Old Feb 01, 2013, 11:55 PM
BretC is offline
Find More Posts by BretC
Joined Nov 2012
Aurora 9 locked on screen "Version Changed"
I have a brand new Aurora 9. I just turned it on for the first time tonight. The opening screen shows:
"[Iformation] Version Changed Ver.107(0) -> Ver.1.08(1) <OK>"
However when I try to push OK on the screen nothing happens. I have turned it on and off several times but nothing changes.
What am I doing wrong?
Internet searches do not provide any information.
Thank you.
Bret C
BretC is offline Find More Posts by BretC
Old Feb 02, 2013, 12:01 AM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Shot in the dark: try touching all over the screen, the touch screen might need calibration and doesn't line up with the ok.
fcbflyer is offline Find More Posts by fcbflyer
Old Feb 02, 2013, 12:09 AM
BretC is offline
Joined Nov 2012
Touch screen problem?
I found part of the problem. The touch screen is not very responsive. I again tried to push the OK button several times, finally it changed windows. Then in an attempt to get to other screens, I had a very difficult and time consuming time repeatedly pushing the touch screen. Wetting my fingers did not help.
Any ideas?
Bret C
Old Feb 02, 2013, 12:18 AM
BretC is offline
Joined Nov 2012
FCB Flyer - Good suggestion. I was finally able to get through the screen calibration process and the screen is reacting a tiny bit better, but unless it can get a lot better, I am not impressed with the transmitter touch screen.
Bret C
Old Feb 02, 2013, 12:32 AM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Did you take off the protective film?
My screen worked better without it.
Also my Aurora is old and I didn't get the stylus with it. The stylus works better than fingers.
Old Feb 02, 2013, 12:35 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by BretC View Post
FCB Flyer - Good suggestion. I was finally able to get through the screen calibration process and the screen is reacting a tiny bit better, but unless it can get a lot better, I am not impressed with the transmitter touch screen. Thanks Bret C
. Aurora 9 - Screen Protector & Intermittent Screen or Icon Problems - Remove Protector or Not & alternate replacements & DIY Fixes.
. Aurora 9 - Screen Sensitivity & Recalibration - Pressure switches, not capacitive, use either Stylus provided or very tip of finger for best results.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
In need, email/phone direct to:
Hitec Warranty & Service - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time. Reach us at 858.748.8440 or
service@hitecrcd.com any time you have a question"
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Feb 02, 2013, 10:33 AM
BretC is offline
Joined Nov 2012
I will have to try the Stylus. Thanks!
Help! Dimensions of Aurora 9 screen? Garret H Radios 62 Sep 13, 2011 03:13 PM
For Sale Custom TX screen protectors - DX7, Aurora 9, JR 9303, SD-10G, ATX RDS8000 Garret H Aircraft - General - Radio Equipment (FS/W) 56 Sep 01, 2011 10:10 PM
For Sale NEW! Screen protector for Hitec Aurora 9!! Garret H Aircraft - General - Radio Equipment (FS/W) 2 Sep 08, 2010 09:20 PM
