Old Mar 14, 2013, 05:24 PM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
This last kite is the best one so far.. rolls, loops, slow flight, hovers, it does it all well
davereap is offline Find More Posts by davereap
Old Mar 16, 2013, 04:26 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
From Israel Amos Etam has been making various lightweight models along the lines of the Kolibri, but much smaller...
I would suggest a read through the build instruction for the Kolibri will clarify a lot of what's going on here..
A good idea seen in pic 4 is the bumper bar
the amos bipe (1 min 22 sec)
Old Mar 16, 2013, 04:29 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Whist I don't have a detailed build log he was kind enough to send me some in build pictures which should give you enough ideas on the process
Old Mar 16, 2013, 04:31 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
more pictures
Old Mar 17, 2013, 04:24 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
some more pictures from amos..
no order but some info here on his processes
Old Mar 18, 2013, 02:33 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Thanks Dave very informative
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Mar 19, 2013, 03:44 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Amos at night...go to full screen for a better view
The Amos Bipe at night (0 min 24 sec)
Old Mar 19, 2013, 06:17 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
My microkite finally got filmed
Flown outside, because the indoor sessions are difficult for my headcam..
this shows the power of the 1811 motor..
slow flight can be nice and steady, and the first part of the video is all on 1/3 power.. sometimes less...but its also a little rocket at full power and more than fast enough at 1/2-3/4 power..
the basic framework will fly on the umx sukoi radio gear setup, but its a lot less agile
cf-aerobat (5 min 5 sec)
Old Mar 20, 2013, 04:20 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
here are more from Amos
indoors with a monoplane
Amos monoplane maiden (0 min 31 sec)
The Amos Bipe low & slow (0 min 25 sec)
In the hangar (0 min 12 sec)
Old Mar 24, 2013, 03:12 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
and another of short sections
PILOT TRAINING (0 min 21 sec)
Old Mar 24, 2013, 03:16 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
On the kite..
I had a slight problem on my elevon horns.. my choice had been to bind them as a 'vertical pegs' only to the hinge tube ... Usually they would be bound to the elevon bracing rod as and be L shaped..
The horns binding on one side came unstuck from the tube, and the elevon could go up and down with the horn staying upright.. a drop of CA fixed it back.. but it could have been flown if I hadn't noticed it with likely poor results..
I have no idea why this side had been lashed separately from the elevons bracing rod, the other side had a figure 8 lashing which went round both the horn and the rod, and that side cant then get loose..
A couple of loops of the thread will now be added to fix the lashings together on the faulty side
Old Mar 28, 2013, 05:45 PM
davereap is offline
davereap's Avatar
Joined Feb 2005
yet another indoor session.. and this kite is one of my two favourite models.. a 24" Imp being the other..
This kite can be flown slow and gentle yet it is fully aerobatic, hover ,rolls , loops , inverted all good
The Imp is more of a hooligans model.. I have great fun bouncing it off all the roof beams , the walls and the floor.. it also will do the lot..
Old Oct 13, 2013, 12:02 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
amos has been building more...here are his pictures...and his text..
Today I finished (?) my latest KISS project - somewhat larger mini vapor clone for my 14 years old grandchild.
I tried to save wt and made it from thinner carbon and usual kitchen cling film,
which is lighter than extra strong film I used before. With the rigging thread the rib less wing assumed a curved camber. Still waiting for a carbon prop and lighter battery to bring down the wt to 11 grams - the smaller Mini Vapor is 9 grams - still a long way to go.
Old Oct 23, 2013, 05:53 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Originally Posted by davereap View Post
NOTE.....CF rod constructions are proving to end up lighter than depron or epp build, which means good performance...and they are showing good damage reaistance..they bounce very well as I have found out..lol...
Their lightness is giving them the ability to fly very slowly....and thats not just high alpha flight ..thats flying properly...they also can fly fast because of their low drag, thin wings...
Whilst the film covering can get cut up in a mid air collision, the frame has taken that sort of punishment ok... and thats only using 2mm spars and and 1.5mm frame rods... the other guys prop disintegrated....my frame was fine....
The menace later went on to shred a mini vapor model....the CF there is just too small...
My flying buddy wanted a very easy flying model, suited to use the parts taken from the parkzone micro SU...
My easiest indoor flier is without doubt the Vapor, so the design was taken as the basis for my new model, but it is scaled up to use the more powerful motor from the Sukoi...
The basic Vapor flying at 18gms has 98sq" of horizontal area....
The Sukoi fies at 35gms..with 52sq" area
Other models are flying at 40+- gms, using SU guts, with no trouble..
So that sort of 40 gms AUW... is my target .. and to keep the wing loading low for a nice slow flier I needed to double its area or there abouts..
my first job was a sketchup design..
1.....a rough size job is easily done tracing over the image of the Vapor..
2....the model is resized... and given extra rods for a bit more strength at its larger size
Hi davereap.
What glue u use for attached plastic bags,or christmas gift paper to the wing,to whisper plane!?
nadine is offline Find More Posts by nadine
Old Oct 26, 2013, 10:20 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Dave , I thought you might like this carbon rod and film plane . Build instructions in this thread
http://www.rcgroups.com/forums/showthread.php?t=1158259
F-3-P Expert Ланцов Алексей (2 min 17 sec)
balsa or carbon is online now Find More Posts by balsa or carbon
Discussion Building Micro and Lightweight RC kites and models using CF Rods and fabric/film davereap RC Paragliders and Kites 47 May 04, 2014 11:11 PM
Sold DLG SHORT composite kit [including mylars and fabric] DLGjunkyard Aircraft - Sailplanes (FS/W) 0 Jan 21, 2013 03:07 PM
Discussion carbon rod indoor rc airplane plans lgliser Scratchbuilt Indoor and Micro Models 1 Dec 04, 2006 08:17 PM
Discussion Carbon Fiber Kite Push Rods Bob Cook Electric Sailplanes 4 Jul 27, 2006 09:05 AM
Hang-Em high Fabrics - excellent source for carbon rods Gary_Canada Vendor Talk 10 Mar 23, 2002 10:53 AM
