Old Feb 02, 2013, 02:42 AM
Axefly is offline
Find More Posts by Axefly
South Africa
Joined Feb 2010
Help!
KK board question ?
Hi guys,
been having a blast with my Talon 2 machine and as i start to progress even further one step at a time i'd like to know the following:
On a punch out, i find that two motors speed up faster than the other two and cause the quad to not shoot straight up, is this normal on the kk board ? Or can it be adjusted ?
My esc's have been calibrated, i'm using thre kk4.7acro1550 software.
Axefly is offline Find More Posts by Axefly
Old Feb 02, 2013, 05:55 AM
Axefly is offline
South Africa
Joined Feb 2010
So i guess i must assume it's normal on the kk boards ?
Old Feb 02, 2013, 07:54 AM
xcaper is offline
Find More Posts by xcaper
Joined Sep 2012
Have a similar setup, and had a slight difference in motor speed. Try swapping motors around to see if the problem follows a motor, or stays put. I also found slight adjustment of the battery to ensure a solid center of gravity, accounting for the weaker side, helped off set what I assume in my case was weaker motors (inexpensive parts on this quad as its my training/crash unit)
xcaper is offline Find More Posts by xcaper
Old Feb 03, 2013, 10:25 AM
Axefly is offline
South Africa
Joined Feb 2010
Thanks, besides what you mention, i'm wondering if it could be the kk board itself that can't respond quickly enough to input/changes equally. How do you check c.g, all my equipment is very much centered except for the bec sticking out very slightly but it is so light. I think some kk veterans would know the exact answer, just don't know who the best KK knowledgeable person is to ask.
Rave HK KK V2 Quad board (and other recent KK boards) randall1959 Multirotor Electronics 2584 Aug 11, 2014 02:01 PM
Help! Original Firmware for KK 2 Control Board. Johnbee02 Multirotor Electronics 0 Jan 08, 2013 09:50 PM
Question KK v5.5 Flight Circuit Control Board v2.9 Guntar Multirotor Talk 0 Jan 07, 2013 08:36 AM
Question WHOAH high humidity makes my KK board not funtcion!!! LowlyElevated Multirotor Electronics 4 Jan 04, 2013 12:28 PM
For Sale HK KK Board + Programmer, and KK Balck Board + Programmer For Sale Actuality Aircraft - Electric - Multirotor (FS/W) 11 Apr 29, 2012 08:27 PM
