This thread is privately moderated by otlski, who may elect to delete unwanted replies.
Old Feb 02, 2013, 09:47 PM
otlski is offline
Find More Posts by otlski
checkout my Blog
otlski's Avatar
Joined Feb 2008
Bearings and cables
What happens when you model real bearings that have friction? Unlike the previous video where we used frictionless bearing pivots, this video will use commodity bearings which indeed do have friction. The result of which is when an outer frame or axis is rotationally disturbed, friction in the torque domain will transfer some of that rotation undesirably to the successive inner axes.
Angular with bearing friction (0 min 11 sec)
Thought exercises:
-more bearing friction means more undesired coupling
-more coupling means more unintended motion
-lower axis MOI means more unintended motion
-higher axis MOI means it is harder to command a purposeful axis slew
Bearing friction is a virtual given for the vast majority of gimbal configurations but it can be reasonably managed with proper selection and by design. Proper selection of cabling and the routing of that cabling is equally important. Cabling likely will increase the unwanted coupling between axes in a similar fashion that bearing friction does.
Lastly, attached is a zip folder with an Excel Spreadsheet that can be used to explore the relationships desribed in this post.
otlski is offline Find More Posts by otlski
For Sale GOPRO 3 Video Output cable with power cable kevinlib FPV Equipment (FS/W) 25 Jul 26, 2013 07:20 AM
Sold Ziroli F8F Bear Cat Kit Full RCSCALEGUY Aircraft - Fuel - Airplanes (FS/W) 2 Mar 01, 2013 08:09 PM
For Sale GOPRO 3 Video Output cable with power cable kevinlib Aircraft - Electric - Multirotor (FS/W) 17 Jan 25, 2013 11:19 AM
For Sale OPS .60 RE ABC New Bearings..... niteman Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 04, 2013 03:19 PM
For Sale Thunder Tiger Rare Bear rclou Aircraft - Fuel - Airplanes (FS/W) 0 Jan 03, 2013 09:51 AM
