Old Feb 23, 2013, 07:44 PM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Originally Posted by ilektron View Post
Only had a little time to string it up and spin up the motors. The yaw control isn't great. Only had PD. Think I'll add I and see what happens.
https://www.youtube.com/watch?v=1pu-k7l9O5U
you have a great little helper there
matwelli is offline Find More Posts by matwelli
Old Feb 23, 2013, 07:46 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
second video - great progress
Old Feb 23, 2013, 08:09 PM
Spidious is offline
Find More Posts by Spidious
Bush Pilots Bounce Higher
Spidious's Avatar
USA, IL, Champaign
Joined Dec 2006
Have you thought of having another motor on the bottom with a rod with helicopter balance weights on the very ends. It might be like having a gyroscope inside of it so it won't dance around so much. It really helped on controlling my helicopters.
Spidious is offline Find More Posts by Spidious
Old Feb 23, 2013, 08:15 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Thanks! I use the term 'helper' loosely, though.
ilektron is offline Find More Posts by ilektron
Old Feb 23, 2013, 11:55 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
I built a new test rig today. Took a metal hanger, made a half loop, put the ends in washers glued to the sides of the cube. I then took a fishing line from the hoop up through an eyelet on a rafter on my patio, and then to the side and down.
The rig actually applied too many lateral forces on the aircraft to be truly be useful. The only useful thing I got out of the tests were the fact that the gyroscopic forces were causing strong couplings between pitch and roll in a hover. I think I need to run some calculations and see how much coupling I can expect and maybe try to use them to my advantage and mix it into the controls.
Old Feb 24, 2013, 09:02 AM
Brandano is offline
Find More Posts by Brandano
I think it depends on the mass of the prop, but try offsetting the inputs by 45 degrees. Essentially, keep them as they are, but consider the pitch and roll axes as being aligned to the diagonals when flying.
Brandano is offline Find More Posts by Brandano
Old Feb 25, 2013, 09:36 AM
corocopter is offline
Find More Posts by corocopter
Joined May 2010
Spidious,
That's an interesting idea.
When you say " helicopter balance weights" do you mean a teetering fly bar?
Can you please post a photo of your heli with this setup?
Kelly
corocopter is offline Find More Posts by corocopter
flying cube! BigBadWolf_TX Power Systems 13 Apr 10, 2002 10:59 AM
Antenna coil from E-Cubed J Morgan Power Systems 8 Jan 31, 2002 06:48 AM
Floating Cube? Not quite! windsurfer Parkflyers 3 Dec 04, 2001 06:22 PM
Floating Cube simitar Parkflyers 15 Oct 18, 2001 11:03 AM
Floating Cube miker Parkflyers 12 Jul 10, 2001 09:48 AM
