Old Feb 06, 2013, 04:45 PM
daughtry50 is offline
Find More Posts by daughtry50
United States, GA, Snellville
Joined Jan 2013
New pilots, fly smoothly, maintain some speed, usually half throttle or more. Avoid full elevator or abrupt elevator movements. Avoid sharp hard turns, especially if you are flying downwind. Watch the nose of your plane, climb gently, when you are landing, make sure the nose of the plane is either level or pointing downward slightly. Maintain some throttle as you make your landing approach (maybe 1/4). As you get over the runway, level out, maintain light throttle. Gradually cut the throttle and allow the plane to settle onto the runway. As you fly, think of the wing as knifing through the air, leading edge first. Abrupt and big elevator movements will cause the bottom (or the top) of the wing to move through the air, killing lift.
daughtry50 is offline Find More Posts by daughtry50
Old Feb 06, 2013, 08:40 PM
Dcope17 is offline
Find More Posts by Dcope17
Co-heir with Christ
Dcope17's Avatar
United States, CA, San Juan Capistrano
Joined Feb 2013
After the wing calculator results... says a 20 MPH stall speed. I wasn't going over 30MPH with about an 80 deg. bank in the corner. I can float my trainer and Typhood 3D plane through anything... I knew this bird would be temperamental.
Next time I will fly smoothly up and higher then I'll try things out and see what it can and can't do.
Dcope17 is offline Find More Posts by Dcope17
Old Feb 08, 2013, 11:46 PM
cold wombat is offline
Find More Posts by cold wombat
cold wombat's Avatar
Australia, WA, Perth
Joined Jul 2011
GuanLi 955mm J3 Cub COG.
Sanity check time...
I've got the Guan'Li 955mm J3 Cub (as supplied by HK- Blue & White or Invasion stripes), but the included instructions are for the RTF version (which assume you're using the supplied battery) and don't give the COG. I've plugged the numbers into the COG calculator (at 10% static margin) and it's saying the COG should be about 55 ~ 57mm from the leading edge (depending on how I muck around trying to 'square off' the tail measurements). This is around 38% of the root chord. Does that sound right?
cold wombat is offline Find More Posts by cold wombat
Old Feb 08, 2013, 11:58 PM
derpron is offline
Find More Posts by derpron
darn you, kakka carrot cake.
derpron's Avatar
Joined Aug 2012
Originally Posted by scirocco View Post
When you stop posting poor advice based on what, 5 1/2 months experience (http://www.rcgroups.com/forums/showp...79&postcount=1) people will stop criticising those posts.
Your desire to contribute and help is admirable, but you're dealing with people's effort and money when you provide advice in these forums, and it needs to be backed up by sound knowledge and experience.
Fortunately one of the benefits of an open forum like this is that bad advice tends to quickly get moderated or corrected. Consider it part of your learning process.
Scirocco
right....
derpron is offline Find More Posts by derpron
Old Feb 11, 2013, 08:31 AM
tclaridge is online now
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
wombat, A J-3 Cub CG should be at about 28% for good flying. I would not go beyond 33%. The wing is a bar shape, so just multiply wing chord * .28 and that is the distance from the leading edge (LE) that it should balance.
Many of my ARF manuals have incorrect CG.
tclaridge is online now Find More Posts by tclaridge
Old Feb 11, 2013, 08:50 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Just a bit of history. We old pharts used to call them plank wings as opposed to tapered wings. Now I feel even older
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Feb 11, 2013, 09:46 PM
Joined Jul 2011
Thanks muchly tclaridge. I was a bit nervous at the number the calc was giving me. I'll play around with it and see if I can work out why. Just out of interest, should the wing width be measured from the aircraft centre line or the side of the fuselage? The diagram on the calc suggests using the CL, but I'm not so confidant that is right.
My only radio kicked the bucket the other day and I'm away from home for now, but once I've sorted those two issues I'll give it a try at 28% and see how it goes.
Old Feb 12, 2013, 06:02 AM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Center line.
Lnagel is online now Find More Posts by Lnagel
Old Feb 12, 2013, 07:45 AM
Joined Jul 2011
:thumbsup:
Thanks Lnagel.
Old Mar 17, 2013, 08:51 PM
Dcope17 is offline
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
Alright, I've been busy and its been over a month... flew the Texan today trouble free.
I didn't do a pretty fix ( it was a good fix, just not smoothed out or covered, no cowl either ) Once i get 2 more flights with it without crashing, I'll make a place to hang it in the garage as it will then be a more permanent bird in the fleet.
I flew in a huge open flight field, kept the speed up and flew great. Landed and actually floated better than I thought after cutting power to a nice smooth landing.
Thanks for all the help everyone.
Old Mar 18, 2013, 04:36 AM
Tucci is offline
Find More Posts by Tucci
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
Please post a pic of your plane on a CG machine. I have the same one. I balanced it using the numbers from one of the calculators and it was too far back...
Tucci is offline Find More Posts by Tucci
Old Mar 18, 2013, 01:12 PM
Dcope17 is offline
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
Will do, give me a day or so and I'll get it checked.
Old Mar 18, 2013, 01:28 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
The main spar is a good start, always worked for me. ZEE
zeezee is offline Find More Posts by zeezee
Old Mar 18, 2013, 01:54 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Best to try maiden flight with some nose-heaviness and move battery pack aft (etc.) in small steps as you get familiar with it's habits. Check for wing tip washout and add some if possible by twisting and reshrinking covering. Let model lift off on it's own when ready at 3/4 throttle and keep climb angle shallow while you or a helper adjust up/downelevator trim as needed. Good tail dragger take-off and landing technique are needed. Nice looking model!! Land on the mains with some power and raise elevators to prevent nose over when rolling slow enough.
E-Challenged is offline Find More Posts by E-Challenged
Old Mar 20, 2013, 10:12 AM
Dcope17 is offline
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
Prolly not getting a pic soon. Working too muck and my buddy has the CG machine so I can't just run out in the garage and do it. There are a couple posts in this thread saying CG no more than 2 1/2" from the LE. Mine was 2 3/8 on its first flight and when I rebuilt it, I put everything back the same. Didn't check CG though. With possiblt a little more weight in the front because of the repair. Mine is likely 2 1/4 - 2 3/8 from the LE.
If your patient, I can check it... just not till the weekend or so.
Will this one fly? And where should CG be? Wheazel Parkflyers 15 Mar 03, 2004 07:28 PM
Where exactly should the CG be on the GWS A10? mrebman Parkflyers 7 May 25, 2003 03:01 PM
Anyone know offhand where the CG should be on a GWS J-3 Stick? mefly2 Parkflyers 2 Apr 17, 2003 08:32 PM
Slow Stick First flight Results - Where should the CG Be? mrebman Parkflyers 14 Jan 15, 2003 01:38 PM
Where should the Litestick CG be? mrebman Parkflyers 4 Jul 09, 2001 12:04 AM
