Old Feb 04, 2013, 10:06 PM
mcashatt is offline
Find More Posts by mcashatt
mcashatt's Avatar
United States, AZ, Gilbert
Joined May 2012
Originally Posted by KKUSA View Post
Can you measure the overall length with the prop and adapter installed, as you are going to be using it? I want to check the clearance between motors. Its enough, I just want to check a few things.
I have taken a bunch of pics with my calipers and will send you a download URL in a PM.
Matt
mcashatt is offline Find More Posts by mcashatt
Old Feb 04, 2013, 10:28 PM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
Made some more adjustments , and added LED mount plates to the ends of the arms. You could have some PCB's made just for those!! I may design that as well just in case you want to go that route. One side of the PCB could be for 1+ watt star LED's , and the other for smd so you have some option.
Let me know what you think!!
KKUSA is offline Find More Posts by KKUSA
Old Feb 04, 2013, 10:36 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Man it is outstanding very well done
tech69x is offline Find More Posts by tech69x
mcashatt is offline
mcashatt's Avatar
Joined May 2012
LOVE IT!!! And--I can etch PCBs here, not that I need to. The WS2801 strips I use are the latest gen and have all of the circuitry *behind* the LED so I can literally clip one out and have it sit perfectly on that platform.
Might want to add some parallel oblong holes where ever wires or cables will be routed so that it's easy to get a zip tie in there and tie them down. You have probably seen this on any model helicopter.
Nice work!
Old Feb 04, 2013, 10:40 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
If you don't mine me asking what is the widest part of the frame
Old Feb 04, 2013, 10:49 PM
mcashatt is offline
mcashatt's Avatar
Joined May 2012
That would be good to know as I know Mike is trying to order some CF plates. Eric?
Old Feb 04, 2013, 11:07 PM
KKUSA is offline
Joined Oct 2010
Here ya go!!!
As far as the PCB's, You can have some made very cheap, for about $1 ea. Its usually cheaper that way, and much nicer. You just have to wait a week, or so, depending on how you want them shipped.
Yes, there will be holes for zip ties. I always do that. Its usually just one of the final detail steps.
Old Feb 04, 2013, 11:12 PM
mcashatt is offline
mcashatt's Avatar
Joined May 2012
Here ya go!!!
Thanks Eric!
Mike--that gives you what you need for ordering the plates, right?
Old Feb 04, 2013, 11:20 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Yes sir thank you very much
Old Feb 04, 2013, 11:22 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Man this is going to be bad to the bone
Old Feb 04, 2013, 11:36 PM
mcashatt is offline
mcashatt's Avatar
Joined May 2012
It's pretty rad. Eric has done a great job with design and I can't wait to see what you do with the cutting.
I really think that with the weight in the middle and all of the smallish but powerful motors, that this should make for an interesting videography platform.
Old Feb 05, 2013, 12:42 AM
mcashatt is offline
mcashatt's Avatar
Joined May 2012
Hey Eric, Mike was wondering what we should call this thing. Since it has (to me) a look that reminds me of Japanese architecture or even of a Samurai's armor, I told him that "Samurai", "Shogun", and "Katana" all come to mind.
Thoughts?
Old Feb 05, 2013, 12:49 AM
KKUSA is offline
Joined Oct 2010
Thoughts?
I think it reminds me more of a Shuriken, a throwing star!!!
Call it whatever you want!!
Old Feb 05, 2013, 03:32 AM
KKUSA is offline
Joined Oct 2010
Ok, the motors will fit just fine!!! I added holes for larger motors, 16mm and 19mm hole pattern. You can choose to leave these out when you machine it if you wish, but they are there just in case.
Added LED plates to lower legs. Added the necessary spacers that will lock it together, and few other details.
I think that is pretty close for the arms. I need to work on the center section now.
BTW, the top and bottom sections will be able to be used as quads all on there own!!!! Its a 3 in 1 !!
Old Feb 05, 2013, 10:01 AM
mcashatt is offline
mcashatt's Avatar
Joined May 2012
Oh man--this is so rad. GREAT WORK ERIC!!
Does anyone know of a good source for the needed hardware (like the spacers)?
Question I need a cheap 18 amp (or more) ESC with brake. What's out there? Miami Mike Power Systems 3 Jan 13, 2013 02:55 PM
Discussion >>Any FJ Cruiser owners out there? daddiozz Life, The Universe, and Politics 20 Jan 09, 2013 08:11 PM
are there any 250 watt 3d capable bluecore plans out there? chimchim 3D Flying 3 Sep 07, 2005 09:19 PM
Any Smoke Experts out there? Jim T. Graham Fuel Plane Talk 2 May 30, 2003 01:46 PM
Any brushless experts out there? Parkflyer Power Systems 4 Nov 26, 2002 09:13 AM
