Old Feb 02, 2013, 02:42 PM
Joined Feb 2013
First timer , about to click Purchase on this cart. Your advice please.
I am about to build a quad from scratch. Here are the specs, I pretty much ripped off from some guy on the internet (http://www.stratus-productions.com/multirotors.htm).
Please let me know if you think I am missing anything - even if its screws or leads, or if I should replace anything. Thank you for checking this out!
HobbyKing
4x NTM Prop Drive Series 28-26A 1200kv / 250w = $59.80
1x Q450 Glass Fiber Quadcopter Frame 450mm - Integrated PCB Version = $11.99
4x NTM Prop Drive 28 Series Accessory Pack = $7.40
4x TURNIGY Plush 30amp Speed Controller = $48.76
1x Gyro / Flight Controller Mounting Pad (10pcs/bag) = $1.99
1x Turnigy 3000mAh 4S 40C Lipo Pack = $38.26
1x WireLabels - servo wire label heatshrink (14mm x 1m) = $0.79
1x Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK = $1.29
1x TURNIGY BESC Programming Card = $6.91
1x Nylon XT60 Connectors Male/Female (5 pairs) GENUINE = $3.19
1x 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) = $3.96
Spares:
2x M3x12mm Nylon Screws (10pcs/bag) = $1.86
1x 5.6mm x 15mm M3 Nylon Tapped Spacer (10pc) = $2.17
1x M3 Nylon Nut (10pcs/bag) = $0.69
Total: $218.85
Ebay:
NAZA Multirotor Stabilization Controller by DJI Innovations Quad-copter D-BUSQty: 1£119.99
iMax B6AC B6-AC Digital LCD Lipo Li-Po NiMh Li-ion 3S RC Battery Balance Charger With Tamiya Connector By Lujex
4 X JP APC Slow Flyer Prop 9x4.7 (LP09047SF) = £20
Total: ~$220
Final Total : ~ £300 / $470
I also have a solder, and a 10 year old 6Ch transmitter and receiver. ( I hope to god it is compatible).
My final aim is to have FPV, and a GoPro or something smaller. Is my setup balanced and powerful enough?
Thank you!
Edit> Thanks again for all your advice, I have added a battery, and male to male servo lead.
hamsterchaos is offline Find More Posts by hamsterchaos
Old Feb 03, 2013, 09:58 AM
Emress
sirbow2's Avatar
United States, IA, Elkhart
Joined Nov 2011
most people have better experience with 10in props on those motors. you need 20+ bullet connector pairs for esc-motor and esc-dist board connectors. dist board is a distrobution board which splits the batteryu + - to all the ESC + -. i dont see these two things. or you can direct solder between motor-esc-dist board, but repairs will be more anoying.
get atleast 2 batts, as it sucks waiting to charge. and get tons of props as you will break many. better to get more now rahter than waiting later.
also, could you please remove the item numbers and just have name of the product and quantity. very hard to read right now.
sirbow2 is offline Find More Posts by sirbow2
Old Feb 03, 2013, 01:37 PM
Joined Feb 2013
Hi - thanks for your help.
The frame - includes a board with it - see here:
http://www.hobbyking.com/hobbyking/s...B_Version.html
I have no idea what PCB means, but I am hoping that I can just direct solder the cables to it. So that means I dont need any bullet connectors.... right?
I will order another batt now.
I have updated the list with the final checkout. Can you recommend what props to get? Specially if I can get orange ones!
Old Feb 03, 2013, 02:16 PM
Emress
sirbow2's Avatar
Joined Nov 2011
oh, yep it does, you're good on that, then. you just solder onto the little gold pads seen here: http://www.hobbyking.com/hobbyking/s...og/24173-3.jpg
a PCB is a Printed circuit board. which basically means, they take a piece of material with a thin layer of copper on it, print a protective layer (printer ink works!) over where they want the copper to stay, and then dip it into acid. this "eats" the copper that didnt have the protection, and thus the leftover is lines of copper once the proctection is taken off. its like integrated wiring. see here for more: http://en.wikipedia.org/wiki/Printed...board#Hobbyist
props: you need two CCW and two CW props on your multirotor. each of the following packs has a two set of each.
http://www.hobbyking.com/hobbyking/s...on_Black_.html
http://www.hobbyking.com/hobbyking/s...on_Green_.html
so if you wanted to use green and black props for better orientation, take one cw and one ccw from a green bag and likewise for black. make sure you put the props on right and each motor is spinning the way its supposed to.
Old Feb 03, 2013, 02:42 PM
Dead trees fly fast!
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
I have to say, i have a better flying experience with 8inch props on those motors. Buy both as they are very cheap. You will use props up quickly
ecks is offline Find More Posts by ecks
Latest blog entry: Graphite ecks
Old Feb 03, 2013, 02:49 PM
Emress
sirbow2's Avatar
Joined Nov 2011
ah, yes, good that you mention that, 8in props on these motors will give you less total lifting power, BUT you will get a big increase in agility. that is why bigger props are most often used on AP.
Discussion First timer looking for advice on what plane to get. tpearson4750 Electric Plane Talk 22 Feb 08, 2013 08:22 PM
Discussion So you want to sell your design, Some advice before you post about it. MaydayMayday The Builders Workshop 24 Jan 20, 2013 08:05 AM
Discussion KF Swifty wing - need advice on powering this flying wing bbz Foamies (Scratchbuilt) 3 Jan 20, 2013 02:16 AM
Discussion Is a Sopwith Pup way to much for a first timer mts247 Balsa Builders 10 Jan 11, 2013 05:43 AM
Mini-HowTo Problems getting your refilled ink carts to work? Read on!! willin Life, The Universe, and Politics 5 Jul 19, 2006 05:39 AM
