Old Feb 02, 2013, 09:04 PM
jyothibasu1k is offline
Find More Posts by jyothibasu1k
NoT iNtElLiGeNt
India, Andhra Pradesh, Guntur
Joined Jan 2011
Tilt Wing Project
hi,
i am almost done and all setup is ready for tilt wing RC aircraft. but during hovering due to vibrations of the motor the propeller is oscillating. how to rectify it.
can any one help me
jyothibasu1k is offline Find More Posts by jyothibasu1k
Old Feb 02, 2013, 09:59 PM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
1) Make sure the props are balanced.
2) If the airframe structure is not stiff or strong enough it may cause vibration.
Best of luck!
leadfeather is offline Find More Posts by leadfeather
Old Feb 02, 2013, 10:42 PM
NoT iNtElLiGeNt
Joined Jan 2011
the two things which you told was okey. we have moderate stiffness in the wing frame. due to throttle vibrations the propeller is oscillating.
what to do now
Old Feb 02, 2013, 10:46 PM
Winging it >
Joined May 2006
what to do now
Can you post a video to help us understand what you are trying to describe?
Old Feb 02, 2013, 11:03 PM
NoT iNtElLiGeNt
Joined Jan 2011
sure, but i need time
Old Feb 03, 2013, 07:30 AM
NoT iNtElLiGeNt
Joined Jan 2011
here are the testing videos
Check 1 (0 min 29 sec)
Check 2 (1 min 5 sec)
Check 3 (1 min 20 sec)
Check 4 (1 min 18 sec)
Check 5 (1 min 50 sec)
Old Feb 03, 2013, 08:35 AM
Winging it >
Joined May 2006
I've watched the videos. Below are my observations and comments:
1) The vibration you mentioned in your first post is coming from (for the most part) ground effect. There is a lot of turbulance very near the ground and this will cause the craft to buffet and vibrate. In video #4, when the plane is being held higher off the ground it appears to be operating much smoother.
2) It appears you have no stabilization in any axis. I don't think you will have any success hovering without gyro assistance.
3) Your plane is very tail heavy in hover. The mass must balance in line with the thrust line of the propellers while in hover.
4) It appears you are using tilt to try to control pitch in hover. I think you will have much more control authority if you use the ailerons to control pitch as well as yaw in hover.
5) You vertical tail fins are tiny. You may find that your plane will not be stable in forward flight and will spiral left or right.
6) To transition to forward flight, the tilt should be slower or in 2 steps (1/2 tilt and then full tilt) to allow the wing to gain some forward speed to make the transition.
Good luck.
Old Feb 03, 2013, 10:56 AM
NoT iNtElLiGeNt
Joined Jan 2011
so the 1st point can be over come by changing the location/surfaces.
2nd can be over come by using a gyro... (can we over come with single gyro or it is manditory to use two)
Old Feb 03, 2013, 12:39 PM
Winging it >
Joined May 2006
On the first point, the vibration will greatly reduce once you are hovering a little higher.
On the 2nd point, yes a gyro can only controls one axis; you must use another gyro for each axis you want to stabilize (pitch axis, roll axis and yaw axis). You can also use a flight control board which will have 3 gyros included.
fixed wing flight control board
Old Feb 03, 2013, 03:04 PM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
I watched the videos and did not see or hear any indication of motor vibration or "oscillating". The motors appeared to be running smooth and consistant.
What I see appears to be a an unstable aircraft and a pilot who does not know how to control it. Unfortunately I have no experience with aircraft of this type, so I can not help much with proven experience.
However as an engineer and experienced RC pilot I offer these things to think about:
I would think the CG needs to be directly under the props during hover.
I would think you want the wing angle to be absolutly fixed (very securely locked) in a near vertical position. Control of pitch and forward or backward should be by "Flaps".
I would think you will need differential motor speed to level the wing in hover.
If you have opposite rotation props then yaw should been very minimum, but a small amont can be controlled with differential flap action. (like normal aleiron function when the wing is normal flying position.
One final thought....what you are trying to do is very difficult. It has been attempted many times. And, the results speak for themselves.
bz1mcr is offline Find More Posts by bz1mcr
Old Feb 03, 2013, 10:14 PM
NoT iNtElLiGeNt
Joined Jan 2011
i hope that, roll and pitch needs gyro.but the yaw can be controlled by rudder effectively with out a gryo. what do u say abt it.
Old Feb 03, 2013, 10:56 PM
Winging it >
Joined May 2006
You might be OK with out a gyro on yaw, but it would be easier to hover with yaw gyro. With your low level of flying experience I would reccomend the all three gyros.
If you used counter rotating props, yaw would be more inherently more stable while hovering.
One more thing to consider is that when you go from hover to forward flight, the yaw and roll control change. The ailerons control yaw (and pitch) in hover but control roll in forward flight. The motor speeds control roll in hover , but control yaw in forward flight.
It gets complicated in a hurry. That's why the flight control boards are a big help in making VTOL practical.
A simple "no gyro" approach might be to have flybar stabilized rotors. F&T had some success with this approach as did the AirHogs toy VTOL. The problem is that there doesn't seem to be any suitable, eaily available, readily adaptable flybar rotors for our VTOLS.
As I have told you in the emails; VTOL is one of the most difficult things you can do in RC. Realistically, with your limited experience and limited resources, your chances of success with VTOL in the near term aren't very good. I'm not trying to be pessimistic, but I don't want you to have false hope or expect success to be easy at all.
Old Feb 03, 2013, 11:59 PM
NoT iNtElLiGeNt
Joined Jan 2011
we are using counter rotating props.
as u said earlier that we need to increase rudder area.
what we did here is two small rudder area = one full large area.
(one large rudder is splited in to two half's)
we are not using rudder's here but instead we are using bank and yaw system
for changing yaw moment
Old Feb 04, 2013, 06:54 AM
Winging it >
Joined May 2006
Jyo,
Here is a video showing F&T's flybar stabilzed VTOL. I think this idea has some potential if the right stabilized rotors can be found. In his case, it look like F&T used rotors from a Blade CX helicopter which he modified quite a bit to get to work.
The flight of this plane does not look as stable as his later gyro stabilized craft, but with enough R&D it might be possible to get a good rotor designed and built for VTOL applications. AirHog did this on their toy VTOL.
Old Feb 04, 2013, 07:26 AM
bz1mcr is offline
AKA Don
Joined Dec 2002
Rudder can control yaw in normal flight, but in hover it is not effective at all. There is just no air flow over the rudder in hover. Yaw in hover must be controled by differential flap which is like aleiron.
Idea Tilt Rotor Project rcjetflyer2 VTOLs 35 Feb 27, 2013 02:12 PM
Discussion EPP Tilt Wing Free Wing CNC wire cut/blade cx foamy freewing a9wr816t74 Foamies (Scratchbuilt) 37 Feb 27, 2011 06:05 PM
Discussion Make the servo move 180 Degree useful for pan and tilt projects Talajouy FPV Talk 2 Aug 11, 2010 05:13 AM
