Old Feb 03, 2013, 11:34 AM
kalnaren is offline
Find More Posts by kalnaren
Wasaga Beach, Ontario
Joined Aug 2007
Question
Current radio offerings
What are people using for aftermarket radios in tanks now?
I've decided to finally build up my PzKpfw III and I'm going to install an ElMod system, so likely I will need a new radio.
I have an Optic 6 Sport (72 Mhz) I use for RC Planes (that I don't get to fly anymore ) but I'm not sure about using it for the tanks, since it's technically only 5 controllable channels and 72 Mhz instead of 2.4 gig.
I was thinking of picking up a cheap radio like this: http://www3.towerhobbies.com/cgi-bin...?&I=LXARNY&P=0
Since I'm not going to use it for planes I'm not overly concerned about the quality, and a $200 computer radio seems a bit overkill for this application.
Any thoughts?
kalnaren is offline Find More Posts by kalnaren
Old Feb 03, 2013, 12:24 PM
Panther F is offline
Find More Posts by Panther F
Panther F's Avatar
United States
Joined Oct 2008
Not really a radio expert, but I would go with this
http://www3.towerhobbies.com/cgi-bin...?&I=LXXMV6&P=7
first before the "other" brand.
Also, a big FYI... 72Mhz is illegal for ground applications.
HTH
~ Jeff
Panther F is offline Find More Posts by Panther F
Old Feb 03, 2013, 12:58 PM
kalnaren is offline
Joined Aug 2007
HTH
~ Jeff
Thanks.
I wasn't sure about 72Mhz and ground applications.
Do you find 4 channels is enough for RC tanks?
Old Feb 03, 2013, 01:05 PM
Panther F's Avatar
United States
Joined Oct 2008
Yes, 4 channels are more than enough BUT, to make life simpler you may need to add fire buttons for the machine gun and the main gun instead of using the trim on the radio. Like I said, not a big radio expert so the 4 channel will work but more is always better... and more expensive as well.
Stay with a known brand. This is MY selection into 2.4GHz world.
HTH
~ Jeff
Old Feb 03, 2013, 01:39 PM
heavyg is offline
Find More Posts by heavyg
heavyg's Avatar
towcester uk
Joined Dec 2010
+1 I'm with jeff
heavyg is offline Find More Posts by heavyg
Old Feb 04, 2013, 07:11 AM
kalnaren is offline
Joined Aug 2007
Thanks for help guys
Old Feb 04, 2013, 01:15 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Think ahead, you can never have enough channels.
Another radio getting high marks is the Turnigy 9 for a good low buck option.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Feb 04, 2013, 02:55 PM
Panther F's Avatar
United States
Joined Oct 2008
Glacier Girl is right, if you plan on expanding the tank with more options... then get one with more channels.
But realistically, 4 is enough. As long as you don't have deep pockets. I'm getting the radio I showed next month, then ALL of my tanks will have one radio. Maybe 2 just in case.
And when I do so I will have a few radios to sell.
~ Jeff
Old Feb 05, 2013, 07:18 AM
kalnaren is offline
Joined Aug 2007
Wow, those turnigy radios are pretty cheap. Might work just fine for tanks.. especially if I want one per tank. I was shuddering at the though of having a $150 radio for each one.
Old Feb 05, 2013, 07:31 AM
Panther F's Avatar
United States
Joined Oct 2008
Spectrum also makes a radio that tankers are using in 2.4GHz.
Just another thought.
~ Jeff
Old Feb 05, 2013, 08:00 AM
kalnaren is offline
Joined Aug 2007
The Spektrum DX4 or DX5 was another on the "possible" list.
Old Feb 05, 2013, 08:07 AM
Panther F's Avatar
United States
Joined Oct 2008
I believe the DX6 is the one everyone enjoys the best.
~ Jeff
Old Feb 20, 2013, 08:17 PM
Comstock is offline
Find More Posts by Comstock
Fortress Fixer / Scale Addict
Comstock's Avatar
United States, NC, Huntersville
Joined Mar 2010
I switched from JR and Airtronics to the Hobbyking 4 and 6 ch for the smaller stuff and the new 9xr for the larger projects. Have had no problems whatsoever.
Comstock is offline Find More Posts by Comstock
Old Feb 21, 2013, 01:50 PM
Kamikaze Ace
USA, FL, Lakeland
Joined Jan 2010
Just finished up a 1/6th Stuart for a client, using the HK 9X. Piece of cake, once you figure out the programming of the tx. Had to dig through the internet to find a manual, as none comes with it. But nonetheless, it now controls the tracks, turret, gun elevation, lights, and gun firing. And still have two open channels for more goodies, like smoke and such.
Nice as it is, with software updates you can make the radio do even more. Not bad for a $60.00 tx, puts my DX6i to shame.
Old Feb 21, 2013, 01:51 PM
heavyg is offline
heavyg's Avatar
towcester uk
Joined Dec 2010
I've gone with a 6 channel 2.4ghz system, converted from a futuba t6x fm rig. Works a charm and no signal clashes
Discussion Electric flyers: How much current does your radio/ESC draw with switch off? Little-Acorn Radios 6 May 26, 2009 11:43 AM
Discussion CBA 10X Current Amplifier - Prototype, from West Mountain Radio RD Blakeslee Batteries and Chargers 29 Jun 10, 2008 01:29 AM
How much current can I get from Radio shack 8 cell 1600 mah Nimh The Other Dave Power Systems 4 May 02, 2008 03:25 PM
Question Multiplex radios' max safe charge current? nik112233 Hitec/Multiplex USA 3 Aug 28, 2006 01:05 PM
