Old Feb 01, 2013, 10:48 PM
SARCFAN is offline
Find More Posts by SARCFAN
Joined Dec 2010
Question
Connectors, amp ratings
I am not sure of the following. lets take a XT60 as an example. It is rated at a constant 60 A. But at what voltage? This is not specified. Or does voltage make no difference? Will the strain on the connector be the same under the following two conditions?
1. When you have a 3S (11.1V) battery with a 30 A drain
2. When you use a 400V source with a device pulling 30A at that voltage.
In case number two the watts is 36 times more. Will the XT60 be operating at the same temperature under both scenarious?
The reason for my question is just out of a matter of interest.
Here is a very practical example.
It is written on a particular household plug '' 125 VAC at 5 amps''. Now if you want to use that same plug in a 220V household. Is it still good for up to 5 Amps?
Sorry if this does not seem boating related, but it is. My question basically: At what voltage do manufacturers give the particular amp ratings of any specific connector?
SARCFAN is offline Find More Posts by SARCFAN
Old Feb 02, 2013, 02:30 PM
viperidae is offline
Find More Posts by viperidae
New Zealand, Wellington, Porirua
Joined Jan 2013
In general the amp rating stays the same when working with different voltages. How ever a switch rated for 125v probably will not be suitable for 220v sure to other factors like contact separation and insulation.
In short, the current rating is based on contact resistance. In your example when the switch its closed out wool see the same voltage in both scenarios as according to ohms law v=I*r. I=30 in both cases and the resistance it's also the same so the voltage drop will be the same too. When the switch opens how ever the full voltage will be across it so must be rated for 400v
viperidae is offline Find More Posts by viperidae
Old Feb 02, 2013, 10:39 PM
SARCFAN is offline
Joined Dec 2010
Thanks. So in theory you could use a XT60 in a 400V system as long as your ampdraw is not over the limmit?
Old Feb 03, 2013, 03:03 AM
Joined Jan 2013
Probably. I wouldn't want to go anywhere near it though. Xt60 connectors are not insulated for high voltage. You'd be liable to electrocuted yourself. The connectors would handle the current though.
Old Feb 03, 2013, 10:46 AM
SARCFAN is offline
Joined Dec 2010
No I agree. But I was always wondering when manufacturers quote the max continious amp-rating. It is never said at what voltage this was achieved.
Looking at normal bedlamp wires, they are seperated by very little plastic between them. With XT60's for example, there are a lot more plastix seperating the two connectors. I'm sure they can handle a lot of voltage. But I'm merely interested at what voltage are the continious amp-rating achieved.
Old Feb 03, 2013, 08:57 PM
Joined Jan 2013
The amp rating is probably based on the connector resistance and power dissipation.
If you have a look at ohms law you'll see that supply voltage has no effect on the current capacity of the connector. In this case Power = Current squared * Resistance
There is no voltage in that equation.
If you don't apply the heatshink correctly to an XT60, there is bare copper exposed even when connected.
It appears it's only a couple of millimetres between the positive and negative. Not taking into account any moisture on the plastic, a surge of just a few KV would be enough to start an arc, and being DC going through it, the arc could be kept going, effectively shorting your battery through the plasma. You don't get this problem with AC (if an arc is created, the voltage soon drops to zero, stopping the arc), which is why you may see a switch or relay with contacts rated at a particular current with a voltage of 125VAC/30VDC
Old Feb 04, 2013, 12:49 AM
SARCFAN is offline
Joined Dec 2010
Thanks. You are too clever. You must speak as if I'm a 10 year old child.
But I do get what you are saying.
Thank you, I'm sorted.
Old Feb 04, 2013, 12:16 PM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
Yeah... For the most part (within some reasonable range) the voltage does not matter.
As viperdae mentioned it would seem they are rating the connector using the equation:
Power = Amps ^ 2 * Resistance
The equations for heat are very similar to power, so the more power you generate the more heat you generate over time. I am going to assume that when they rate the something for 60amps they are probably thinking they have a given resistance and at over 60 amps the heat buildup becomes a problem - like softening or melting the plastic. The resistance of a connector is probably somewhere in the 0.0009 ohm range which means something around 4 watts of power dissapated in the connector is a problem.
You could use any voltage you like, but if nothing changes in the overall circuit and you crank up the voltage you will also increase the number of amps.
It would seem that you work mostly with voltage and the motor to determine RPM and an amp draw. Then given the amp draw you can determine if a given connector will work.
I don't think arcing is a problem until the voltage gets really high. I am pretty sure it takes about 3000 volts to jump a 1mm gap in air.
cyberhoops is offline Find More Posts by cyberhoops
Old Feb 04, 2013, 12:26 PM
Joined Jan 2013
Yes, it does take 3300V for a spark cross a 1mm air gap. But any inductive load is going to produce a sizeable voltage when disconnected. Once an arc starts from a high voltage, a low voltage can keep it going.
Old Feb 04, 2013, 12:28 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Ahhh. Ok. Thanks Viper.
Discussion Dual Rates - How To Establish Airplane High & Low Rates? itsme2 Electric Plane Talk 7 Jan 06, 2013 09:52 AM
Deans 2 & 3 pin connectors and Multiplex Connectors SOLD Mikey 68 Non R/C Items (FS/W) 1 Jan 02, 2013 01:21 PM
Himax motor connector amp rating AndreyT Power Systems 1 Sep 23, 2005 05:53 AM
Amp rating of a Deans Series connector module? Mike Parsons Batteries and Chargers 20 Jun 11, 2005 03:42 PM
MP Jet 1.8mm Connectors amp rating???? power Power Systems 3 Apr 08, 2005 09:53 PM
