Old Feb 10, 2013, 11:34 AM
Custom quad builder
tech69x's Avatar
United States, TX, Spring
Joined Apr 2012
Originally Posted by KKUSA View Post
I think you may find that his 250 motor mounts may not fit with the motor slots at 45deg relative to the arm. If the motor mount tab is under 6mm wide, they will, if its wider, they will interfere with the side plates. I'm not sure exactly how wide they are. Matt will need to measure them. Or just go with motors that will mount on top.
Any motor will fit I have already tried
tech69x is offline Find More Posts by tech69x
Latest blog entry: Win a frame
Old Feb 10, 2013, 11:50 AM
(My english is Bad - Sorry)
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by tech69x View Post
Yea it's going to take a lot of material
If it was my design, i would try to find a way to split that big plate in smaller one.
Like 4 arms plates...
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 10, 2013, 12:02 PM
mcashatt's Avatar
United States, WA, Bellevue
Joined May 2012
Hey beggars can't be choosers!
I will go with what ever I am lucky enough to get frame-wise and then adapt. Of course, I would love to use those 250's and I think that the way they mount will reduce vibration, but I also recognize the hard design and cutting work that is being done and don't want you guys worried about my particular implementation if it costs you more time.
Thanks again all!
mcashatt is offline Find More Posts by mcashatt
Latest blog entry: SkullCopter Labs
United States, IN, Indianapolis
Joined Oct 2010
Not necessarily. If mounting on top, yes, but not if mounting on bottom between the upright plates as Matt wants to do. His 250 motors must use the included motor mount. If the width of the tabs are greater than 6mm, it will not fit without interference to the upright plates when it mounts at 45 degrees to the arm. He could get them in there, but is not ideal as it would be pushing the plates to the side. No reason to jerry-rig stuff if it isnt necessary. The 22mm holes for the 250's were placed axially to the arms for this reason. They may indeed fit, but without knowing all the dimensions of the motor mount, there is only one way to be sure.
Please see pic.
KKUSA is offline Find More Posts by KKUSA
Old Feb 10, 2013, 12:07 PM
Joined Oct 2010
Thanks again all!
It was designed for you, for your particular implementation.....What are you talking about!!!! You stated you had very particular requirements, and thats how it was designed.
If it were to be a more universal design, we could have done it a bit differently.
Old Feb 10, 2013, 12:21 PM
mcashatt's Avatar
Joined May 2012
And I appreciate it. Really, I do. I would just rather get what I can and not waste any material since it is already cut, that's all. Seems like it wouldn't be too hard to just drill the holes I need with my drill press if I can't make it work as-is.
Old Feb 10, 2013, 01:30 PM
Joined Oct 2010
That was considered, but its going to need extra parts and screws to hold it all together that way, and thats just adding weight.
Old Feb 10, 2013, 01:32 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Could be integrated in the design.
Old Feb 10, 2013, 01:56 PM
Joined Oct 2010
Yes, some of it could. However, as it is, its true to Matt's design intent. Its essentially how he wanted it!!! So.....
Old Feb 10, 2013, 02:00 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I am just saying.
It will use a lot of material that's all.
When will we see an actual assembly :-)
Old Feb 10, 2013, 03:18 PM
Joined Oct 2010
I am just saying.
Same amount of material, it just makes using more of a panel more difficult.
Im not sure about a completed unit. Thats up to Mark and Matt.
Old Feb 10, 2013, 05:26 PM
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Matt, you should update the first post and title of this thread. Looks pretty cool!
TheFernMan is online now Find More Posts by TheFernMan
Old Feb 10, 2013, 06:31 PM
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Well I got a little more done today
Name: ImageUploadedByTapatalk HD1360542634.589585.jpg
Description:
Old Feb 10, 2013, 06:33 PM
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Please see pic.
They are not more than 6mm
Old Feb 10, 2013, 06:34 PM
mcashatt's Avatar
Joined May 2012
Attachment 5526533
Very nice Mike! The anticipation is killing me! I got a nice spot cleared out on my workbench and ready!!
Question I need a cheap 18 amp (or more) ESC with brake. What's out there? Miami Mike Power Systems 3 Jan 13, 2013 02:55 PM
Discussion >>Any FJ Cruiser owners out there? daddiozz Life, The Universe, and Politics 20 Jan 09, 2013 08:11 PM
are there any 250 watt 3d capable bluecore plans out there? chimchim 3D Flying 3 Sep 07, 2005 09:19 PM
Any Smoke Experts out there? Jim T. Graham Fuel Plane Talk 2 May 30, 2003 01:46 PM
Any brushless experts out there? Parkflyer Power Systems 4 Nov 26, 2002 09:13 AM
