Old Feb 05, 2013, 11:42 AM
cpmcgraw is online now
Find More Posts by cpmcgraw
Experienced Balsa Mangler
United States, AL, Tillmans Corner
Joined Oct 2012
Originally Posted by Sundancer View Post
I'm impressed that you are "multi-tasking" - this AND the Envoy!
Hehe, you should see the other project I started earlier. I'm working the plans up for a KK Falcon. Even have some balsa mangled for it. These two beauties are my "warm up" practices for starting the Falcon in earnest.
cpmcgraw is online now Find More Posts by cpmcgraw
Old Feb 05, 2013, 06:38 PM
Joined Oct 2012
Day 4 -- Progress Report
Photo 1 shows what "multi-tasking" is about -- The stabilizer plan on the board, and the Envoy just off to the left.
Notice the epoxy bottles. I had not used these in some time, and I'd forgotten how good the smell was...
Old Feb 06, 2013, 01:30 PM
Joined Oct 2012
Day 5 -- Tailplane Progress
Photo 1 -- We have ribs! Tip pieces to come.
Old Feb 06, 2013, 01:55 PM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
A man after my own heart - start with the tailplane, gives you that "1/3rd finished" glow!
Sundancer is offline Find More Posts by Sundancer
Old Feb 06, 2013, 03:32 PM
Joined Oct 2012
Day 5 -- Tailplane Progress (Page 2)
Photo 1 -- We now have tips. Hmnn... Ribs and tips... Strangely getting hungry...
Old Feb 06, 2013, 04:19 PM
Joined Oct 2012
Day 5 -- Tailplane Progress (Page 3)
Photo 1 shows the tailplane under construction. I'm following Smeed's 'split the middle' leading edge method. It wasn't all that difficult.
Sanding will bring the outline back into shape after the unit is finished. The ribs have to be cut into two sections (fore and aft) around the double rear spar. I also have to notch the bottoms of the spars to fit over the tip pieces. I like to build the tailplane as a one-piece unit first, then cut away the elevator. Keeps things aligned...
Old Feb 07, 2013, 10:13 AM
Joined Oct 2012
Day 6 -- Tailplane Progress
Photo 1 -- Added the ribs to the frame, reinforced the glue on a few joints last night. The rudder is being used as a spacer for the two added ribs.
Old Feb 07, 2013, 12:43 PM
mixer421 is offline
Find More Posts by mixer421
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
That's looking like a fine set of tail feathers but please tell me where I can buy those lovely T-bar pins.
mixer421 is offline Find More Posts by mixer421
Old Feb 07, 2013, 12:46 PM
Joined Oct 2012
DuBro Large (1 1/2") T-Pins
If your local hobby shop carries the DuBro line, they should have these or should be able to get them. They come in bags of 100 and are indispensable.
ADDENDUM: There are three sizes. I prefer the large ones, but there is a 1 1/4" and a 1", with smaller diameters.
Old Feb 07, 2013, 01:28 PM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Or http://www.slecuk.com/catalogue/Building-Aids.html
Colonel Blink is offline Find More Posts by Colonel Blink
Old Feb 07, 2013, 01:33 PM
mixer421 is offline
Agricultural flyer
mixer421's Avatar
Joined Aug 2007
Thanks CP, Found them on E-bay UK. Couldn't find a UK model shop that stocked them. Now the Colonel will tell me that there's dozens of 'em oop North!
Old Feb 07, 2013, 01:36 PM
mixer421 is offline
Agricultural flyer
mixer421's Avatar
Joined Aug 2007
I knew it! And Norwich is oop North from 'ere!
Old Feb 07, 2013, 03:09 PM
Joined Oct 2012
Photo 1 -- The tailplane has been removed from the board, and last-minute glue joints are being reinforced. A good sanding is in order...
The center section will receive a covering of 1/16" sheet balsa, with the center gap exposed for the rudder to fit into,,,
Old Feb 09, 2013, 08:28 PM
Joined Oct 2012
Day 8 -- Fiddly Bits
Not much done tonight, no photos. Managed to get the rudder fin drilled for Robart hinge points. Will have to reinforce the balsa somehow around those locations to prevent breakage.
Old Feb 10, 2013, 03:12 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Must be quite tricky getting hinge points into surfaces as thin as this. I tend to use mylar hinges pegged with cocktail sticks for these thin surfaces, they work well down to as thin as 3/32".
Build Log Dart Kitten - Britplan Build Off January 2013 to June 2013 Colonel Blink Vintage & Old-Timer Designs 404 Mar 09, 2014 11:16 AM
Build Log The Travelling Tadpole - Britplan Build Off January 2013 to June 2013 Ian Dale Vintage & Old-Timer Designs 69 Jun 30, 2013 03:28 AM
Build Log "TV" Sparky (Aeromodeler 1951) - Britplan Build Off January 2013 to June 2013 hoffboy Vintage & Old-Timer Designs 11 Feb 11, 2013 11:25 AM
Discussion President (A.Hatfull) - Britplan Build Off January 2013 to June 2013 hobgoblin Vintage & Old-Timer Designs 12 Jan 18, 2013 12:54 PM
Discussion K. Edgerton "King Harry" BritPlan Build off January 2013 - June 2013 Doncrashum Vintage & Old-Timer Designs 4 Jan 14, 2013 05:30 PM
