This thread is privately moderated by Nitro_Nancy, who may elect to delete unwanted replies.
Old Feb 01, 2013, 03:58 PM
Nitro_Nancy is offline
Find More Posts by Nitro_Nancy
Nitro_Nancy's Avatar
United States, CA, Industry
Joined Jan 2011
New Product
Tex RC 650mm - 900mm Mini Plane Collection
I am excited to announce our Tex RC mini plane collection! The sizes range from 650mm-900mm and come in various models. All come in either ready to fly or almost ready to fly versions.
4 Ch. Edge 540 Aerobatic Plane
Specifications:
Wingspan : 700mm(27.6in)
Length : 600mm(23.6in)
Weight : 310g(9.9oz)
Propeller 7*P6
R/C System:2.4GHz
Battery :11.1V 600mAh
Servo : 5g*3
Motor:C2205AX-KV1500 brushless
ESC: 10A brushless(high voltage)
3 Ch. 182 Sky Trainer
Specifications:
Length : 565mm(22.2in)
Weight : 265g(8.5oz)
Propeller 7*P6
R/C System:2.4GHz
Motor:C2205AX-KV1620 brushless
ESC: 10A brushless
Battery :7.4V 600mAh
Servo : 5g*2
3 Ch. J-3 Cub
Specifications:
Length : 524mm(20.6in)
Weight : 215g(6.9oz)
Propeller 7*P6
R/C System:2.4GHz
Servo : 5g*2
ESC: 10A brushless
4 Ch. PA34 Civilian
Specifications:
Wingspan : 900mm(35.4in)
Length : 766mm(30.2in)
Weight : 480g(16.9oz)
Propeller 7*6(3-blade)
R/C System:2.4GHz
ESC: 10A brushless
Battery :7.4V 800mAh
Servo : 5g*3
4 Ch. Spitfire Mini Warbird
Specifications:
Wingspan : 650mm(25.6in)
Weight : 230g(8.1oz)
Propeller 7*P6(3-blade)
R/C System:2.4GHz
ESC: 10A brushless
Servo : 5g*3
4 Ch. Zero Warbird
Specifications:
Length : 534mm(21in)
R/C System:2.4GHz
Motor : C2205AX-KV1620 Brushless
ESC : 10 amp Brushless
Servo : 5g*3
Purchase them here:
http://bit.ly/XZ7pvc
More Pictures and Videos will be posted soon!
Nitro_Nancy is offline Find More Posts by Nitro_Nancy
Site Sponsor
Old Feb 07, 2013, 12:50 AM
FlyGuy3345 is offline
Find More Posts by FlyGuy3345
FlyGuy3345's Avatar
United States, WI, Sheboygan
Joined Apr 2012
So who has flown the BF 109 ????????
FlyGuy3345 is offline Find More Posts by FlyGuy3345
Old Feb 11, 2013, 08:45 AM
CC16 is offline
Find More Posts by CC16
United States, VA, Roanoke
Joined Feb 2012
Anyone purchased one of these birds yet? I like the 109 for a possible baseball field flyer but would like some details to back it up.
CC16 is offline Find More Posts by CC16
Old Apr 18, 2013, 10:24 AM
Brian_ is offline
Find More Posts by Brian_
United States, TN, Nashville
Joined Dec 2007
"mini"?
Looking at the PA34, it says it's made of Depron. Is that correct?
Seems to be a Kyosho
http://www.rcgroups.com/forums/showthread.php?t=1322038
Brian_ is offline Find More Posts by Brian_
Old Jul 02, 2013, 12:59 AM
warhawk crazy is offline
Find More Posts by warhawk crazy
warhawk crazy's Avatar
United States, CA, San Diego
Joined Apr 2009
c rate
the pa 34 by nitro planes
ESC: 10A brushless isnt that 2 of them
Battery :7.4V 800mAh.....what is the c rated at ? 30.....i just didnt want to guess
because at nitro planes the dont show the c rate
warhawk crazy is offline Find More Posts by warhawk crazy
Old Mar 06, 2014, 11:55 PM
scarabaeus is offline
Find More Posts by scarabaeus
My Little Foamy
United States, CA, Emeryville
Joined Mar 2014
I bought the Edge 540T (RTF). Haven't maidened it yet (This weekend if the weather holds)
Pros (so far):
- The paint looks very nice for a foamie (vs EPO).
- Quick build, like 5 minutes, tops. Really it only took that long because 1) I was really trying not to scratch the paint and 2) because I had to hunt some screws down (see cons)
- Well packaged and arrived in great shape with everything working.
Cons (so far):
- The paint on scratches/flakes off like crazy.
- The screws that "lock in" the landing gear were missing, but I just used some spares from other planes.
- The magnets that hold the cab/battery compartment cover were stronger than the glue used to hold them on, so those snapped off immediately under their own strength. A little extra glue fixed that.
- TX seems a bit on the cheap side compared to the Dynam TXs, but when can you expect for such a great price.
scarabaeus is offline Find More Posts by scarabaeus
Old Mar 08, 2014, 11:22 PM
My Little Foamy
Joined Mar 2014
So I just got back from maidening the Edge, and it wasn't good. To start, the design of the battery compartment seems to have been an afterthought. You pretty much have to unscrew and remove the wings to get the battery in, which is a bit annoying. The tail wheel is also poorly designed and is really just a small wobbly disc of plastic on some wire (used as the rudder hinge), which made the plane spin violently to the left on takeoff. I'm going to have to mod this probably to remove the back wheel, cutting the wire and attach a more solid wheel to the rudder directly. On the plus side, the motor has some good spirit and should be enough IMHO to do some tame acrobatics.
Old Oct 17, 2014, 11:57 AM
shonmac is online now
Find More Posts by shonmac
shonmac's Avatar
United States, NJ, Dunellen
Joined Aug 2014
I need new landing gear for the 3 ch 182 sky trainer but the site says out of stock. Anyone know where I can get replacement landing gear?
shonmac is online now Find More Posts by shonmac
Latest blog entry: Upgrading
Old Nov 28, 2014, 03:36 PM
Keith Barnes is offline
Find More Posts by Keith Barnes
Gator
United States, CT, Essex
Joined Nov 2013
Can someone help with my Tex Spitfire 650mm. Binding and electronics.
Keith Barnes is offline Find More Posts by Keith Barnes
Data Google-Earth collection of flying / rc-fields AAAB507 Other Websites 11 May 01, 2015 12:17 AM
Discussion BH 4ch "Mini Pocket Rocket" 650mm P-51D ElIntocable Electric Warbirds 1 Mar 27, 2011 05:42 PM
Discussion Monsoon RC 900mm singchooi Sailboats 2 Feb 05, 2011 04:24 AM
For Sale FS: Electric RC Plane Collection ercman Aircraft - General - Miscellaneous (FS/W) 6 Feb 16, 2008 11:18 PM
