Old Feb 05, 2013, 02:42 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
Originally Posted by JetPlaneFlyer View Post
Nope, 35% back does not necessarily make the plane unstable. I've had freeflight gliders that fly very stable with the CG at 60 or 70% of the wing chord.
The thing that's often missed is that the biggest influence on where the CG needs to be for stability is the tail. A plane with a very large tail and a long tail moment can balance way back and still be stable. In fact it's perfectly possible for the CG to be behind the trailing edge of the wing and the plane still be stable.
The fact that the tail is so important to CG position is why any rule of thumb based on wing chord alone and totally ignoring the tail is little more than a guess.
Steve
You're right, I simplify things too much... the calculator really is the best way to do it. What I say really only applies to your typical cookie cutter type airplane which has similar dimensions to a majority of the planes out there. The larger your tail is among other things, it will scoot the CG back way beyond what you might see with a "typical" aircraft... ie with tandem wing planes.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Feb 05, 2013, 02:59 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Back in the olden days, I used to think nothing of chasing a free-flight across the meadows... at 70+ now, I think even less of it!
100% m.a.c. c.g.s were not unknown 50 years ago... on free-flights..
From Frank Zaic's "1959-61 Model Aeronautic Year Book"..(nothing like it availiable today).. a treatise on tail volume and c.g...
Sparky Paul is offline Find More Posts by Sparky Paul
Old Feb 05, 2013, 04:03 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
As a case in point; attached is a plan I did a few years ago for a micro rocket power freeflight glider for a postal contest in the USA. I mailed my plane over to the US, I got lucky, it positioned first in the contest.
The plan is based on a 60 year old Aeromodeller magazine plan originally powered by a Jetex rocket motor. Note that the design is quite conventional, it has a large tail but is not a tandem wing. CG is approx 80% back in the wing. The model was very stable, see the video.
Snowflake Rapier L1 power (1 min 5 sec)
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Feb 05, 2013, 07:00 PM
mrittinger is online now
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Yup, there are exceptions to every rule....there are also "general" guidelines.
Ive seen hot, highly loaded models with very far forward CG, and some FF types (mostly competition duration types) with your 80% CG.
A lot depends on the type of model, it's intended purpose, and some math.
I have found that the vast majority of my RC designs, perform well with CG somewhere from 20% to 30%, depending on the type and usage. Try flying that P51 with an 80% Cg and you are in for a wild ride....but the FF duration ship with a 30% would be interesting as well....
Getting back to the AT6.....probably 25% of the MAC or forward would be a decent starting point with what your intended flight envelope is...IMHO.
Mark
mrittinger is online now Find More Posts by mrittinger
Old Feb 05, 2013, 07:35 PM
Dcope17 is online now
Find More Posts by Dcope17
Co-heir with Christ
Dcope17's Avatar
United States, CA, San Juan Capistrano
Joined Feb 2013
1st flight is in the books...
Didn't go so well. nice take off and gain some altitude, make the turn and all is good, then had to tighten the turn so a little more angle ( don't know the technical term ) and some more elevator... and spiral of death. I let go and stops the spiral but couldn't get it leveled off before it made it to the ground.
Pulled out one landing gear and broke off the motor mount plate. Outside of the slight damage tearing the wheel off, the wing and tail are in great shape. Going out of town for a few days so I can't put it back together until Tuesday of next week.
Everything felt good in the short flight I had, How do I keep the spiral of death out of it? Was it simply too much elevator travel?
Dcope17 is online now Find More Posts by Dcope17
Old Feb 05, 2013, 09:49 PM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
Dcope, do you know the wing load?
tclaridge is offline Find More Posts by tclaridge
Old Feb 05, 2013, 10:08 PM
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
Total weight was 21oz. Certainly not on the lighter side of the scale.
Old Feb 05, 2013, 10:24 PM
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
wing load was 15.48 oz per sq. ft.
Old Feb 06, 2013, 12:47 AM
Aberdeen
Joined Mar 2006
Simple; Avoid stalling
Old Feb 06, 2013, 10:09 AM
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
That's all it was... too slow? Okay... next flight will be faster...
Old Feb 06, 2013, 01:24 PM
Aberdeen
Joined Mar 2006
You can stall at any speed. If you tried to pull it round in too tight a turn it could snap on you even if your flying speed was high. A stall occurs when the wing's angle of attack gets too high. The elevator controls the angle of attack of the wing, too much up elevator = stall
Small quite heavily wing loaded 'warbird type' models can be tricky.
Old Feb 06, 2013, 01:34 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Yes. I am surprised at the number of folks that don't understand this. I used to fly with a guy who was a full scale business jet jockey. He would talk about the Challenger series jets and how he loved it. But at max altitude he would talk about how fine a line it was between cruise and stall only a difference of a few knots.
So an airplane can stall at over 500mph!
Old Feb 06, 2013, 02:21 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
The highest flier had a "coffin corner" at altitude where flying too slowly resulted in a stall, and too fast resulted in Mach buffet and tuck.
The speed range (IAS) was only about 20 mph!
from "Aerograph 3, Lockheed U-2"... Jay Miller
Old Feb 06, 2013, 03:59 PM
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
So to explain and you can correct my noob thinking... I can stall at any speed. Meaning even though I. Am moving fast, I can hit a full elevator and angle the wing upwards but if I have enough weight... the wing won't climb but simply skid through the air and loose its lift.
So what is my solution... fly gently. I usually fly with grace and never hack the sticks. This one was that if I left it at its current turning radius, it was heading straight over to of me. This thing was fast for a little plane and didn't think it required that much room. Next time will be easy flying banked no more than 45 deg and plenty of room... until I get the hang of it.
Old Feb 06, 2013, 04:31 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Stall is basically seperation of airflow from the top surface of the wing OR stab. You can "stall" at any speed. Too much elevator throw can put you into a snap, then a spin.
I'd say keep up a little more speed, cut down on ele throw. Just my opinion, hard to tell without a vid...
I've heard the U2 , at altitude, had to make HUGE turns to avoid having one wing go supersonic, and the other stall at the same time :O
Mark
Will this one fly? And where should CG be? Wheazel Parkflyers 15 Mar 03, 2004 07:28 PM
Where exactly should the CG be on the GWS A10? mrebman Parkflyers 7 May 25, 2003 03:01 PM
Anyone know offhand where the CG should be on a GWS J-3 Stick? mefly2 Parkflyers 2 Apr 17, 2003 08:32 PM
Slow Stick First flight Results - Where should the CG Be? mrebman Parkflyers 14 Jan 15, 2003 01:38 PM
Where should the Litestick CG be? mrebman Parkflyers 4 Jul 09, 2001 12:04 AM
