Old Feb 21, 2013, 04:22 PM
cpmcgraw is offline
Find More Posts by cpmcgraw
Experienced Balsa Mangler
United States, AL, Tillmans Corner
Joined Oct 2012
"Measure twice, cut once" has proven once again to be at the root of this problem. Also, "Never assume..."
I just checked the measurements of the dihedral braces I cut, and found them to be as much as 1/8" off in total length. When I was making the patterns, I thought (assumed) I had cut them according to the length and angle of the plan. I did...
Turns out, the plan was a bit off...
I'm creating a new set of patterns and I'm going to check them more carefully before cutting the actual parts. The old wing won't go to waste, though. I'll use it for a practice round when I start covering...
cpmcgraw is offline Find More Posts by cpmcgraw
Old Feb 21, 2013, 09:16 PM
cpmcgraw is offline
Joined Oct 2012
Day 20 -- New Wing Parts
Photo 1 shows my new "kit" of wing parts. I should be assembling it tomorrow...
Old Feb 22, 2013, 01:50 AM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Originally Posted by cpmcgraw View Post
I just checked the measurements of the dihedral braces I cut, and found them to be as much as 1/8" off in total length. When I was making the patterns, I thought (assumed) I had cut them according to the length and angle of the plan. I did... Turns out, the plan was a bit off......
At least you have the face-saving opportunity to point out that the inaccuracy was not wholly your own! Whereas my dihedral dilemma was caused purely by my own error...
I am impressed that you have decided to build another wing - I think that I would have either given up on the model (I can be a bit like that) or simply packed the wing mount such that when fitted, the wings had identical dihedral in relation to the fuz sides rather than the centre section....
Colonel Blink is offline Find More Posts by Colonel Blink
Old Feb 22, 2013, 05:37 AM
cpmcgraw is offline
Joined Oct 2012
Mine was a mistake I should have caught, but didn't. It was an ill-fitting collection of pieces from the start, and I should have paid attention.
As I may have mentioned, I have my eyes on attacking a KK Falcon soon. I need to bone up on these skills before mangling too much balsa on that bird. Rebuilding a one-piece 38" Mamselle wing is easy; trying to rebuild that two-piece 96" Falcon wing due to lack of diligence would be extremely painful!
Old Feb 22, 2013, 06:23 AM
JohnAV8R is online now
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Craig, youíre not alone. These things happen. I just set up a pylon mount for my wing platform. Got my square out, used an incidence meter, lined everything up the way I thought I wanted it, added the glue and left to let it dry. Came back the next day and did more work on the area. A week later Iím looking at the pylon from a different angle, itís not at 90, but maybe 85 degrees vertical. It some how got bumped before the glue dried. Bummer!
John
JohnAV8R is online now Find More Posts by JohnAV8R
Old Feb 22, 2013, 06:10 PM
cpmcgraw is offline
Joined Oct 2012
Day 21 -- New Wing
Now this wing feels better!
I'm taking a bit more time fitting the pieces, sanding a bit more, even taking the extra time to notch the TE. The tip pieces fit a little better, too.
Photo 1 shows the overall construction. The root rib was added (not original) and was cut from 1/8" balsa. It has not been glued in at this point, because I need to cut a new dihedral angle jig.
Photo 2 is an enlargement of the tip area. What little gapping there is remaining this time is easily filled with a bit of glue.
Old Feb 23, 2013, 07:56 AM
cpmcgraw is offline
Joined Oct 2012
Over in the Vintage & Old-Timer Plans PRE 1960 PLANS ONLY thread, Old_Pilot mentioned using "onion skin paper" in place of traditional tissue, and it turns out this is what I've been using as a plan protector all this time. It's tougher than tissue.
I'm going to try this out on that unusable Mamselle wing to see how it works. If it does, then this may be the route I take with both of these builds. It's certainly cheap enough (about $6 or $7 a roll, for at least 250' x 12").
Has anyone used acrylic paints over nitrate dope with success?
Old Feb 23, 2013, 08:09 AM
Joined Nov 2008
Looking forward to the report!
Old Feb 23, 2013, 01:28 PM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Yes, I've used artists acrylic paint over nitrate clear dope, admittedly only for smallish areas such as nose cowlings etc., and it works OK, no issues that I can detect.
Sundancer is online now Find More Posts by Sundancer
Old Feb 23, 2013, 01:43 PM
cpmcgraw is offline
Joined Oct 2012
Excellent! Finishing these birds gets easier and easier...
Old Feb 23, 2013, 04:16 PM
John38 is offline
Find More Posts by John38
Southampton, UK
Joined May 2007
Sundancer,
was that fuel proof - diesel and/or glo??
john
John38 is offline Find More Posts by John38
Old Feb 23, 2013, 04:45 PM
cpmcgraw is offline
Joined Oct 2012
Day 22 -- Wing, Continued
Another wing panel started, and yet another oops spotted in the plans. This may have already been noted, but it's another item that caught me off-guard the first time. The line drawings for the two halves are not symetrical. The plan-drawn port wing is almost another plane, it's so far off-kilter.
So, back to Inkscape for the correction -- flip the plan digitally left-to-right, then print the needed images to get a matching port half.
Aren't computers wonderful (when they work)???
Side note -- my browser (Chromium) crashed this morning after a late-night update session. Mind you, not only did the browser crash, it reboots the computer every time you try to run it! I had to switch over to Firefox to get out to the internet.
Photo 1 shows the new port half started. I had already assembled the tip pieces and the TE over the (normal) starboard image, then lifted and flipped them once the new plan image was ready. Things line up now...
Photo 2 shows an enlargement of the new plan, offering proof it was reversed...
Old Feb 23, 2013, 07:09 PM
cpmcgraw is offline
Joined Oct 2012
Quick note -- Fixed the issue with Chromium (unbranded Chrome browser). Installed Chrome (Google-branded version). So much for open-source...
The port wing is cooking nicely. Top spars should be installed this hour...
Old Feb 23, 2013, 09:35 PM
cpmcgraw is offline
Joined Oct 2012
The upper spars are now glued in and cooking. I'll leave everything overnight, then lift it and start sanding the edges. The starboard wing has already been rounded and looks good.
Photo 1 shows the progress...
Old Feb 23, 2013, 09:48 PM
kkphantom is offline
Find More Posts by kkphantom
kkphantom's Avatar
Australia, WA, Perth
Joined Nov 2010
Originally Posted by John38 View Post
Sundancer,
john
Artist's acrylics are water based and neither glow nor diesel proof. Automotive acrylics (spray cans) are diesel proof but not glow proof.
kkphantom is offline Find More Posts by kkphantom
Build Log Dart Kitten - Britplan Build Off January 2013 to June 2013 Colonel Blink Vintage & Old-Timer Designs 404 Mar 09, 2014 11:16 AM
Build Log The Travelling Tadpole - Britplan Build Off January 2013 to June 2013 Ian Dale Vintage & Old-Timer Designs 69 Jun 30, 2013 03:28 AM
Build Log "TV" Sparky (Aeromodeler 1951) - Britplan Build Off January 2013 to June 2013 hoffboy Vintage & Old-Timer Designs 11 Feb 11, 2013 11:25 AM
Discussion President (A.Hatfull) - Britplan Build Off January 2013 to June 2013 hobgoblin Vintage & Old-Timer Designs 12 Jan 18, 2013 12:54 PM
Discussion K. Edgerton "King Harry" BritPlan Build off January 2013 - June 2013 Doncrashum Vintage & Old-Timer Designs 4 Jan 14, 2013 05:30 PM
