Old Feb 03, 2013, 01:53 PM
Sirolf is offline
Find More Posts by Sirolf
Joined Aug 2011
Power issues
Hi guys,
don't know if this is the right place to be but i believe this is a CC issue.
First of my setup;
Trex 700E FBL
Castle ICE2 120HV with YGE cappack.
Align 700MX customwound 510kV YY-wind
Zippy 4000mAh 40C 2x 6S
I know it's not a problem with bad lipo's cause i have 4 sets and cannot believe
they all went bad from october till now storage charged.
That's why it's good to have some logs to see what is going on afterwards.
ESC is setup in setRPM at 2000rpm Idle1 and at a full pitch (+14/-14) climbout the rpm drops to 1550!!!
Last time it really had no problem what so ever.
I also tried FEP..no difference.
Tried 4.02, 3.27...nothing.
I'm suspecting the motor also..
If anyone who can read the log differently please chime in....!
One is with gov, the other on FEP. FW 3.27
Logs can be found on https://skydrive.live.com/?cid=8f365...PSAzWpn9BQA-0Y
CSV file pitch pumps 2 and 3 show the problem i'm having.
I have to add that i changed Auto-lipo to custom 36V.
Does this mean LVC is disabled?
With Auto-lipo on startup it only counts to 7 with a freshly charged pack!
I measured 49,7V on the connectors with a digi voltmeter when hooked up to
the ESC, but still only 7 beeps...WTH
Forgot to mention this...so that's why i suspect the 120HV
Sirolf is offline Find More Posts by Sirolf
Old Feb 03, 2013, 03:48 PM
Sirolf is offline
Joined Aug 2011
Okay... so i analysed the logs for some time now and previously when the heli flew fine
the logs showed when i demanded power from the system headspeed obviously dropped but Power Out increases.
Now it shows that on pitch pumps Power Out % drops in RELATION with rpm.
What gives..? Is this setup related somewhere, i never changed anything.
Old Feb 03, 2013, 04:34 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
That indicates you are hitting one of the limits and doing into soft cutoff mode.
If the battery voltage starts to get close to 36v it will start reducing power to try to keep voltage from hitting the LVC (36v).
If it’s not that:
1. Disable the current limiter
2. Set PWM to 12 KHz
3. Set timing to low
4. Set the LVC to 12v and time flights – that’s the way that I fly.
The only other limiter is the temperature limiter and you can’t change that.
RC Man is offline Find More Posts by RC Man
Old Feb 04, 2013, 04:41 AM
Sirolf is offline
Joined Aug 2011
Have you looked at the logs?
I'm not convinced it has something to do with a limiter but i take any advice on this matter.
Next time i have time for it will be friday so that's a bummer...
Current limiter is set at Insensitive, will disabling it make any difference in the long run?
PWM is and was at 12KHz, timing is at medium but will change that to low.
Maybe i did screw up with LVC or my pack are getting tired. So LVC to 12V will completely
disable any form of limiter? Other than draining the packs entirely.
I time all my flights, even on my nitro's.
Old Feb 09, 2013, 02:16 PM
Sirolf is offline
Joined Aug 2011
So i bought some new packs, set the LVC to 24V.
Did a few charge-discharge cycles on the charger and had all lipo's sit 4-5 days in the warmest room of the house.
Just 4 easy runs today including full pitch climbouts again on 4.02 gov.
No more drop in headspeed anymore.. new packs produces noticably more power; so.... damn... bad lipo's!
In the long run, how bad would it be to continue using the older lipo-packs this way?
See the logs of today: http://sdrv.ms/Y0E7xv
Old Feb 13, 2013, 05:12 PM
Old Sloppy is offline
Find More Posts by Old Sloppy
Harry from Atlanta, Ga.
Old Sloppy's Avatar
Buford, Georgia
Joined Sep 2006
It can cause a crash, Expensive Repairs.
Harry
Old Sloppy is offline Find More Posts by Old Sloppy
Old Feb 14, 2013, 10:16 AM
Sirolf is offline
Joined Aug 2011
Not if i auto it down.. servo's are powered by a separate 2S lipo.
Old Feb 14, 2013, 03:00 PM
Patrick del Castillo is offline
Find More Posts by Patrick del Castillo
Patrick del Castillo's Avatar
Olathe,KS,USA
Joined Oct 2000
One thing to be concerned about with bad Lipos is that they can fail unexpectedly. So you must be prepared for that.
Also, bad Lipos can be very hard on the input capacitors. It's good that you are running additional caps (YGE Cap pack) -- but still be aware that they can overheat when used with bad Lipos. If they overheat badly, they can fail suddenly -- and the ESC will overheat and possibly fail if the capacitors fail.
Thanx!
Patrick
Patrick del Castillo is offline Find More Posts by Patrick del Castillo
Old Feb 15, 2013, 06:33 AM
Sirolf is offline
Joined Aug 2011
I'll keep an eye on the logs.
Will get a second pack this spring and to some charging at the field from now on.
Help! LC Filter issue, PCB board issue. Pic included tymbo FPV Talk 2 Apr 06, 2013 11:56 AM
Discussion Power Issue on Trex 250. ESC??? stuka Power Systems 0 Jan 27, 2013 07:32 PM
Question First Kit build and I found an issue is it an issue? -S- The Builders Workshop 27 Jan 22, 2013 04:30 PM
Discussion Battery Issue...Reversed polarity? Charger Issue? Power supply issue? IDK ! Help!! H20up2 Batteries and Chargers 4 Jun 09, 2010 09:42 PM
Airliner weight & power issue SkynetAir Scale Kit/Scratch Built 17 May 22, 2003 09:53 AM
