Old Feb 02, 2013, 03:54 AM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
Measuring IR of a LiPo
I am making a series of investigation into selecting the best pack for a project and buying alot.
Have been testing some brands using a method.
A friend pass a SkyRC i-Meter for me to paly around. It is a RC multi meter capable to do one thing i need - measuring the IR of the cell or a pack of cells.
But when measuring 1P vs 4P, the R is almost similar. Parallel the load, resistance is averaged over the 4 cells correct?
Is there a more accurate way to measure them? Some model of packs i have varies too much from the specification by mfg.
Also, during flight, i was collecting data on the max current consumed.
Do you trust the reading from a watt meter or an expensive Fluke current clamp meter?
prodriverex is offline Find More Posts by prodriverex
Old Feb 02, 2013, 04:44 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I have tried thinks like that in the past with mixed results. The only way that I have found to get a good consistent IR measurement is to do it as the pack charges like the Power Lab chargers do. If you are serious about LiPo’s you should own a Power Lab 6 or 8. With the optional PC interface you will get a graph of the IR of each cell as it charges. IR is dependent on the state of charge and cell temperature.
RC Man is offline Find More Posts by RC Man
Old Feb 02, 2013, 05:09 AM
The Engineer
Singapore
Joined Dec 2009
Yes I heard about PL8. I have Schulze charger and its has that IR function too but I'm not able to get it working. Maybe I need to add resistor to the bal cab connector.. will have to read up on that..
On another note, I have seen some tutorial video using light bulbs.. but those are running 12v. I'm on 6S..
Old Feb 02, 2013, 06:14 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
You might find these threads useful.
http://www.rcgroups.com/forums/showthread.php?t=1323465
http://www.rcgroups.com/forums/showthread.php?t=1577989
Of the chargers I and a couple of others who are interested in IR have tested, the iChargers and the Hyperions with the latest firmware give very close agreement with an ESR/IR meter and each other, my PL8 is pretty close but tends to give slightly lower values. It is increasingly inaccurate on poorer quality (high IR) packs. Sorry, haven't any data on a Shulze.
The various cheap meters with IR measurement functionality from HobbyKing and others that use only a two wire method (ie only the main battery leads) are a waste of time and money - at least as IR meters.
John
jj604 is online now Find More Posts by jj604
Old Feb 02, 2013, 07:56 AM
reptileman is offline
Find More Posts by reptileman
nj
Joined Jan 2004
John
so would a iCharger 106B+ be worth getting just for the IR feature because all of my other chargers do not have a IR function or is there something better?
reptileman is offline Find More Posts by reptileman
Old Feb 02, 2013, 10:17 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
The 106B+ is fantastic for measuring internal resistance and I keep one of mine in my field kit at all times to help out guys at the field to test their batteries and help them determine a safe maximum current draw.
If you only plan to use the IR function and do not plan to use the 106B+ for charging, Wayne Giles' ESR Meter would be better if you have high performance, high capacity (5000mAh or larger) packs. Wayne's ESR Meter has .04mOhm resolution whereas the 106B+ has 1mOhm resolution. I've found the 106B+ to be perfect for assessing 2500mAh and smaller packs and will bust out my ESR Meter to resolve subtle differences in my larger packs.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 02, 2013, 11:11 AM
nj
Joined Jan 2004
Mark
Hi i have larger rc packs 3000 to 5400MAH i did look at that ESR meter but it states a limit to 5000MAH capacity does the I charger have a limit also?
Old Feb 02, 2013, 11:30 AM
So. Cal.
Neither have a theoretical capacity limit on measuring IR. They do have practical limits however. Since high quality 5000mAh cell have IR in the 1mOhm range, resolving an accurate and repeatable measurement can be tricky. That said, there is no better instrument on the planet for measuring IR in this low range than Wayne's ESR Meter.
Mark
Old Feb 02, 2013, 11:35 AM
nj
Joined Jan 2004
Mark
Hi then why does it state it good for up to 5000MAH capacity in the info on it?
Old Feb 02, 2013, 12:48 PM
So. Cal.
Wayne's thread actually states up to 6000mAh but I'm quite certain that this is simply due to the fact that high performance lipoly cells larger than this typically have IR that is on the threshold of repeatable measurement.
He will have to corroborate this. I've sent him a message.
Mark
Old Feb 02, 2013, 01:19 PM
Wayne Giles is online now
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Hi,
The 5000maH limit is historical because when I first designed the meter,that was the largest lipo available. The unit will measure up to any size but the meauring pulse of 16A was designed to be large enough to load a large cell but not so large at it would damage the smallest cell.
If you are looking at large cells where the IR is likely to be down around 1 - 2 milliohms then the meter is ideal because of it's high resolution of 0.04milliohms.
The other advantage of the meter is that it takes instant readings without going through any charging cycle which can introduce errors due to temperature changes.
On the other hand it is absolutely useless at charging batteries!!
If you want any more details send me a PM?
Wayne
Wayne Giles is online now Find More Posts by Wayne Giles
Old Feb 02, 2013, 01:27 PM
kcobra is offline
Find More Posts by kcobra
Joined Dec 2004
Is IR naturally higher on smaller cells? I've got two 6s, 2900 mah packs that have about 10 cycles each. Using my 4010Duo the per cell IR reading during charge is always 4 to 5 IR. On some older 2s 5000 mah packs I get ~2 IR per cell.
kcobra is offline Find More Posts by kcobra
Old Feb 02, 2013, 01:30 PM
So. Cal.
Absolutely. Cells of equivalent quality have IR that is linearly dependent of capacity.
Mark
Old Feb 03, 2013, 03:43 AM
GordonTarling is online now
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Wayne's ESR meter is a great piece of kit, but in order to get results worth having, you do need to be fussy about the battery temperature that you measure at.
GordonTarling is online now Find More Posts by GordonTarling
Old Feb 03, 2013, 05:34 PM
The Engineer
Singapore
Joined Dec 2009
I need it for up to 23.88Ah per cell. Will it work?
Mini-HowTo Measuring IR (Internal Resistance) with a CB II lquick Batteries and Chargers 12 Sep 03, 2012 04:45 PM
Discussion Measuring IR squid Batteries and Chargers 2 Sep 17, 2011 06:23 AM
Discussion PowerLab 8 IR Measurements squid FMA Direct 1 Sep 13, 2011 03:27 PM
Question iCharger 106B+ IR measurement Wogboy Batteries and Chargers 1 Jun 08, 2009 10:07 AM
Easy internal resistance (IR) measurement? savydad Batteries and Chargers 8 Oct 12, 2005 06:10 PM
