Old Feb 02, 2013, 05:53 PM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
Originally Posted by colj00 View Post
general rule is 35% back from the leading edge of the wing. but because its a warbird, its more like 25% back.
25% is the general rule of thumb regardless of what plane (for traditional non-swept monoplanes). 35% is technically unstable, best to leave to only the most hardcore 3D machines.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Feb 02, 2013, 07:19 PM
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
"general rule is 35% back from the leading edge of the wing."
That is very hard to believe. Start at 25 percent.
foamflyer is offline Find More Posts by foamflyer
Old Feb 02, 2013, 07:51 PM
United States, ID, Burley
Joined Mar 2012
Originally Posted by scirocco View Post
And just what's your source for that? I don't think I've ever seen as far back as 35% quoted as a rule of thumb guide - maybe 33% max, more typically 25-33%.
After detailed calculation, it may well end up further back than that, but to throw 35% out as a "general rule" is I'm afraid just BS.
If you want to learn something about cg, try reading this: http://www.theampeer.org/cg/cg.html
For the OP, if it is indeed the Herr AT-6, apparently the recommended cg is at the rear of the spar: http://www.rcgroups.com/forums/showp...5&postcount=70 & http://www.rcgroups.com/forums/showp...19&postcount=5
thanks for the link, never to old to learn ! May be to old to remember but not to learn
fastfwd is online now Find More Posts by fastfwd
Old Feb 02, 2013, 08:05 PM
sub-noob
colj00's Avatar
Australia, WA, Perth
Joined Aug 2012
okay guys, stop hating :/
i usually fly 35% back though.
colj00 is offline Find More Posts by colj00
Old Feb 02, 2013, 08:08 PM
Joined Dec 2011
It's not about hating.
A tail heavy plane (balanced at 35%) might fly for a few moments.
Nose heavy might not fly well, but is manageable.
For those of us with decades of experience, we want to make sure noobs understand to start "nose heavy" and then slowly move the CG back, bit by bit.
DustBen is offline Find More Posts by DustBen
Old Feb 02, 2013, 08:31 PM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
When you stop posting poor advice based on what, 5 1/2 months experience (http://www.rcgroups.com/forums/showp...79&postcount=1) people will stop criticising those posts.
Your desire to contribute and help is admirable, but you're dealing with people's effort and money when you provide advice in these forums, and it needs to be backed up by sound knowledge and experience.
Fortunately one of the benefits of an open forum like this is that bad advice tends to quickly get moderated or corrected. Consider it part of your learning process.
Scirocco
scirocco is offline Find More Posts by scirocco
Old Feb 02, 2013, 11:35 PM
Seattle Area
Joined Aug 2007
Scirocco
eagle777 is offline Find More Posts by eagle777
Old Feb 03, 2013, 12:03 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
All normal wing / tail style models like this .. I balance at 30 - 33% back from L/E measured at root. The slight sweep-back makes this a safe CoG ... but still responsive.
I rarely have to move a CoG from that.
Nigel
solentlife is online now Find More Posts by solentlife
Old Feb 03, 2013, 12:07 AM
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
For years all I ever heard as general rule was UP TO 1/3rd chord back from L/E.. at root.
Nigel
Old Feb 03, 2013, 12:11 AM
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
Post deleted after back-checking ...
Old Feb 03, 2013, 12:34 AM
Seattle Area
Joined Aug 2007
25% is a nice rule, easy to remember, and safe. It usually works well for a maiden and possibly is the best CG for that plane.
Saying 35% is ok too, but I have not gone much more than 30%, except for 3D planes IIRC.
The 25% rule is conservative, works well in most cases, and is easy to measure and remember. To say the starting point is 35%, well that is pretty bold, and would most likely make a plane more responsive or hard to handle than many people want.
I haven't tested this premise extensively, and am just pointing out the accepted starting CG.
Old Feb 03, 2013, 07:40 AM
Joined Oct 2008
For what you have been flying this may be fine, but I suggest you don't try it with anything more scale or valuable. We're not hating, just trying to make sure people don't wreck a plane unnecessarily. 25% is always safe for a conventional aircraft, 35% is usually dangerous.
Old Feb 03, 2013, 08:45 AM
ARFs make me BARF
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Ignore the root chord measurement. Calculate it properly!
http://adamone.rchomepage.com/cg_calc.htm
or an easier version: http://www.scaleaero.com/CG_Calculator.htm
mrittinger is offline Find More Posts by mrittinger
Old Feb 03, 2013, 10:27 AM
Co-heir with Christ
Dcope17's Avatar
United States, CA, San Juan Capistrano
Joined Feb 2013
So, I'm running it through the calculator and every thing I understand except the static margin % that I have to enter.
Top of the page says 5%-15% for good stability...
So, I'm guessing I want 10% then.
Dcope17 is offline Find More Posts by Dcope17
Old Feb 03, 2013, 10:30 AM
Joined Oct 2008
5% is pretty common in general aviation planes... higher for something that will experience a lot of different loads like a military cargo plane, but that's just my opinion. Anywhere in that range is fine really.
Will this one fly? And where should CG be? Wheazel Parkflyers 15 Mar 03, 2004 07:28 PM
Where exactly should the CG be on the GWS A10? mrebman Parkflyers 7 May 25, 2003 03:01 PM
Anyone know offhand where the CG should be on a GWS J-3 Stick? mefly2 Parkflyers 2 Apr 17, 2003 08:32 PM
Slow Stick First flight Results - Where should the CG Be? mrebman Parkflyers 14 Jan 15, 2003 01:38 PM
Where should the Litestick CG be? mrebman Parkflyers 4 Jul 09, 2001 12:04 AM
