Old Feb 25, 2013, 12:42 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Originally Posted by jyothibasu1k View Post
what is FTDI basic programmer
and what about this as u said in previous post
" The (Arduino Nano Version 3) board does not have any sensors on it. You have to break open the Nintendo Wii Motion plus to use its gyros and the Nintendo Nunchuck for its accelerometer. You have to connect those to the Arduino Nano. "
if i get (Nano version 3) + (USB to Mini-USB) cable
only these 2 are enough for me. what about Nintendo & Nunchuck ?
i am confused, can you clarify my doubt.
You choose the hard way!
If you get arduino nano vers.3 and the usb cable,you have to buy also the stabilization units like this:
http://hobbyking.com/hobbyking/store...tion_Plus.html
and this:
http://hobbyking.com/hobbyking/store...i_Nunchuk.html
REMEMBER,this 2 items,you have to open it and solder wires to connect to the ARDUINO 3 board!!!!IT'S A DIY STUFF!!!!
@RcVertt,is not the simple way to buy one MWC LITE SE,v1,board instead of arduino 3 and wii+ and nchuk!?
Hope is help
If you had read the post above,leadfeather told you ,what is FTDI and how and who!?
Ftdi,is the programmer to buy by you,ONLY if you buy ARDUINO PRO MINI 5V!!!
If you buy arduino nano v3,is no need for FTDI ,because in the board,have botloader and the usb connector!!
Cheers
nadine is offline Find More Posts by nadine
Old Feb 25, 2013, 01:53 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Originally Posted by nadine View Post
...@RcVertt,is not the simple way to buy one MWC LITE SE,v1,board...
Yes. Too many of the same questions asked over and over again
If (MWC Lite SE, v1) has a 328p chip and has pins D2, D4, D5, D6, D7, D10, D11, A0, A1,A2 available then it should work. It will also need a mini-USB plug on the board. He will never figure out how to use a separate FTDI programmer in time. I think it also can't have the Uno bootloader on it. This is if he wants to use the code I posted.
So if that board has all that stuff on it then all he should need is a USB to Mini-USB cable.
RCvertt is offline Find More Posts by RCvertt
Old Feb 25, 2013, 08:23 AM
jyothibasu1k is offline
Find More Posts by jyothibasu1k
NoT iNtElLiGeNt
India, Andhra Pradesh, Guntur
Joined Jan 2011
now i got two options
1) got direct arduino board supported for multiwii software (but takes time it may be a more than a week) only code is to be changed in this model.
2) as u said to buy different things nd club them into one.
when i asked the shop keeper he said that the arduino board has usb itself (some version 8 )
if i get this then i need only nchuck, am i right ?
to be frank you guy's made me confuse alot. pardon me for being confused.
the shopkeeper asked me to send the list that i need, so one of you send me the proper things i need so that (if though i m not aware) he might know regarding it
now i am sending the following things, if i am wrong correct me
1) arduino board nano version 3 or (he said he have a usb in built arduino board)
2) wii motion plus (http://hobbyking.com/hobbyking/store...tion_Plus.html)
3) wii nchuck (http://hobbyking.com/hobbyking/store...i_Nunchuk.html)
i hope these are the three things i need.
jyothibasu1k is offline Find More Posts by jyothibasu1k
Old Feb 25, 2013, 08:25 AM
Dialfonzo is online now
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Small MultiWii arduino board.
Integrated Gyro and Accelerometer
http://www.rcgroups.com/forums/showthread.php?t=1764146
Dialfonzo is online now Find More Posts by Dialfonzo
Old Feb 25, 2013, 10:24 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Flite Test - Quadshot - REVIEW (14 min 52 sec)
Old Feb 25, 2013, 10:29 PM
Ran D. St. Clair is offline
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
Jyothi,
It is time to change direction. If you have a passion for VTOL, you have the rest of your life to figure it out. For now, since you are essentially out of time, you need to focus on getting the best grade you can for this project. That means you need to gather as much hard numerical data as possible. Thrust, vs. Power, vs. weight, etc. Put together some nice graphs. Analyze why it did't fly. Develop some free body diagrams to show thrust vectors, CG location, etc. Describe the details of the control modes, and do the math to determine maximum control forces in pitch, roll and yaw. Write up a good report, be humble about your failure, and learn as much as you can from it. You ask a lot of questions, and that is fine, but a lot of the answers are right in front of you.You just need to really think about what your experiences are trying to teach you.
Good luck.
Ran D. St. Clair is offline Find More Posts by Ran D. St. Clair
Old Feb 25, 2013, 11:20 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
...to be frank you guy's made me confuse alot. pardon me for being confused.
Sorry about the confusion. Language barrier makes it difficult.
To use my code, here is list for shopkeeper...
1) Arduino Nano Version 3.
2) Nintendo Wii Motion Plus
3) Nintendo Wii Nunchuck
4) USB to Mini USB cable.
But as Ran D. said, you are out of time. It takes a month to learn MultiWii for custom projects.
As Ran D. said, write up about why it needs gyro and accel stabilization. Write up the changes you made in order to get it to fly forward. Write up what changes you would make to a future build.
Old Feb 26, 2013, 05:57 AM
NoT iNtElLiGeNt
Joined Jan 2011
that was gud and warm support ran.
we already at the beganing decided to go further whether we fail or succeed.
sure we do as u said. we will continue after our colz also.(by now we got passion over RC's )
but at present i have time till march 10 2013, so i wanna work very hard to reach the success. if this time is really enough for me. if i keep 100% work effort.
Originally Posted by Ran D. St. Clair View Post
Jyothi,
Good luck.
Old Feb 26, 2013, 06:01 AM
NoT iNtElLiGeNt
Joined Jan 2011
now we are using kk black board v5.5, coded to VTOl. but facing problem in " how to connect board +Reciever + servo's".
i could not find any useful stuff in internet regarding connecting receiver and kk board.
if any one have an idea post proper pic/ pdf file or video
Old Feb 26, 2013, 07:46 AM
v22chap is online now
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
This looks like the manual to the KK v 5.5:
http://pdfdownloadfree.net/?pdfurl=1...pqep5fe2MyXqOI
and manual for flashing the micro chip ": down further on the page it has links to walk thru videos .... probably help a lot
http://pdfdownloadfree.net/?pdfurl=1...19fk0dnS2oiw6g
Here is a website for hook up of KK boards ..
http://www.kkmulticopter.kr/index.html?modea=manual
and another with a video
http://www.pyramidmodels.com/shop/pr...lackboard_v5_5
another
http://www.toymall99.com/kk-multicop...exacopter.html
here is a forum with a walk thru vid .. it said it was v5.5 but don't look like it ... but might learn something from them .
http://www.helifreak.com/showthread....18#post4751918
Hope these links all work and help !!!
v22chap is online now Find More Posts by v22chap
Old Feb 26, 2013, 07:53 AM
NoT iNtElLiGeNt
Joined Jan 2011
hi larry
the links u posted don't clarify my doubt. i have already checked a few hours back.
my doubt is " how to connect Rx to KK Black board" ?
another
Old Feb 26, 2013, 07:57 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It is clear in the manual linked
Bottom Left
Old Feb 26, 2013, 08:31 AM
NoT iNtElLiGeNt
Joined Jan 2011
we have connected in the same way. but now the problem is we could not find the mixing.
can you tell me how to know the mixing in a board. or can u guide me over coding of kk board.
Bottom Left
Old Feb 26, 2013, 08:32 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I know nearly nothing about KK boards.
Always use MultiWii ..
Old Feb 26, 2013, 08:50 AM
v22chap's Avatar
Joined Jan 2003
It is covered in the videos in the second link for flashing I provided ...
Flite Test - HK Quad Controller Programming - FLITE TIP (13 min 40 sec)
Idea Tilt Rotor Project rcjetflyer2 VTOLs 35 Feb 27, 2013 02:12 PM
Discussion EPP Tilt Wing Free Wing CNC wire cut/blade cx foamy freewing a9wr816t74 Foamies (Scratchbuilt) 37 Feb 27, 2011 06:05 PM
Discussion Make the servo move 180 Degree useful for pan and tilt projects Talajouy FPV Talk 2 Aug 11, 2010 05:13 AM
