Old Feb 01, 2013, 03:49 PM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
VTOL bi-copter experiment
Based on some prior playing around with bicopters and thrust tilt platforms ( https://www.youtube.com/user/matwelli ) thought it was time to get serious about VTOL
for me, forward flight isnt the GOAL of this, its just part of the package, this airframe needs to be effective both hovering and forward flight, i look at forward flight as being a range-extender , with hovering to do real work being just as important
I have two designs, a quad based, and this, a bicopter
in hovering, it uses motor speed diferential for pitch control, it also tilts the motors slightly, this has no effect
uses motor side/side tilt for roll and yaw
to transition, the front/rear motors tilt to 90 deg, the yaw still works by tilting the front rear motors.
pitch control is controlled both by elevons on the wing, and by pitching the front/rear motors
roll control is by the elevons on the wing, and by the motor roll control, as they are above the CG they will still be effective
this is the maiden flight - the foam wing is for show that part is a while away from being sorted
downfall of this design, is as with all bicopters, effectiveness of roll control depends on the vertical diference between the CG and the motor pivot point, and with this frame its only 50-60mm , and changing the load will affect the control and PID tuning requirements - so my quadcopter design (next to be built) may be a better overall choice
VTOL Bicopter Maiden (2 min 13 sec)
matwelli is offline Find More Posts by matwelli
Old Feb 01, 2013, 05:31 PM
Brandano is offline
Find More Posts by Brandano
Actually, there's a way to control roll effectively that would not depend on the distance between the rotor til point and the CG: If the rotor had a swashplate and cyclic input. This is the way the V22 can manage to control pitch in an hover while still managing a decent allowable CG range. It is a cargo plane, after all.
Brandano is offline Find More Posts by Brandano
Old Feb 01, 2013, 06:00 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
are you talking vertical or lateral CG ? i can see it helping with a lateral CG change
the osprey (real machine not rc) is a very cleaver machine, but i am just using off the shelf motors and props, two fully functioning helicopter heads would be cool, but not what i am doing
Old Feb 02, 2013, 05:29 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Hi matwelli,
what board you use for stabilizations!?
Regards....
nadine is offline Find More Posts by nadine
Old Feb 02, 2013, 09:44 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Nice work mate! Looking forward to seeing where you take this project!
leadfeather is offline Find More Posts by leadfeather
Old Feb 02, 2013, 03:19 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
@Nadine - its an open pilot copter control board, I love using them because you can easily access the custom mixer to do some wild setups I have the tilt forward servos controlled by both pitch and an auxiliary channel mixed together
@lead feather - cheers, its certainly been an interesting experiment
Old Feb 02, 2013, 06:42 PM
v22chap is offline
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
Cool and simple ,, looking forward to what you do with this contraption and I say that with respect as it is the same type of test rig I usually use to prove an idea
v22chap is offline Find More Posts by v22chap
Old Feb 03, 2013, 11:59 AM
KAMAX-T is offline
Find More Posts by KAMAX-T
KAMAX-T's Avatar
Powell TN
very cool Matt...You are a talented individual...
Terry
KAMAX-T is offline Find More Posts by KAMAX-T
Old Feb 18, 2013, 02:40 AM
native18 is online now
Find More Posts by native18
Arkhangelsk, Russia
Joined Apr 2009
Hello all.
I want to present my bi-copter from the game Halo.
Falcon UH-144 HALO RC model bicopter (2 min 24 sec)
native18 is online now Find More Posts by native18
Old Feb 18, 2013, 05:43 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Originally Posted by native18 View Post
Hello all.
http://www.youtube.com/watch?v=V-DZXIj4RPk
OMG
Superb....
Old Feb 18, 2013, 04:18 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Hello all.
Well done, sir.
ilektron is offline Find More Posts by ilektron
Old Feb 18, 2013, 04:28 PM
piito is offline
Find More Posts by piito
piito's Avatar
Joined Oct 2010
Hello all.
In my opinion, you are the coolest russian i have seen on YouTube (after fpsrussia ). Great bicopter. Does it hover stable?
Greets from around the border.
piito is offline Find More Posts by piito
Old Feb 23, 2013, 08:49 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
wow - nicely done.
you should do a thread on it, size, CG location, settings, she certainly flies nice
Old Feb 24, 2013, 03:31 AM
Arkhangelsk, Russia
Joined Apr 2009
wow - nicely done.
CG location is below the axis of rotation of rotors.
55cm length of the model
Weight 620g
screws 9x4x3
flight controller MultiWii Lite v1.0 (Bi)
motors - D2822/14 1450KV
battery 2S 3000
Old Feb 24, 2013, 11:35 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Weight 620g
screws 9x4x3
battery 2S 3000
You could post,pid settings for the craft!?
What servos you use it!?
regards
Discussion VTOL Bi-Copter - Tri-Copter Hybrid uberdisco VTOLs 1 Jul 14, 2011 02:07 PM
Discussion Bi-Copter - Tri-Copter Hybrid uberdisco Multirotor Talk 0 Jul 14, 2011 01:45 PM
Discussion VTOL Bi-Prop as UAV? GaryGress_1 UAV - Unmanned Aerial Vehicles 3 Aug 31, 2010 12:58 PM
New Product Vector 450 XE bi-rotor VTOL airplane GaryGress_1 Parkflyers 2 Aug 12, 2010 03:23 PM
