Old Feb 01, 2013, 11:57 PM
Gene is offline
Find More Posts by Gene
United States, CA, Anaheim
Joined Aug 1999
Multi motor programming Joe or Bernie ?
I recall reading an article by Joe Ford a few years back on how to set up two Phoenix ESC's to control two motors. There were certain settings that you would program the two controllers to and these settings would apply to both ESC's. I printed the information out, but of course, I can't find it now. I'm programming two Phoenix 35's to power two motors on a B-25. Joe, could you direct me to where that article is on your Castle Creations site or would you list those settings here, so that I can proceed with this project. Thank you.
Gene is offline Find More Posts by Gene
Old Feb 02, 2013, 04:59 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Maybe some of the guys at the Scale Forum can help – give them a try.
RC Man is offline Find More Posts by RC Man
Old Feb 02, 2013, 09:25 AM
Gene is offline
Joined Aug 1999
Thank you RC Man. I'll look there too.
Old Feb 02, 2013, 12:50 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
Gene,
The pdf that Joe wrote that info in is no longer on the Castle site, but I found the info here, posted below as well as the link I found the info at:
http://www.rcgroups.com/forums/showt...ighlight=multi
A typical twin set up is:
• One ESC for each motor Y harnessed on the receiver, both BECS enabled.
• One large battery Y harnessed to the ESCS, keeps the same voltage to each ESC
• Change ‘Throttle Type’ to ‘Fixed’
• Change ‘Cut Off Type’ to ‘Soft Cut Off’
The goal here is to keep both motors running at the same speed and to not have one cut off completely at ‘Low Voltage Cut Off.’
Bernie
Joe added:
Current limiting disabled as well.
David Hogue is offline Find More Posts by David Hogue
Old Feb 02, 2013, 05:25 PM
Gene is offline
Joined Aug 1999
David thanks. That sounds like what I had read a while back. Joe Ford recommended "Current limiting disabled as well". I was going blind trying to figure out where to find that information. You found it. Great job on your part. Really appreciate it. I owe you a beer.
Old Feb 02, 2013, 11:25 PM
USA, NC, Clayton
Joined Feb 2001
Wierd, I was sure I copy/pasted Joes "Current limiting disabled " part too. Its added now. I have done several twins with castle esc's so I have a hard copy somewhere too. Posting here will no doubt help me sometime in the future when I need toreference it, too
Old Feb 03, 2013, 07:29 AM
Gene is offline
Joined Aug 1999
Same thing happenend to me when I tried to print it.
Old Feb 13, 2013, 11:39 AM
Bernie Wolfard is offline
Find More Posts by Bernie Wolfard
Castle's Chaos Corner
Bernie Wolfard's Avatar
Olathe, KS (next to the Castle)
Joined Jun 2001
Unless you are running your systems to there maximum capability, I.E. 50 amps at full throttle on an ICE 50, there is no need to turn of or change Current Limiting. Joe is a speed freak and always pushed system to and past their limits.
Bernie
Bernie Wolfard is offline Find More Posts by Bernie Wolfard
Old Feb 13, 2013, 02:22 PM
Gene is offline
Joined Aug 1999
Bernie, I don't plan to run my ESC's up to the max allowable Amps. I'm using Phoenix 35's and drawing about 15 Amps per motor.
Idea Multi Rotor Racing (FPV or else) crashtested Multirotor Talk 45 May 13, 2013 01:08 AM
Sold (4) Emax Multi Copter motors 2212 - 920KV Sleepyc Aircraft - Electric - Multirotor (FS/W) 1 Jan 15, 2013 09:41 AM
Sold 4 Motors for sale in multi's but thought I'd post them here too. Navy Jet Mech Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2013 01:43 PM
