Old Feb 02, 2013, 01:30 PM
SRWitt is offline
Find More Posts by SRWitt
Joined Jan 2011
Starts of an AS355 Build
I've been working on modeling an AS355 in CAD for the last couple of days, with the ultimate goal of building a fuselage plug to mold a fuse for my Blade 400.
Here's some screenshots of the progress so far. I need to work on the vertical stabilzers shape, right now its modeled as a flat piece with no contour.
SRWitt is offline Find More Posts by SRWitt
Old Feb 02, 2013, 05:39 PM
SRWitt is offline
Joined Jan 2011
Glass added into the windows and rendered.
Old Feb 02, 2013, 06:46 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Looks good so far. Make sure that you have enough room in the tail of that fuse to take the boom complete, less braces, with the ability to put the tail rotor shaft at least part way up the rear gearbox covering. Don't get the tail so small in the quest to keep it scale, that you can't get the mechanics inside it. Most 450 size fuses are oversized in the tail boom for that very reason and there is little chance on being able to change that in the near future. Also keep in mind the control rods for the tail pitch but those could be changed to Sullivan Goldenrods or plastic sleaves glued to the boom and the existing rod bent to bring it right up against the boom so that there is minimal increase in body boom diameter needed. Take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Feb 02, 2013, 10:42 PM
SRWitt is offline
Joined Jan 2011
Don
I've been thinking of the issues with the tail. I've got an idea in mind, but don't want to get to ambitious yet, Once I've got a rough model of my mechanics made I'll make the final decesions on the tail. Belt drives are easy enough to manipulate and I've got a nice carbon fiber sheet I made at work a couple years ago to play with.
Question First Kit build and I found an issue is it an issue? -S- The Builders Workshop 27 Jan 22, 2013 04:30 PM
Help! Wish to start an airliner build, but need your help abroadhurst94 RC Airliners (Commercial, Cargo, Troop Carrier) 75 Oct 17, 2012 02:28 PM
Discussion Build an autogyro using helicopter as donor-PROJECT STARTED JasonJ1969 Auto Gyros 27 Dec 10, 2009 05:43 PM
Discussion Start 'em young: Building an EPP chuck glider for your little copilot surfimp Slope 4 Nov 19, 2006 10:12 AM
