Old Feb 02, 2013, 12:46 PM
pirulin is offline
Find More Posts by pirulin
pirulin's Avatar
France, Aquitaine, Agen
Joined Mar 2009
Build Log
Parflyer built completely with Honeycomb under vacuum
hello,
For those who want to test ...I put a lot of pics about the building process.
That's the build log i post here :
http://www.rcgroups.com/forums/showthread.php?t=1790246
I do my best to explain it in English, ins't perfect but understandable (i hope),
I hope you'll enjoy it,
Best regards,
pirulin is offline Find More Posts by pirulin
Old Feb 03, 2013, 01:11 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Beautiful work! And as for your English, it's a LOT better than my French...
Shedofdread is offline Find More Posts by Shedofdread
Old Feb 03, 2013, 03:14 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Very nicely done! What was the final weight of just the airframe?
wyowindworks is offline Find More Posts by wyowindworks
Old Feb 04, 2013, 12:23 PM
pirulin is offline
pirulin's Avatar
Joined Mar 2009
Shedofdread :
Thank you for my English, but I'm sure there are many grammar mistakes and word errors, but if you can understand that’s the essential
Wyowindworks, your datas :
I prefer giving you detailed weights because of my errors in the final achievement and reinforcements choosen.
Weigths of the frame’s sandwich skins without before assembly (not glued half shells and accessories):
Wing 31.5gr
Fuselage and tail: 19.8 gr
Horizontal elevator : 6.3 gr
Frame Elements finished :
Wing (included former, spar, horns, ball joints, steel linkages and servo mount without servo): 44.3 gr
Fuselage, including bulkhead, rods linkage, ball joints horns, various reinforcements and battery mount (without geared motor and electronics and servos) : 39.9 gr
Elevator with hinge and clevis: 6.6 gr
So a total weigth frame : 90.8 gr.
I think we can do even more lighter, we can save at least 10 grams!...
As many of us, I always tend to put too much resin with micro balloons when I glued the half-shells (I like to do sturdy ... but at this scale each gram is really important), except for motor bulkhead, the formers are too heavy and strong. As regards the wing, I make same error as the fuselage, I put too much resin and micro balloons. Because the skins are really strong, the wing spar isn’t indispensable, on my next models I’ll replace it by studs which ensure the bottom and top surfaces linkage.
Per dmē this layup (Kevlar 36gr/mē + glass 25gr/mē+honeycomb 1.5mm+glass 25gr/mē gives :
Weight calculated to obtain an estimate before implementation: 2, 2 gr / dmē
Weight achieved with flat test specimen: 3,03 gr /dmē
Weight below are "out of the mold (per dmē)" the halfs parts achieved depending on the complexity of the shape:
For the wing: ~ 3.15 gr/dmē
For the fuselage: ~3.98 gr/dmē
For the elevator: ~ 2.86 gr /dmē
Reading that, you can deduct that the more the shape is complex the harder is to obtain a light frame weigth…
Regards,
Old Feb 11, 2013, 07:34 PM
eRaptor is offline
Find More Posts by eRaptor
Bloomington, IL
Joined Apr 2004
Wow.
That air frame is a work of art.
And, I learned something about the use of plasticine. Thanks for sharing your build.
eRaptor is offline Find More Posts by eRaptor
Old Feb 12, 2013, 01:04 PM
pirulin is offline
pirulin's Avatar
Joined Mar 2009
Originally Posted by eRaptor View Post
Wow.
Thanks a lot, it was a pleasure to share .
Have good flights and fun
Discussion What is a good multirotor under $800 for FPV with GoPro? X14Halo Multirotor Talk 1 Jan 12, 2013 11:33 AM
Sold Complete built ready to fly Slowstick with 4 channel radio! $85 + Shipping kctrading Aircraft - Electric - Airplanes (FS/W) 2 Apr 13, 2009 08:39 AM
Discussion JAZZ With "built-in" BEC under 6s LiPos ? 55-10-32 ? bmaaa Kontronik 5 Mar 01, 2006 11:37 AM
Has anyone built a pizza box flyer with an ips motor under 10in in wingspan? Mat Scratchbuilt Indoor and Micro Models 5 Sep 18, 2004 01:28 PM
For Sale Eco 8 built with mechanical mixer complete including radio karl51 Aircraft - Electric - Airplanes (FS/W) 3 Sep 12, 2003 06:11 AM
