ep (J) = mgh + 1/2mv^2(h), then:
h = ((v(l)^2 -v(h)^2)/2g
Assuming velocity at height is 2m/s and 38m/s launch you get 73.5 m height, with an average launch height of 60m this represents 82% efficiency, do you think this is possible? 82% Seems kind high to me?
Bellisimo
belli is offline Find More Posts by belli
Old Feb 04, 2013, 11:09 AM
G_T is offline
G_T
G_T
Joined Apr 2009
The drag coefficients are rather small at launch speed, and the duration of the climb is only a few seconds.
Gerald
Discussion What is considered high wing loading? jeff262 Fuel Plane Talk 38 Jan 28, 2013 06:43 PM
Discussion Motor heating up to 80+ deg C during no load tests Nereth Electric Motor Design and Construction 10 Jan 17, 2013 05:52 AM
Question Need Launch pre-set starting point for a Poly wing DLG hog2soar Hand Launch 4 Jan 09, 2013 05:16 PM
Discussion No Load Bench Test, Watts, Amps mybad Power Systems 6 Jan 03, 2013 07:15 PM
Discussion Simple layup for a wing DLG wing soholingo Hand Launch 16 Jul 03, 2007 08:52 AM
