Old Feb 02, 2013, 10:39 PM
Razorback Flyer is offline
Find More Posts by Razorback Flyer
Razorback Flyer's Avatar
United States, AZ, Mesa
Joined May 2012
Question
645 MG Servos
Ok I was told that Im asking for trouble With the 645mg servos with a 5 cell NIMH battery, because when charged up, and when I get to the flying field, my voltages are around 6.75 volts. The Hitec specs are given for 4.8 and 6v. So am I over a safe voltage for these servos? Should I be running a BEC or like a BATshare unit?
Thx, Terry
Razorback Flyer is offline Find More Posts by Razorback Flyer
Old Feb 02, 2013, 11:54 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
The Hitec specs are given for 4.8 and 6v. So am I over a safe voltage for these servos? Should I be running a BEC or like a BATshare unit? Thx, Terry
"The Hitec specs are given for 4.8 and 6v."
= Nominal voltages of standard 4 and 5 cell NiMH/NiCD battery packs, refer:
. Servo - Operating Voltage Range - (Hitec) usage with NiMH, Lipol & A123 batteries.
A 5 cell NiMH battery could be a problem if high capacity AA cells above say 1500 MAh as they do not
withstand the current draw of several 645MG servo and become the frequent cause of jitters.
Users may resort to/ recommend a 5V 10A switchmode regulator to reduce voltage thus reduce the higher
current draw which their battery packs could not otherwise withstand.
The higher the voltage, the higher the current draw and faster wear & tear on the servo.
. Dual Batteries - Multiple Batteries may be installed for redundancy or even one for each servo.
Much more information available e.g.
. Servo - FAQ : Metal Gear Servos - DIY Repair & Extend MG Servo Gear Life
under sub sections
"Battery Care, Performance & DIY Battery Packs."
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Found hitec 645 mg servos helicopterdr Aircraft - General - Radio Equipment (FS/W) 0 Jan 13, 2013 04:15 PM
Wanted Hitec 645 mg cmebe4 Aircraft - General - Radio Equipment (FS/W) 2 Jan 08, 2013 11:32 PM
Sold Hitec MG Servos (2 x 645 MG/3 x 625MG) purcilas Aircraft - General - Radio Equipment (FS/W) 5 May 09, 2012 08:46 PM
Sold Hitec servo 4 x 645 mg, 1 x 5645 MG and 1 x 985 MG tiju000 Aircraft - General - Radio Equipment (FS/W) 1 Oct 22, 2010 12:31 AM
For Sale 4 servos hitec hs 645 mg Benji Aircraft - General - Radio Equipment (FS/W) 1 Oct 05, 2006 08:06 PM
