Old Feb 02, 2013, 06:14 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
Contest
smallest submarine
well, because i found some nice items that fit together in my head, i decided to go for the smallest rc submarine. it might end up slightly longer than some of the super cheap toy ones that barely run, but it will be the smallest 3 channel dynamic diver built on the forums.
i started this whole thing when my wife gave me parts from a pen that broke. it had this lovely clear plastic tube on the outside that looked just like a miniature wtc tube! i did some measuring and found out that one of my new 3ch IR receivers could fit inside with a battery as well
so i am going to build the receiver kit and wind some more actuators. i might try a X tail on it, but i'm not sure yet.
once i get all the insides figured out, i will shorten the wtc tube to as small as i can make it.
today i tested how well it stays dry in the tub, as well as tested if the IR will work under water. both tests tell me it should work just fine indoors, so i will run with it.
the receiver i used in the pictures is a 2 channel differential thrust type. its meant for airplanes so it has no reverse, neither will the 3ch i have to build. i am considering adding thesteve converter to the motor output and using a servo board instead however. depends on how much room i have.
if anyone wants to try this, feel free to post in here.
links:
thread about the IR system: http://www.rcgroups.com/forums/showthread.php?t=1800107
the gentleman who makes the kits: http://www.rcgroups.com/forums/member.php?u=270360
his website (korean) http://www.drcmall.com/
derk is offline Find More Posts by derk
Old Feb 03, 2013, 11:01 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
Thats cool! I dont know hardly any thing about these but does the IR work under water?
I want to try a micro Sub ill look around in my work area if i cant throw one together.
chester2240 is offline Find More Posts by chester2240
Old Feb 03, 2013, 11:08 PM
derk is offline
derk's Avatar
Joined Dec 2003
i actually wasn't sure how well it would work which is what i tested once i had the water tight container working. for in the tub at the bottom of about 12" of water it worked just fine, so it should work in any indoor setting. once its done i will get some good video of it in action, hopefully something really cool. i'm building the receiver tonight, then all thats left is making the nose and tail shaped and the control surfaces.
Old Feb 03, 2013, 11:49 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Should be no problem sticking a couple of IR LED's underwater so you get 100% of the possible range vs losing some to surface reflection and stuff like that.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Feb 04, 2013, 12:47 AM
derk is offline
derk's Avatar
Joined Dec 2003
i don't think i will need to go to that extent. i will try another test, take a picture of active IR transmission through a fish tank and see if its going through. i wouldn't ever need much more travel than 12-24 inches anyway, the receiver wont go crazy if it loses signal like normal 72mhz or 75mhz can. i could also have the transmitter pointed into a pool and shoot a video from the bottom of the pool and see how much IR light it sees.
anyways, back to soldering
Old Feb 04, 2013, 09:59 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
A few years ago, I archived a German builders photo for inspiration.
Small sub...
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Feb 04, 2013, 10:54 PM
derk is offline
derk's Avatar
Joined Dec 2003
i have seen those ones in the past, and they were certainly tiny and complicated, my goal is pure size and not scale. mainly not scale because i stink at making things look like a real counterpart
but thanks for the motivation
still working out bugs with the receiver, hope to try another fix tonight and see if that fixes it.
Old Feb 05, 2013, 10:22 PM
tchalfant is online now
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
derk! that is really small! Great work there!
tchalfant is online now Find More Posts by tchalfant
Old Feb 05, 2013, 11:29 PM
derk is offline
derk's Avatar
Joined Dec 2003
thanks, i finally got the receiver to cooperate, so now on to all the fun parts!
i am hoping to keep this light enough to not need any flotation foam and just some keel weight to help her stay level.
Old Feb 06, 2013, 05:00 AM
wbnemo1 is offline
Find More Posts by wbnemo1
Registered loser :)
warm sunny(rainy, windy)Florida
Joined Jan 2005
subscribed! ....for obvious reasons
Will
wbnemo1 is offline Find More Posts by wbnemo1
Old Feb 06, 2013, 07:49 PM
crazygary is offline
Find More Posts by crazygary
crazygary
United States, CA, Clovis
Joined Aug 2011
Way cool, Derk!!
Following with great interest!!
Keep on keepin' on, bro'!!
crazygary is offline Find More Posts by crazygary
Old Feb 07, 2013, 10:43 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Nice
boredom.is.me is offline Find More Posts by boredom.is.me
Old Feb 19, 2013, 01:31 PM
wbnemo1 is offline
Registered loser :)
Joined Jan 2005
any more progress?
Old Feb 19, 2013, 07:36 PM
derk is offline
derk's Avatar
Joined Dec 2003
not lately, i have a deadline for some indoor flying events, so i have to push myself to work on them. though i did play around with using blue-tac for a small mold for the nose, just shaped it with a ball bearing and sized to the tube, then poured in some 30 minute epoxy. it worked well enough. i think when i do it for the real one, i will add micro balloons to help keep the density close to water's so its not using up buoyancy.
one thing i am concerned about is the very close proximity of the actuators, that they might interfere with each other. i might need to play around with centering magnets or small pieces of steel to help them stay independent.
so until i get more on the current list done, this is on standby. indoor flying is seasonal, the tub is always there lol
Old Mar 11, 2013, 09:45 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i keep tossing around this idea in my head, but a surface runner only of a ww2 fleet or type 7 boat, around 8 inches. there is this nice little water foutain at the mall.........
nemoskull is offline Find More Posts by nemoskull
For Sale Type 209/1200 submarine kits for sale bassplayer1 Boats (FS/W) 3 Oct 17, 2014 10:24 PM
Build Log 1/72 KILO,my second submarine ZL Zhang Submarines 15 Jan 22, 2013 09:44 PM
Question Neptune a Good First Submarine?? Gimpdiggity Submarines 13 Jan 20, 2013 01:38 AM
For Sale Mini DVR Global Smallest Sport Camera For FPV RC4YFPV FPV Equipment (FS/W) 6 Jan 13, 2013 07:22 AM
Discussion Neptune Submarine: KIT or not a KIT? mikethenerd2 Submarines 7 Jan 05, 2013 12:28 AM
