Espritmodel.com Heli Air
Old Feb 20, 2013, 10:58 PM
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
check your props too, in video 19 i noticed the right mount vibrating a lot. You'll loose alot of power running an imbalanced system.
foam and tape is offline Find More Posts by foam and tape
Old Feb 21, 2013, 05:40 AM
NoT iNtElLiGeNt
India, Andhra Pradesh, Guntur
Joined Jan 2011
thank you.
what do u say about ailevon (aileron + elevator mix). will it helps in our situation.
should i opt flybar.
Originally Posted by leadfeather View Post
Forward flight looked good!
jyothibasu1k is offline Find More Posts by jyothibasu1k
Old Feb 21, 2013, 05:42 AM
NoT iNtElLiGeNt
Joined Jan 2011
yes your ri8.. both the throttles have been flushed away from the mounting at different time. so remounted them again correctly.
what do u suggest me to do now to get success...
Old Feb 21, 2013, 07:30 AM
Winging it Ò>
leadfeather's Avatar
Joined May 2006
Originally Posted by jyothibasu1k View Post
thank you.
Jyo, How much time do yo have left to complete this project. Back in the beginning of December you had told me that you only had 2 or 3 months for this project. Do you still have a deadline?
leadfeather is offline Find More Posts by leadfeather
Latest blog entry: Quick Stick
Old Feb 21, 2013, 09:08 AM
NoT iNtElLiGeNt
Joined Jan 2011
yes our project time ends by this feb month or maximum we can request for 1 week in march.
Old Feb 21, 2013, 09:22 AM
NoT iNtElLiGeNt
Joined Jan 2011
@foam and tape
should we use counter rotating propeller or CX blades.
Old Feb 21, 2013, 11:23 AM
Better use counter-rotating propellers. You can just about manage with equal handed propellers, but they will cause a lot of trouble in fine-tuning and cause some nasty handling effects.
Brandano is offline Find More Posts by Brandano
Old Feb 21, 2013, 04:48 PM
RCvertt's Avatar
Joined Aug 2007
I recommend GWS gyros or similar since I don't think you have enough time left to learn MultiWii.
I think your multiwii will have to have an accelerometer if you use one. If you want MultiWii then here is some code for you. It's for use with a ProMini arduino. I'm not sure which arduino pin to use for the motors but it's either digital 3, 10, 11, or 9. Plug your ESC signal wire into one of these until it works. This code has not been tested so you will have to do that.
At the top of the file you can change the delay of when hover or forward flight controls start here...
Code:
 int userHoverDelay =350;                  //QTR   350 is about three seconds.   Is is the amount of time to waite until hover controls work.
 int userForwardFlightDelay =350;          //QTR   350 is about three seconds.   Is is the amount of time to waite until forward fligt controls work.
You can change the motor and servo commands here... (Change a sign from + to - if you need to reverse the servo direction.
Code:
///////////////////////////QTR Motor and Servo commands./////////////////////////////
void hover()
      motor[0] = rcCommand[THROTTLE] -axisPID[ROLL];                                               //Left  Motor       Arduino Pin- 3, 10, 11, 9.
      motor[1] = rcCommand[THROTTLE] -axisPID[ROLL];                                               //Right Motor       Arduino Pin- 3, 10, 11, 9.
       servo[1] = constrain(1500 +axisPID[PITCH] +axisPID[YAW], 1020, 2000);                   //Left  Aileron     Arduino Pin- A0
       servo[2] = constrain(1500 +axisPID[PITCH] -axisPID[YAW], 1020, 2000);                   //Right Aileron     Arduino Pin- A1
       servo[3] = constrain(1500 +rcCommand[PITCH],                 1020, 2000);                   //Back  Elevator    Arduino Pin- A2
void forwardFlight()
      motor[0] = rcCommand[THROTTLE] +rcCommand[YAW];                                              //Left  Motor       Arduino Pin- 3, 10, 11, 9.
      motor[1] = rcCommand[THROTTLE] +rcCommand[YAW];                                              //Right Motor       Arduino Pin- 3, 10, 11, 9.
       servo[1] = constrain(1500 +rcCommand[ROLL],    1020, 2000);                                 //Left  Aileron     Arduino Pin- A0
       servo[2] = constrain(1500 -rcCommand[ROLL],    1020, 2000);                                 //Right Aileron     Arduino Pin- A1
       servo[3] = constrain(1500 +rcCommand[PITCH]+1, 1020, 2000);                                 //Back  Elevator    Arduino Pin- A2             (+1 for trim.)
RCvertt is offline Find More Posts by RCvertt
Old Feb 21, 2013, 09:45 PM
NoT iNtElLiGeNt
Joined Jan 2011
thanks for your concern.
wii how much time will it take to shipping in hobby king, last time it took around 15 days i hope so.
now i m thinking of this
http://www.hobbyking.com/hobbyking/s..._GYRO_ACC.html
what do u say.
Code:
Code:
void hover()
Old Feb 21, 2013, 09:46 PM
NoT iNtElLiGeNt
Joined Jan 2011
i am using counter prop only..... foam had used CX blades i hope so asking him a suggestion.
Old Feb 21, 2013, 11:18 PM
RCvertt's Avatar
Joined Aug 2007
...now i m thinking of this
what do u say.
I say bad.
It doesn't use the 328p chip so we don't know if the 1.7 code I posted is compatible.
Also none of these boards have the pins labeled. HobbyKing sells a 5v Nano that has all the pins clearly labeled. They also sell the motion plus gyro and nunchuck accel. They probably also sell a USB to miniUSB cable. I can't help with any of the "all in one" boards.
Old Feb 22, 2013, 12:22 AM
NoT iNtElLiGeNt
Joined Jan 2011
then what is ur advice ?
u said multi wii in ur previous post.
tell me clearly which is best and provide any web link of it so that i am not confused regarding their models.
I say bad.
Old Feb 22, 2013, 03:58 AM
Winging it Ò>
Joined May 2006
hi, i hope that i told you that i brought kk 2.1 multicopter board. its not kk1
i did not buy it, just borrowed from one of my frd.
i found vtol option in that programming option.
program was over and need to be tested
Jyo,
Do you still have this KK board available for your project?
Old Feb 22, 2013, 05:41 AM
NoT iNtElLiGeNt
Joined Jan 2011
its not working, so left it.
i will surely follow you, tell me what to do
what are my problems you have seen in the latest videos..
Jyo,
Old Feb 22, 2013, 05:42 AM
RCvertt's Avatar
Joined Aug 2007
then what is ur advice ?...
Sorry, meant Arduino Nano...
Arduino Nano board. http://hobbyking.com/hobbyking/store...ler_Board.html
Wii Nunchuk accelerometer. http://hobbyking.com/hobbyking/store...i_Nunchuk.html
Wii Motion Plus gyros. http://hobbyking.com/hobbyking/store...tion_Plus.html
...or better yet go with what LeadFeather says. I see that you have a dead line of 10 days left. Not enough time to build a MultiWii.
Idea Tilt Rotor Project rcjetflyer2 VTOLs 35 Feb 27, 2013 02:12 PM
Discussion EPP Tilt Wing Free Wing CNC wire cut/blade cx foamy freewing tiltrotorcoaxial Foamies (Scratchbuilt) 37 Feb 27, 2011 06:05 PM
Discussion Make the servo move 180 Degree useful for pan and tilt projects Talajouy Video Piloting (FPV/RPV) 2 Aug 11, 2010 05:13 AM
