Old Feb 02, 2013, 08:47 PM
Froglube is offline
Find More Posts by Froglube
Froglube's Avatar
United Kingdom, England, Lancs
Joined Jul 2012
Build Log
Veron Skylark
Hi All
before I start teaching the youngest and eldest to make this 20" rubber job i thought Id better make it myself so here it is, put togetherer over a couple of nights.
as you can see very basic butI had some difficulty bending the 1/16 sheet over the front part of the ribs no matter how many clamps I used. I suspect I should have used softer sheet of soaked the leading edge or something. to allow somewhere for the tissue to stick too I added a couple of extra 1/16 cross members and moved one of the wing supports to its proper place after I'd eroneously stuck it between the two other formers rather than where the leading edge comes to rest with the wing on.
Anyhoo Its done now, will fit the motor and balence tomorrow as I'm pooped!
Its a bit heavier than intended as I covered the top wing partly to make it prettier but mainly to strenghthen it as i had rather over sanded it to get it to bend.
The motors 6 x 14 inch strands of 1/8 tan.
ATB
Tom
Froglube is offline Find More Posts by Froglube
Old Feb 03, 2013, 03:21 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Should be a great starter for the kids Tom, with potential to produce satisfying flights. It is great to see youngsters being encoursge to learn basic modelling skills - they will probably lose interest when "other attractions" rear their heads later, but hopefully in later years they will remember the fun they had, do some building and pass it on in turn.
Sundancer is offline Find More Posts by Sundancer
Old Feb 03, 2013, 06:14 AM
kkphantom is offline
Find More Posts by kkphantom
kkphantom's Avatar
Australia, WA, Perth
Joined Nov 2010
When trying to curl balsa sheet into an airfoil section, you can dope the underside and when that's dry, wet the top surface and it will curl naturally. Place a strip of balsa under the sheet to hold the curve and weigh down the edges. Leave to dry overnight and then dope the top. Works for me. Gary
kkphantom is offline Find More Posts by kkphantom
Old Feb 03, 2013, 01:38 PM
Froglube is offline
Froglube's Avatar
Joined Jul 2012
Cheers for that, will try when we get that far, been out all day today so not had a chance to settle down and start them off.
ATB
Tom
Discussion Skylark Auto Antenna Tracker(Skylark AAT/Trace OSD/Convert module review) skylarkfpv FPV Equipment 121 Apr 25, 2016 05:26 AM
Sold Skylark Tiny III OSD Kenny S FPV Equipment (FS/W) 4 Jan 28, 2013 12:26 PM
For Sale Skylark Tiny OSD & VAS 2G4 Helical hucker FPV Equipment (FS/W) 1 Jan 27, 2013 03:58 PM
Discussion Skylark AIO(All-in-1) OSD for 2013 discount skylarkfpv FPV Equipment 16 Jan 25, 2013 11:04 AM
Discussion Carl Goldberg Skylark 56 MARK II plans? Eddy Balsa Builders 6 Jan 22, 2013 08:58 PM
