Old Feb 03, 2013, 06:14 AM
Cumulus2000 is offline
Find More Posts by Cumulus2000
Joined Aug 2006
My new Dual-Tri VTOL Platform with MWC
Hello I like to show you my new VTOL Platform it flies but i have still some Problems and i hope someone can help me.
The gyro board is based on Multiwii and I have the Code from Cass Version 1.8 on it.
How can i activate the servo stretch code? I have only a servo rotation of 90degrees and because of that the Yaw correction in hover mode works only on one side and the other side is limited by the 2000us.
And my big problem is the Yaw offset to make the torque correction in hovermode. I did it like this but now the servo jumps in transition.
servo[5] = constrain( 2730 - (lastRcData[AUX2] >> AUX2_DAMPENING) + YAW_DIRECTION * axisPID[YAW]/2 - rcCommand[PITCH]/5, 1020, 2000); } //front motor tilt (regular speed)
Cumulus2000 is offline Find More Posts by Cumulus2000
Old Feb 03, 2013, 06:44 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Welcome to RCgroups!
I myself am pretty new to using Cass's code so I may be wrong on some of these, but for moving the servo beyond 90 degrees I changed the endpoints in the radio and the code gave me about 5 percent more throw to get yaw in hover and get the two motors far enough for forward flight.
for the jumping servo in transition make sure you change the value in fast hover as well, I had the servo jump in transition too. We only changed the values in hover and forward flight, while fast hover was backwards. Changing all the values should help.
foam and tape is offline Find More Posts by foam and tape
Old Feb 03, 2013, 07:52 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
There is a place in the code to turn the servo stretching on. I'll be home in a few days and can look it ... up unless someone else can help sooner.
leadfeather is online now Find More Posts by leadfeather
Old Feb 04, 2013, 10:33 AM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Really like the hardware. Subscribed.
ilektron is offline Find More Posts by ilektron
Old Feb 06, 2013, 01:57 PM
Ran D. St. Clair is online now
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
Why not just max out the travel in the TX, and then if necessary, use longer servo arms?
Also, unless this thing is strapped to a wing of some sort, I don't see how it would fly with the forward motors rotated all the way forward. There would be nothing to provide any lift. I would think anything beyond about 45 degrees would be problematic.
Assuming that there is a wing involved, it would presumably need to have ailerons, because differential tilt on the rotors is going to be minimally effective when the front rotors are both rotated forward 90 degrees.
Ran D. St. Clair is online now Find More Posts by Ran D. St. Clair
Discussion New 450 Pro Dual Tail Slider (with metal links) half the cost of Align! PcChip Electric Heli Talk 5 Feb 12, 2013 09:37 PM
For Sale New FPV platform Skyhunter 1800 EPO RC4YFPV FPV Equipment (FS/W) 11 Jan 09, 2013 09:07 AM
Sold New Arizona Regulator. Dual Voltage with switch for heli kekiv Aircraft - Fuel - Helis (FS/W) 2 Jan 07, 2013 10:25 AM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 03:17 PM
