Old Feb 02, 2013, 12:19 AM
Dcope17 is online now
Find More Posts by Dcope17
Co-heir with Christ
Dcope17's Avatar
United States, CA, San Juan Capistrano
Joined Feb 2013
Plane CG... where should it be?
SO, I acquired this little plane and know nothing about it. I have a .40 size trainer I built like 10 years ago and a 3D foamie ( which required no building )
I noticed a weight in the cowl but I have no idea what size motor and battery pack were used to need this weight.
I like this little plane and don't want its first flight ( in my possession ) to be its last.
Here's what I have...
Dcope17 is online now Find More Posts by Dcope17
Old Feb 02, 2013, 01:04 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
A good starting point. Measure the chord at the wing root. Then go about 25% of the root chord back from the leading edge of the wing.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Feb 02, 2013, 01:05 AM
wizard of odd is online now
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, VIC, Sale
Joined Apr 2011
FWIW, that looks like a Herr Engineering AT6.
sirzeppu has just maidened his here http://www.rcgroups.com/forums/showthread.php?t=1820734, maybe ask him.
wizard of odd is online now Find More Posts by wizard of odd
Old Feb 02, 2013, 06:20 AM
derpron is offline
Find More Posts by derpron
darn you, kakka carrot cake.
derpron's Avatar
Australia, WA, Perth
Joined Aug 2012
general rule is 35% back from the leading edge of the wing. but because its a warbird, its more like 25% back.
derpron is offline Find More Posts by derpron
Old Feb 02, 2013, 06:43 AM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
And just what's your source for that? I don't think I've ever seen as far back as 35% quoted as a rule of thumb guide - maybe 33% max, more typically 25-33%.
After detailed calculation, it may well end up further back than that, but to throw 35% out as a "general rule" is I'm afraid just BS.
If you want to learn something about cg, try reading this: http://www.theampeer.org/cg/cg.html
For the OP, if it is indeed the Herr AT-6, apparently the recommended cg is at the rear of the spar: http://www.rcgroups.com/forums/showp...5&postcount=70 & http://www.rcgroups.com/forums/showp...19&postcount=5
scirocco is offline Find More Posts by scirocco
Old Feb 02, 2013, 07:05 AM
Teddy Ong is offline
Find More Posts by Teddy Ong
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
it should be about 1/4 to 1/3 of wing root
Teddy Ong is offline Find More Posts by Teddy Ong
Old Feb 02, 2013, 07:24 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I'd go with the 1/3 of the chord at the root because the swept back leading edge would put the CG a little futher back.Keep the speed up when you land it. The AT6/ Harvard, is a known tipstaller.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Feb 02, 2013, 07:36 AM
derpron is offline
derpron's Avatar
Joined Aug 2012
oh ive read a fair amount of times that 35% is a good place to start.
Old Feb 02, 2013, 09:15 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I think you may be confusing the actual CG measurement with something I see often on RCG (it makes me cringe) and that is some people provide the CG measurement from the wing root without explaining that the calculation is done on the Mean Aerodynamic Chord (MAC) and not the root chord. Quite often you'll see this on Delta planforms where the OP say "the CG is at 50% from the leading edge" when the CG is actually 20% of the MAC (even though the physical point on the aircraft is the same)
I've actually seen someone try to balance a conventional plane at 50% from the leading edge "because my delta flew fine that way" The results, of course, were disastrous.
Read the article that scirocco linked to and take a look at a CG calculator. None will recommend an actual CG starting point back as far as 35%. (realize that there are exceptions for everything and some 3D pilots will run a rearward CG because they think it makes hovering easier, but may adversely affect all other aspects of flight)
Azarr
Azarr is offline Find More Posts by Azarr
Old Feb 02, 2013, 09:24 AM
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
Thanks everyone... I'll PM sirzeppu about his setup and how well it worked.
Also, thanks for that link showing how to set the CG. I'll be giving that a read this evening when I get home and settle in.
Last, its maiden will likely be at the local football field with a track around it. I figured it won't fly as slow as my trainer but with that long of a runway... I'll bring it in hot and take the whole length of track to set it down if need be.
Old Feb 02, 2013, 10:37 AM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
If it was mine I would balance it on the spar even with where your aileron horns are. As noted since it has a sweep to the wings the normal 25-30% back from the LE doesn't work.
Also as noted some of these old Harvards are difficult to fly especially slow.
Evan D is offline Find More Posts by Evan D
Old Feb 02, 2013, 10:54 AM
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
Use a CG calculator. Much better. Measure and key in the numbers.
Old Feb 02, 2013, 12:22 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
The similar sized House of Balsa T-6 would be unflyable with the c.g. further aft than as shown!
The T-6 is an AWFUL airplane. Sometimes fun to fly, but very sensitive to control throws and will tip-stall at every opportunity!
There was a lot of activity years back racing these things with OS 15 motors. Getting them off the ground at the start was always amusing, directional control on the ground was poor. Switch to the OS25 motor got rid of that problem.
This is my last one, switched to electric when a sufficiently powerful and light motor became available. Still had the too-heavy Nicad battery. With a Lipo, it's a lot better.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Feb 02, 2013, 04:25 PM
daughtry50 is offline
Find More Posts by daughtry50
United States, GA, Snellville
Joined Jan 2013
Please, AWFUL to fly, all of them. I don't think so. I've owned built up Texans and foamie Texans and they flew just fine. The reason, my wing loading on them was fairly light. If you have a Texan that flys the way you describe then it is probably heavy and also set up tail heavy. A Texan will not fly like a trainer but, set up properly they fly nicely.
daughtry50 is offline Find More Posts by daughtry50
Old Feb 02, 2013, 05:52 PM
DustBen is online now
Find More Posts by DustBen
DustBen's Avatar
United States, AL, Birmingham
Joined Dec 2011
I'm a little concerned by the 35% figure also.
I've flown 100's of models and cannot recall any model with such an aft CG location listed as the "starting point".
25% is a nice starting point and can slowly be moved back.
At 35%, nothing is going to happen slowly.
DustBen is online now Find More Posts by DustBen
Will this one fly? And where should CG be? Wheazel Parkflyers 15 Mar 03, 2004 07:28 PM
Where exactly should the CG be on the GWS A10? mrebman Parkflyers 7 May 25, 2003 03:01 PM
Anyone know offhand where the CG should be on a GWS J-3 Stick? mefly2 Parkflyers 2 Apr 17, 2003 08:32 PM
Slow Stick First flight Results - Where should the CG Be? mrebman Parkflyers 14 Jan 15, 2003 01:38 PM
Where should the Litestick CG be? mrebman Parkflyers 4 Jul 09, 2001 12:04 AM
