This thread is privately moderated by N827TM, who may elect to delete unwanted replies.
Old Feb 03, 2013, 11:08 AM
N827TM is offline
Find More Posts by N827TM
Trader Rating: 8
Mansell Models
N827TM's Avatar
United States, UT, Layton
Joined May 2004
Trader Rating: 8
Sold
Scorpion 3026-8 Motor
I am selling a this motor. I have had it for a couple of years and put some use on it. The motor runs great. It is in good condition, I just ran it yesterday. I am asking 40.00 shipped conus. Here are the specs:
Specifications
Stator Diameter ............................ 30.0 mm (1.181 in)
Stator Thickness ........................... 26.0 mm (1.024in)
No. of Stator Arms ................................................ 12
No. of Magnet Poles ............................................... 14
Motor Wind ............................................. 8 Turn Delta
Motor Wire ...................... 27-Strand 0.21mm (31 AWG)
Motor Kv ........................................... 1212 RPM / Volt
No-Load Current (Io) ................................. 3.45 Amps
Motor Resistance (Rm) ............................. 0.020 Ohms
Max Continuous Current ............................... 76 Amps
Max Continuous Power .............................. 1000 Watts
Weight ...................................... 189.3 Grams (6.68 oz)
Outside Diameter ......................... 37.50 mm (1.476 in)
Shaft Diameter .............................. 4.97 mm (0.197 in)
Body Length .................................. 43.9 mm (1.728 in)
Overall Shaft Length ....................... 82.5 mm (3.248 in)
Tom
N827TM is offline Find More Posts by N827TM
Old Feb 03, 2013, 02:14 PM
John.G is offline
Find More Posts by John.G
Trader Rating: 33
love to fly, hate to crash
John.G's Avatar
Fort Erie Ont. Canada
Joined Jan 2005
Trader Rating: 33
Nice motor, does it come with the prop mount. What size prop, battery did you run. I am looking for a motor in this size range but not as powerful but I maybe able to make it work. Thanks, John
John.G is offline Find More Posts by John.G
Old Feb 03, 2013, 03:38 PM
N827TM is offline
Trader Rating: 8
Mansell Models
N827TM's Avatar
Joined May 2004
Trader Rating: 8
John,
I was running 3s and 4s setups. The 3s setup was an 11X5.5 APC on 3s 5000mah. I was pulling around 54 amps. The 4s setup was a APC 10X5 on 4s 4000amp pulling 62 amps. This motor is a lot of power. It gave my 4.5 pound trainer unlimited vertical. Again it is a good running motor.
The motor shaft is 5mm. I do not have a prop adapter for it.
Tom
Old Feb 03, 2013, 05:57 PM
Wetcoast is offline
Find More Posts by Wetcoast
Trader Rating: 40
Vancouver, BC
Joined Jan 2004
Trader Rating: 40
I'll take it
If it is in as good a shape as you say. Than I'll take it for $40 shipped to WA.
Bearings good, shaft good no major bumbs or bruises?
Please PM me your Paypal info.
Cheers,
Wetcoast
Wetcoast is offline Find More Posts by Wetcoast
Old Feb 03, 2013, 06:55 PM
N827TM is offline
Trader Rating: 8
Mansell Models
N827TM's Avatar
Joined May 2004
Trader Rating: 8
Sold!
Sold Scorpion SII-3026-710KV blushless motor TKK Aircraft - Electric - Power Systems (FS/W) 1 Jan 27, 2013 06:17 PM
Sold Scorpion SII-3026-890 brushless motor innov8tiveTech Aircraft - Electric - Power Systems (FS/W) 0 Jan 03, 2013 01:02 PM
Sold Scorpion S-3026-8 motor with Commander 90 amp speed control chuck4816s Aircraft - Electric - Power Systems (FS/W) 0 Dec 01, 2011 05:02 PM
For Sale Scorpion S-3026-8 motor Prestigeauto Aircraft - Electric - Power Systems (FS/W) 1 Aug 10, 2010 11:24 AM
Sold Scorpion 3026-8 1212kv 1000 Watt Brushless Motor beeflyer2 Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2008 07:15 AM
