Old Feb 07, 2013, 08:59 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Originally Posted by jyothibasu1k View Post
so only motors will be operated by kk board, but remaining servo's to be operated by receiver directly.
QUOTE=leadfeather;24061005]If you are building a quadcopter VTOL you can make it work for controlling the fan motors. The tilt servo and other control surface servos will need to be controlled directly from the Rx.
[/QUOTE]
The answer to your question depends which KK board you are referring to. The one you linked is quadcopter only. Other boards have more options. You may be able to re-flash the board you selected to control servos and operate a bicopter also.
This KK board has far more options than the board you linked earlier.
leadfeather is online now Find More Posts by leadfeather
Old Feb 07, 2013, 09:26 PM
jyothibasu1k is offline
Find More Posts by jyothibasu1k
NoT iNtElLiGeNt
India, Andhra Pradesh, Guntur
Joined Jan 2011
if u can see the two pic's there u can notice the spar across the fuselage.cg and pivot hing to that spar .
hope it gives a clarity to you where cg and pivot hing is
Originally Posted by matwelli View Post
looking side-on , not top down
looking side on , where is your CG in relation to the pivot point ? in the VERTICAL not horizontal plane
there needs to be seperation for control, and i think your vertical CG and pivot point are to close
jyothibasu1k is offline Find More Posts by jyothibasu1k
Old Feb 07, 2013, 09:36 PM
Winging it >
Joined May 2006
As stated earlier, the cg must line up with the center of the motors; not the pivot point of the wing.
In the hover configuration on your design, the center of the motors appear to be about 15mm ahead of the pivot point. The cg needs to line up with the center of the motors or about 15mm ahead of the pivot point. With the power off, just pick up the model by the motor shafts; adjust the balance until the model hangs level.
Old Feb 07, 2013, 09:38 PM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Yes. But how far down from the hinge point is the cg
I get that looking top-down its in the right place, but what is the vertical distance?
matwelli is offline Find More Posts by matwelli
Old Feb 07, 2013, 09:44 PM
Winging it >
Joined May 2006
The hinge point is not the issue at this time.
The center of thrust is in the middle of the fans. The cg must line up with the center of the fans during hover for this configuration. As you can see in the video they poste, every time they tried to lift off vertically it was very tail heavy...looks like they balance to the pivot point and not to the center of the fans
Old Feb 07, 2013, 09:56 PM
Ran D. St. Clair is offline
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
Jyothi,
I received your PM on how to use the KK1 board you bought. That is not the board I recommended. I gave you a direct link to the KK2 board, it is in still in this thread. The KK1 board you bought appears to be for quadcopters only. I have never used it so I can't say much about it except to read the manual here:
http://www.hobbyking.com/hobbyking/s...44X7478X19.pdf
You would still be better off buying the KK2 board. It has pre-programmed modes for a 2 rotor copter like what you are trying to do. It also has the ability to drive servo's like what you need. It also has a universal mixer capability that will allow you to control both of your motors and both of your two wing control surfaces in whatever manner you desire. It also has a direct on board user interface with buttons and an LCD display so you can access all of its capabilities without a computer or special software. Just plug it in, follow the instructions, and start playing with the parameters.
At this point it is not clear to me that you understand the basic physics of the situation you are dealing with. You need to find a local adviser. There is only so much help we can provide from the other side of the planet via a forum, especially if you don't take the advice you are being given.
Ran D. St. Clair is offline Find More Posts by Ran D. St. Clair
Old Feb 07, 2013, 10:10 PM
NoT iNtElLiGeNt
Joined Jan 2011
i have sent link to you, just to get a rough idea over it.
in the kk board i am using their is an option called VTOl.. so we selected it and made some program for it... should test it after a few hour's.
This KK board has far more options than the board you linked earlier.[/QUOTE]
Old Feb 07, 2013, 10:14 PM
NoT iNtElLiGeNt
Joined Jan 2011
these pics are for matwelli.... in order to get him where my cg is being operated... the wing used here is old one... we have replaced new one u can see that in the video's uploaded at starting of this thread.
the diff of wing to this pic and that video is
all are same but, the motor position is changed to the lower side of the wing.
a box type fitting under the wing for holding motor.
Old Feb 07, 2013, 10:15 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Yep. But if they have no vertical distance they will have no hope of pitch control in hover......
Old Feb 07, 2013, 10:17 PM
NoT iNtElLiGeNt
Joined Jan 2011
we lift the plane by catching on either side of spar rod and balance cg (pitch).
what do u mean by vertical distance
Old Feb 07, 2013, 10:19 PM
Winging it >
Joined May 2006
Not true... if they use the ailerons (flaps) for pitch control as advised, they will have good pitch authority regardless of vertical cg. However, no control scheme is going to work to control pitch in hover until the craft is no longer tail heavy in hover.
NoT iNtElLiGeNt
Joined Jan 2011
hi, i hope that i told you that i brought kk 2.1 multicopter board. its not kk1
i did not buy it, just borrowed from one of my frd.
i found vtol option in that programming option.
program was over and need to be tested
Originally Posted by Ran D. St. Clair View Post
Jyothi,
Old Feb 07, 2013, 10:22 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Yep . They sure will, good plan.
I hope that we can explain the principal behind the reason, will leave it to you
Old Feb 07, 2013, 10:38 PM
NoT iNtElLiGeNt
Joined Jan 2011
check this
Winging it >
Joined May 2006
The principal can be explained in two words "pitching moment". Just compare to how a flying wing aircraft controls pitch.
Idea Tilt Rotor Project rcjetflyer2 VTOLs 35 Feb 27, 2013 02:12 PM
Discussion EPP Tilt Wing Free Wing CNC wire cut/blade cx foamy freewing a9wr816t74 Foamies (Scratchbuilt) 37 Feb 27, 2011 06:05 PM
Discussion Make the servo move 180 Degree useful for pan and tilt projects Talajouy FPV Talk 2 Aug 11, 2010 05:13 AM
