Old Feb 02, 2013, 11:44 AM
Joined Nov 2011
try to setup 160HV
hi
i got 7HV
i buy 2 brand pulse battery( red series ) 65C 5000MAH
the first flight i down after 2 min to use only 50% battery first 5 flight
the flight was slow and easy
second flight i just take off and make for 1 sec high pitch to check power
and the castle 160 got cut , and after 2 sec power back
i got 3 more battery pack and its didn't happed to me b4
maybe cause its new battery ? but its still didn't happen to me too
cell are balance and good
I speak with the seller that was very nice
And with some extra cash he upgrade the battery to the green ones
Today i make the same first 5 flight on 50%
and i got same problem again
I cant belive that its the battery again what should i check
This the only brand 65c that i try in this configeration , i got tp 65 c that thay not new as pulse , maybe new battery drow more then my tp cause she new ? Maybe its the cc setting after all
Ask me anything , please help me ,
governor RPM
spool up 5
head speed change rate 14
governor gain 17
2106
2162
2253
ratio - 8.466
cutoff
3.0
corent limiting 200A ( just now see that and i have changed to 240A )
soft cutoff
motor
start power 59
timing 7
PWM 8 KHZ
V3.27
thanks
itay007 is offline Find More Posts by itay007
Old Feb 03, 2013, 10:02 AM
United States, MO, Springfield
Joined Jul 2010
sounds like the ESC is overheating
Elios000 is offline Find More Posts by Elios000
Old Feb 04, 2013, 12:57 AM
Joined Nov 2011
this is not heating
it can happens after less then 1 min
Old Feb 04, 2013, 09:11 PM
Joined Apr 2008
What error code you are getting?
chopper62 is offline Find More Posts by chopper62
Old Feb 05, 2013, 05:58 PM
United States, ND, Bismarck
Joined Mar 2012
Sounds like a bad solder joint from the motor to esc. It behaves that way when it loses a phase of the motor. Why don't you pull the data log and post it up here?
flint723 is offline Find More Posts by flint723
Discussion Which battery should I try first? highflyer38 Power Systems 3 Jan 28, 2013 07:13 PM
Discussion First try at creating a video from my AP rig. jbdww Aerial Photography 1 Jan 28, 2013 12:02 AM
Discussion Do not try this @ home gettinglucky Batteries and Chargers 7 Jan 15, 2013 06:44 PM
Discussion Castle 160HV vs Castle 160HV Lite keithtsr Power Systems 10 Aug 14, 2010 04:32 PM
Anyone try a low ratio GWS setup? Pierre Audette Power Systems 1 Feb 08, 2003 04:52 PM
