The flybar is something I would have like to pursue, but I don't have access to a mchine shop. Here are the features I would incorporate into a flybar rotor if I could build one: 1) Adaptable to ordinary propellers. If a prop breaks, it can be replaced easily 2) Adjustable flybar angle for tuning the stability 3) Adjustable flybar weights 4) Easily replacable flybar arms...to try different lengths and for repairs 5) Easily mounted to common motor shafts
Latest blog entry: Quick Stick
Hi,
i seen that you need more help.So,first you have to decide what do you want to do with kk board!?Because vtol stuf is a litlle bit difficult but not impossibile,that because some comands really need to be inverted. If you want to make one plane like samson avatar,it will work but if you want to tilt forward more than 45°,aileron with rudder became inverted! ![]() For programing i use lazzy zero flash tool with good results. Cheers |
India, Andhra Pradesh, Guntur
Joined Jan 2011
we want to auto stabilize yaw,roll,pitch and 2 motor's.
we instantly at the beginning... don't know what to do and how to operate it Quote:
Can you link the exact KK board you purchased? Some version do quadcopter only; others can do many more configurations.
Joined Jan 2011
But remember for tilting you need some spare channel from rx and not more than 45° tilt!!! this is the board: http://hobbyking.com/hobbyking/store...rol_Board.html and one video with osprey twincopter firmware:
Or if you want,you could try to go only with gyros and mechanical mix,like this,but remaines only the problemm to translate from hovering to normal flight!: http://www.rcgroups.com/forums/showthread.php?t=1577718 enjoy.... ps:the simple way is like Leadfeather sayed to you,to use system like Foam&tape does used in his plane with Flybar!!!! http://www.rcgroups.com/forums/showthread.php?t=1319946 |
Joined Jan 2011
so only motors will be operated by kk board, but remaining servo's to be operated by receiver directly.
QUOTE=leadfeather;24061005]If you are building a quadcopter VTOL you can make it work for controlling the fan motors. The tilt servo and other control surface servos will need to be controlled directly from the Rx.[/QUOTE] |
| Thread Tools | |
| Idea Tilt Rotor Project | rcjetflyer2 | VTOLs | 35 | Feb 27, 2013 02:12 PM |
| Discussion EPP Tilt Wing Free Wing CNC wire cut/blade cx foamy freewing | tiltrotorcoaxial | Foamies (Scratchbuilt) | 37 | Feb 27, 2011 06:05 PM |
| Discussion Make the servo move 180 Degree useful for pan and tilt projects | Talajouy | Video Piloting (FPV/RPV) | 2 | Aug 11, 2010 05:13 AM |
