Old Feb 01, 2013, 06:30 PM
SYRFD is offline
Find More Posts by SYRFD
Joined Aug 2012
Help!
Question on covering cockpit area
I am building a SIG Cavalier and giving it the look of a pt 19 Trainer. It will have an open cockpit. Any suggestions on how to protect and cover the wood I used for the cockpit? Will spray paint alone be enough or should I use wood stain and then paint? I don't want to use any monokote for the cockpit, but I want to have it protected. Thanks!
SYRFD is offline Find More Posts by SYRFD
Old Feb 01, 2013, 11:50 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
I would spray paint it, then just take some thinned epoxy and cover the open are. It will give it a cool look too.
Kyler1 is offline Find More Posts by Kyler1
Old Feb 06, 2013, 03:51 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Thinned epoxy first, then paint. If you paint first the epoxy will just lay on top of the paint doing very little good. Epoxy first will soak into the wood so even if the paint fails you still have protection.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my Senator.....
Old Feb 07, 2013, 12:57 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
A lot depends on where you place and/or point your exhaust.....If it is anywhere but pointed toward the cockpit, not a whole lot needs to be done.
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ Ki-61
Discussion Question about covering Carnifax Painting and Finishing Tips 6 Feb 14, 2013 09:16 AM
Help! Econokote on EPP covering question Flying-Addict Slope 36 Jan 27, 2013 04:55 PM
Discussion Propeller covers holes on the motor rcdogmatix Electric Plane Talk 2 Jan 15, 2013 01:38 PM
Sold custom covered 3DHS Vyper 65 (lpu NYC area only) Irg Aircraft - Electric - Airplanes (FS/W) 13 Jan 09, 2013 10:50 AM
Discussion 18" Albatros covering question richb77uk Scratchbuilt Indoor and Micro Models 2 Jan 07, 2013 03:46 PM
