Any capable drafters or SketchUp experts out there??
Hey Guys,
I am currently designing and building two FPV rigs. One of the two uses a TBS Discovery and it is altogether another topic. For this project, I am attempting to build something from scratch that was inspired by the Shrediquette Bolt. I am calling it the "Ace of Spades" because it kind of resembles a Spade. This aircraft will be focused on flying in confined spaces (forest shots, inside buildings, etc), and will be an X8 configuration using Turnigy Park 250 2050 motors. Another RCG member, tech69x (Mike) has generously agreed to do the cutting on this frame from G10 material with his new CNC router. To let him do that, however, I have to draft something in a program like SketchUp. Well, after a few days of trying, I give up (for now). I will take a class in drafting some day but I have a deadline for this project: I am heading to Hawaii on 2/20/13 and I would like to take this build with me. Anyway, I was planning to make the design open source anyway so I was wondering if any of you could jump in to help do the drafting if you know how to use SketchUp (or comparable) proficiently? I would expect for there to be comments and design changes, but I think that this design might be useful. I have attached my (horrible) concept sketch. Hope it makes sense. Thanks, Matt |
Latest blog entry: SkullCopter Labs
Now, what are your actual thoughts as to it's efficacy as a FPV aircraft? |
You bet! Definitely more compact which is a big plus.
Two questions: 1) Where would you suggest mounting the 2-axis gimbal for the GoPro? In my crappy sketch I did I just assumed you would need to use those CF tubes to tie the frame together and since they would extend out in front, you could just hang the gimbal from them (a la xaircraft). 2) Does this leave enough room for all of the various Rx, Vtx, gps, fc, Lipo, etc? If push comes to shove, the GPS could be taken away as it is much less necessary for the purpose of this particular frame (most filming would be in dense/covered areas anyway). Really nice work Eric!! Now it reminds me of something Chinese for some reason. Like Chinese architecture or even a Chinese letter. |
I think I can answer my own question for #2: Yes. Put FC in middle, LiPo below bottom plate, Vtx and Rx on top.
Thanks again! |
I actually have two GoPros and the 3D kit, so I was thinking about putting that on a gimbal, but didn't want to overwhelm your design with frivolous requests. One other thought I had was that, given the purpose of this aircraft, it may be good to have that top and bottom plate extend out a little past the edge of the props so that they can handle the occasional bump into a wall, tree limb, etc. I am not sure the exact dimension of the props, but I wouldn't likely use anything larger than 6". Therefore, if the plate extended out in about a 3-4" radius from the center of the motor then it should protect the props. Do you agree? |
| Thread Tools | |
| Question I need a cheap 18 amp (or more) ESC with brake. What's out there? | Miami Mike | Power Systems | 3 | Jan 13, 2013 02:55 PM |
| Discussion >>Any FJ Cruiser owners out there? | daddiozz | Life, The Universe, and Politics | 20 | Jan 09, 2013 08:11 PM |
| are there any 250 watt 3d capable bluecore plans out there? | chimchim | 3D Flying | 3 | Sep 07, 2005 09:19 PM |
| Any Smoke Experts out there? | Jim T. Graham | Fuel Plane Talk | 2 | May 30, 2003 01:46 PM |
| Any brushless experts out there? | Parkflyer | Power Systems | 4 | Nov 26, 2002 09:13 AM |
