Old Feb 24, 2013, 02:17 PM
native18 is offline
Find More Posts by native18
Arkhangelsk, Russia
Joined Apr 2009
Originally Posted by nadine View Post
You could post,pid settings for the craft!?
What servos you use it!?
regards
servos: http://www.hobbyking.com/hobbyking/s..._13g_0_10.html
native18 is offline Find More Posts by native18
Old Feb 25, 2013, 01:52 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Originally Posted by native18 View Post
CG location is below the axis of rotation of rotors.
55cm length of the model
Weight 620g
screws 9x4x3
flight controller MultiWii Lite v1.0 (Bi)
motors - D2822/14 1450KV
battery 2S 3000
thanks for that, can you tell be how far below the motor pivot point the CG is ?
matwelli is offline Find More Posts by matwelli
Old Feb 25, 2013, 11:32 AM
native18 is offline
Arkhangelsk, Russia
Joined Apr 2009
The photo shows that motors are deployed down. Screws further. Ideally, the CG must be below the screws. My model is at CG screws.
Sorry, my English is not their native language.
Old Feb 25, 2013, 01:40 PM
Ran D. St. Clair is online now
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
It doesn't matter if the screws (propellers) are up or down. Either way, the thrust line is through the pivot point. What matters is the location of the pivot point relative to the C.G. I think you have effectively answered that question.
Thanks.
Ran D. St. Clair is online now Find More Posts by Ran D. St. Clair
Old Feb 25, 2013, 06:00 PM
v22chap is online now
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
I love native 18 's reverse engineering on the motor pivot points ... using a blade grip the wrong way around is a really neat idea ....
It took me quite awhile studing the picture to pick up on that ,,, enlarging also helped !!!
This would work great on tricopters also ,,, it will be filed away for future use
Thanks for sharing
v22chap is online now Find More Posts by v22chap
Old Feb 25, 2013, 10:37 PM
Joined Dec 2006
It certainly is a great looking thing. 10 out of 10 points for style!
Old Feb 26, 2013, 04:04 AM
VTOLicious is offline
Find More Posts by VTOLicious
VTOLicious's Avatar
Austria
Joined Oct 2007
Thanks.
True, thrust line is always through pivot and adequate pivot-CG-distance is crucial.
But it does matter if the motors are pointing up or down if the nacelles are not balanced itself - consider the weight shift! Dependent in which direction they are mounted the (longitudinal) CG will move with or against the desired pitch movement.
Rgds Michael
VTOLicious is offline Find More Posts by VTOLicious
Old Feb 26, 2013, 08:34 AM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Rgds Michael
This is true. I noticed with my bicopter if I let it hang by the arms, and disturbed it with the motors powered down, it would oscillate almost indefinitely. When I reverses the gain to be backwards, I could get it to almost immediately dampen out a disturbance.
ilektron is offline Find More Posts by ilektron
Old Feb 26, 2013, 11:32 AM
Joined Dec 2006
Rgds Michael
Good point - R.D.
Old Feb 27, 2013, 05:37 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Actually, there are a number of factors that goes into determining where the CG is on a Bicopter. 1. If it is an OAT or FAAT, 2, How high the props sets above the Spar and 3, the angle of rotation are the most important ones.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Feb 28, 2013, 12:19 AM
native18 is offline
Arkhangelsk, Russia
Joined Apr 2009
This is high enough? This model flies much better Gress Aero.
Old Feb 28, 2013, 12:37 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Native18,where is located the mwc board and the battery!?I never seen one foto of this...
Cheers
nadine is offline Find More Posts by nadine
Old Feb 28, 2013, 12:40 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
What is mean,OAT and FAAT !?...sorry my ignorance
At point 3,can you make one drawing?!
Regards
Old Feb 28, 2013, 07:07 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Hi native18.
How far down is your cg from propps!?
I attached on foto also...What dim.have there!?
PS.hope matwelli,d'ont kill us,for highjacking his thread
Regards...
Old Feb 28, 2013, 07:50 AM
native18 is offline
Arkhangelsk, Russia
Joined Apr 2009
CG just below the screws. Bending aluminum tube made ​​in order to raise the screws above the cab soldiers.
Photo provisions battery and controller I will later.
Discussion VTOL Bi-Copter - Tri-Copter Hybrid uberdisco VTOLs 1 Jul 14, 2011 01:07 PM
Discussion Bi-Copter - Tri-Copter Hybrid uberdisco Multirotor Talk 0 Jul 14, 2011 12:45 PM
Discussion VTOL Bi-Prop as UAV? GaryGress_1 UAV - Unmanned Aerial Vehicles 3 Aug 31, 2010 11:58 AM
New Product Vector 450 XE bi-rotor VTOL airplane GaryGress_1 Parkflyers 2 Aug 12, 2010 02:23 PM
