Latest blog entry: Quick Stick
Jyo,
But he gave you the link,in post 94. I tell you that..if you d'ont have someone who help you with GUI and how to programm the wii board,it will be more difficult that really is now!If you allready know what is wii,please not consider that i wrote earlier. You could allways try,nothing is impossibile ![]()
India, Andhra Pradesh, Guntur
Joined Jan 2011
@ lead
the wing had broken due to yesterday's incident. now we are planning to make a new wing can u send me any new way of design. and one more thing is the servo is working but the copper rod we are using is not being able to force the wing over the fuselage in aero mode effectively. can u suggest any other material to be used in the place of copper rod that suits for servo connection |
As far as material for the push rod that connects the tilt servo to the wing, the most common choices are either strong stiff wire such as music wire (sometimes called piano wire). Another choice is carbon rod or tubing. If you don't have these choices for a push rod easily available, you may be able to use spokes from a bicycle. |
Joined Jan 2011
foam nd tape's design u have mailed me know.. but i am couldnot understand how to print that and cut. as it is A4 size containing all parts.
what glue is better for stciking of foam. Quote:
Joined Jan 2011
we have designed a new wing with increased stiffness and tested on another fuselage
as the Transmitter battery charge is about to complete we decided to test in Aero mode.. and it is successful on this model also
Forward flight looked good!
| Thread Tools | |
| Idea Tilt Rotor Project | rcjetflyer2 | VTOLs | 35 | Feb 27, 2013 02:12 PM |
| Discussion EPP Tilt Wing Free Wing CNC wire cut/blade cx foamy freewing | tiltrotorcoaxial | Foamies (Scratchbuilt) | 37 | Feb 27, 2011 06:05 PM |
| Discussion Make the servo move 180 Degree useful for pan and tilt projects | Talajouy | Video Piloting (FPV/RPV) | 2 | Aug 11, 2010 05:13 AM |
