cool build, i did a similar model recently: http://www.rcgroups.com/forums/showthread.php?t=1789909
though i was not using sukhoi guts, i went for light weight everywhere i could (except maybe the covering as it needs to withstand some abuse now and then lol) AUW ended up right around 17-18 grams. its a good flying relaxing plane to fly. will you get some video for us to see yours in action? |
flying tonight...so hopefully some video...
glitches on vapor...one of the others at our indoor session has glitching... but I dont know what is the cause... I fly mine on a dx8 , and not had any problems.. what tx is yours on. Thanks Derk your model is just what I am looking for ...more to collect here so I hope you dont mind me reposting some info Derks model is based on.....Building the Kolibri light http://www.rcgroups.com/forums/showthread.php?t=183298 and here... http://litke.info/uPlanes/electrics/kolibri.html and this video link of derks model flying as well.
Ive got a Spektrum DX6i and an 8... both have been good... NOTE...the 6i has reported pot problems, which may be a pain , reported for certain production dates....but they are fixing those free as and when needed.. My flying buddy has just sent his back for repair
I love the dx8...the quality is fine... also got futaba ff6 ...9c...T10CP... and they are allways good, even when using the non futaba modules.. |
I'm using an Optic 6 with a FRsky 2.4 ghz module for my outdoor models and its very good makes my Spektrums look really poor. I've handled a DX6i and it didnt seem any better than the DX5. Briefly considered the DX7 but at that price I expect something better than the Optic which it isn't. Waiting for the FRsky transmitter to come out.
Terry |
Here is the Whisper maiden flight...
slower than expected. cruises at under half power, climbs on any more power.. nice and easy here.. later we run into a warped wing problem, and we are not sure if it was down to the cold in the hall , or getting a couple of knocks.. but it was enough to make the model have a strong right turn.. we also run into problems with push rods.. the rudder was pulling well with a lot of movement, but had reduced movement when it was pushing... Its possible that flex in the rod is giving trouble, in which case a pull pull setup solution would be better EDIT we sorted out the little niggles, by repositioning a push rod connector and adding 2 tension threads to each of the wings ..positioned on the leading and trailing edges out near the tips ..they go down to the UC legs, where they can slide down the legs to pull the wings all level..It means checking every now and again and adjusting as needed, fixing in position with a small bit of tape... I am still not sure what is making the wings warp that tiny bit, possibly its the cold in the hall.or impacts from my buddies hard landings....but the threads do the job...Its also possible that the joints , thread and CA , have a bit of give, so any hard knock will alter their setup just a touch... we are still puzzled.. The whisper has had a good solid mid air collision... with my flying buddy flying it, I managed to direct hit him with my r/ckite .. both models crashed to the floor from about 12 ft ..both were fine , they do bounce well.. After the collision the whisper was actually flying even better... so who knows...we did laugh.. . video .
That fellow is a good flier, but the model is a very delicate, light weight, depron build with CF stiffening, and it wont last him long.. In fact it has been damaged and completely rebuilt twice in 4 weeks... It got shredded the first week in a mid air, got squashed in transport another week and had impact cracks on another outing ...
The whisper is for a relaxed sedate flying session, or for fliers without the 3D skills... for that it it is doing well... and its CF structure is nicely durable, it bounces very well... What I am after with the CF structures is better durability combined with light weight... Idealy I want a slow flying but 3D capable model, one that goes as well as the white 3D'er, but one that bounces better... That is what I am hoping to get closer to with the all moving wing and control surface approach |
here is a video of the carbon traveler... its what I am trying to acheive, but I just want it in a smaller model... down at a 20" span
The 4 wing panels were put on, and Ive linked them so they work as pull pull with threads joining each pair at the front and rear , positioned at the root... so whatever way one moves the other will follow... I added some diagonal bracing to the wings for better strength...
Ive adjusted the tail plane shape so any push pull setup will not get in the way of movement..and lastly I fixed on a motor |
The gear is all on and working.. I went pullpull on everything so I have good large movements on all surfaces... In fact ive had to go to low-low rates to reduce the movements untill I get it trimmed and sorted... Ive added wheels out of depron , used 3x 5gm servos, a 12A esc , an orange rx with the box removed..
The motor on 2 cells has plenty of power for vertical or hovering, and draws 5-6A at full power.... All that is left is the plastic bag covering...and to get the final All up weight... |
| Thread Tools | |
| Discussion Building Micro and Lightweight RC kites and models using CF Rods and fabric/film | davereap | RC Kites | 37 | Mar 30, 2013 06:52 AM |
| Sold DLG SHORT composite kit [including mylars and fabric] | DLGjunkyard | Aircraft - Sailplanes (FS/W) | 0 | Jan 21, 2013 03:07 PM |
| Discussion carbon rod indoor rc airplane plans | lgliser | Indoor and Micro Models | 1 | Dec 04, 2006 08:17 PM |
| Discussion Carbon Fiber Kite Push Rods | Bob Cook | Electric Sailplanes | 4 | Jul 27, 2006 09:05 AM |
| Hang-Em high Fabrics - excellent source for carbon rods | Gary_Canada | Vendor Talk | 10 | Mar 23, 2002 10:53 AM |
