Glue it on with E-6000 or Goop. Those glues stay flexible for a couple of decades. Just make sure you keep it away from EPS foam, as it'll melt them.
Also, as you move up to bigger planes like this you have to adjust your landing style a bit. That last 6" above the ground are critical- try to land as smooth as possible, wings level, and let it sliiiiide. |
Latest blog entry: F-20 update
Another look at the photos shows there appears to be very spotty application of epoxy? Almost like a large air gap was trying to be bridged with epoxy?
One single narrow plate along the span's length will receive the same leverage loads as without the plate, and will still be concentrated on a single point the diameter of the bolt head, which can still be pulled through the plate (depending on thickness) with a lot of extra weight with little strength gain. If the plate were oriented for-aft, the load would be further spread across the stab right were it matters most, at the root. Do NOT just add glue on top of glue again. Grind/sand off the top of that fin as flat/square as you can. |
Here's a different thought process:
Why glue on the tail in the first place?? Why not build a new tail, use some basswood across the span at the back of the stab (a pseudo-spar), and a 2" wide band of 1/64" plywood on top of that. Cover with your choice of covering, add your control horn, and then use some #12-24 nylon machine screws to anchor the tail on top of the fin on its seat??? Then, if you suffer a hard landing, you just replace the busted nylon screws. I apologize if this post comes across as "doling of unwanted online advice" or "needless criticism" as is indicated by some other folks here at RCG (atmosteve).... Its not, its just friendly, helpful advice designed to prevent you from having the same problem over and over. Buy a couple handfuls of the nylon machine crews so you have spares if you do this. They will need to be a bigger size than the metal ones that are there already to take the load, and to be safe, you should change them after every flying session. Best of luck to you! R, Target |
Latest blog entry: Stork 4 Pro X-tail from...
| Thread Tools | |
| Discussion Help, I need more thrust to keep my rc chuck glider in the air | aa35199 | Power Systems | 13 | Feb 03, 2013 12:51 PM |
| Discussion rubber band on prop saver keep breaks | modelerchina | 3D Foamies | 6 | Jan 25, 2013 07:38 PM |
| Discussion Tail belt keeps breaking on my Trex 450 SE | QuietRiot | Mini Helis | 5 | Feb 18, 2007 10:28 PM |
| Discussion Landing skids keep falling off my blade cp, how do you keep them on? | SteveCH | Micro Helis | 10 | Mar 13, 2006 12:15 PM |
| HELP!! I keep distroying tail booms on my Hummingbird. Best replacement? Thank you!! | Matthew Cotten | Micro Helis | 0 | Dec 11, 2004 09:42 AM |
