Old Feb 04, 2013, 07:30 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
As you asked me to in a PM, I've looked at the videos and think that all the comments above have the problems or potential problems covered.
I think I also see a need for a little more stiffness in the wing. It looks like a single layer of foam with a spar top and bottom. If you added KFm2 top strip from the leading edge to the spar and glued that where it rests on the spar and also at the leading edge, it will add a lot of stiffness to the wing. You could even do that top and bottom like the KFm4 wings and get more stiffness. If that stiffening was in line with the rod the wing pivots on and another short two or three layer section KFm2 or KFm4 section added across where the two wing panels are joined at the leading edge, it should improve the wing strength.
I don't think a stronger wing is going to fix all the issues here though and make that easier to fly. It was just something I noticed...
You've chosen a tough task, it will need some effort to work it all out. Good luck with it!
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 04, 2013, 08:29 AM
jyothibasu1k is offline
Find More Posts by jyothibasu1k
NoT iNtElLiGeNt
India, Andhra Pradesh, Guntur
Joined Jan 2011
i am using poly carbon sheet for doing this project, later i want to shift to foam. because due to fear that foam may break when crashed.
what do u suggest to use for stability FCB or Gyro
Jack
jyothibasu1k is offline Find More Posts by jyothibasu1k
Old Feb 04, 2013, 08:33 AM
NoT iNtElLiGeNt
Joined Jan 2011
to be frank i was moved to tilt wing after looking at that video. as you suggested ealirer that tilt rotor is the toughest of all VTOL category.
now tell me which option is better for me
to use flybar with some modifications or FCB or Gyro
Originally Posted by leadfeather View Post
Jyo,
Here is a video showing F&T's flybar stabilzed VTOL. I think this idea has some potential if the right stabilized rotors can be found. In his case, it look like F&T used rotors from a Blade CX helicopter which he modified quite a bit to get to work.
The flight of this plane does not look as stable as his later gyro stabilized craft, but with enough R&D it might be possible to get a good rotor designed and built for VTOL applications. AirHog did this on their toy VTOL.
Old Feb 04, 2013, 08:34 AM
NoT iNtElLiGeNt
Joined Jan 2011
what is differential flap can you tell me in detail
Originally Posted by bz1mcr View Post
Rudder can control yaw in normal flight, but in hover it is not effective at all. There is just no air flow over the rudder in hover. Yaw in hover must be controled by differential flap which is like aleiron.
Old Feb 04, 2013, 08:42 AM
Jack
USA, ME, Ellsworth
Joined May 2008
I have no experience with either a FCB or a Gyro, the guys that suggested it should be able to answer that I think.
Jack
Old Feb 04, 2013, 08:44 AM
NoT iNtElLiGeNt
Joined Jan 2011
okey..
Old Feb 04, 2013, 09:07 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Jyo,
I think you can reach your own conclusion for fcb or gyro if you think the whole control scheme through from hover to transition to forward flight and back. Once you really think it through and understand what has to happen the best answer will become evident.
Here is another suggestion that may be much easier for you to attain success with the limited time you have for this project. Would you consider making your craft short take off and landing (STOL)? The wing would go from about 45 tilt to forward. This way you should be able to proceed quickly without adding gyros or a fcb and no need for the yaw and roll control switch over.
leadfeather is online now Find More Posts by leadfeather
Old Feb 04, 2013, 09:22 AM
NoT iNtElLiGeNt
Joined Jan 2011
yes, i wanna maintain
VTOL, CTOL and STOL in my project if all comes together in my way
the title of our project is "Tilt Wing RC Aircraft "
any thing that is satisfying this project i am ready to do.
Jyo,
Old Feb 04, 2013, 10:02 PM
Ran D. St. Clair is online now
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
Jyothbasu1k,
I received your PM. Leadfeather is giving you some very good advice. Success with VTOL requires either years of trying, failing and learning, or if you want to be smart about it, start from an existing successful platform and evolve from there. You have started down a more difficult path with your existing platform. If you want to see more immediate success then start with a proven quad-copter or tri-copter configuration.
Your tilt wing 2 rotor platform is one that can certainly be made to work, but you have a lot to learn and a fair amount of money yet to spend if you insist on going down that path. Most people can't take all the failure between you and success if you go that way. Better to choose an easier path at first. .
I suggest you buy a KK2 board.
http://www.hobbyking.com/hobbyking/s...rol_Board.html
The price is reasonable and it has the flexibility to do most anything you could want. There are many other fine flight controller boards out there, but this one is more "plug and play" than most.
If you insist on this platform then I suggest you go back to basics Build your prototype with the wing fixed vertical first. Get the CG correct so the wing hangs perfectly vertical from the props. At that point the fuselage is just a place to put the radio gear and has nothing to do with flying. Elevons on the two control surfaces behind the propellers and differential thrust on the two motors is all you need for a fully controlled hover.
You will be able to fly such a craft forward slowly but if you ever get it into anything approaching forward flight you will have serious CG problems, as well as control problems. Come back when you get that far and we will help you from there.
Ran D. St. Clair is online now Find More Posts by Ran D. St. Clair
Old Feb 05, 2013, 12:27 AM
NoT iNtElLiGeNt
Joined Jan 2011
i have already tested CTOL with the similar wing on another fuselage
Test 3 (1 min 40 sec)
ya, i have to test fixed wing vertical take off
Originally Posted by Ran D. St. Clair View Post
Jyothbasu1k,
Old Feb 05, 2013, 02:44 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
one issue to look at, apart from everything above (including getting a KK2 board, because you really need it, and it will handle the mixing) is when in hover, how far is your vertical CG location from the pivot point of your pitch control ?
matwelli is offline Find More Posts by matwelli
Old Feb 05, 2013, 02:49 AM
NoT iNtElLiGeNt
Joined Jan 2011
under the pivot center.. i mean both at same line.
Old Feb 05, 2013, 02:54 AM
NoT iNtElLiGeNt
Joined Jan 2011
@lead feather, Ran, jacks
we are trying to work with flybar. the FCB/Gyro's are our last hope. i will be updating my trail results here..
Old Feb 05, 2013, 03:16 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
No . The vertical distance between the pivot point and your cog . You need distance in order to have control
Old Feb 05, 2013, 05:36 AM
NoT iNtElLiGeNt
Joined Jan 2011
i am unable to catch your point. how can i keep distance between pivot and cg.
if distance is kept then how can the fuselage hing to pivot and balance cg
Idea Tilt Rotor Project rcjetflyer2 VTOLs 35 Feb 27, 2013 02:12 PM
Discussion EPP Tilt Wing Free Wing CNC wire cut/blade cx foamy freewing a9wr816t74 Foamies (Scratchbuilt) 37 Feb 27, 2011 06:05 PM
Discussion Make the servo move 180 Degree useful for pan and tilt projects Talajouy FPV Talk 2 Aug 11, 2010 05:13 AM
